Old 10-13-2011, 01:14 AM
  #361
Thojmoto's Avatar
found a nice pix of the relay on and the clips that hold it on a different thread
http://img18.imageshack.us/img18/3082/photo2ezz.jpg
Old 10-14-2011, 12:37 AM
  #362
Thojmoto's Avatar
Just got mine done, took about 30 min taking my time. I got my relay out pretty easily, used a regular pliar(not needle nose) and a small flat head.
Push the relay to one side off one of the clips, then grab it vertically with the pliars.
Use the flat head to push the other clip and with the other hand pull the relay off in an up and down motion with the pliars. Came off surprisingly easy.
Hope this helps some1.
PS. Didn't have wire cutters to cut the ressistors so i used a nailcliper FTW!
Old 10-17-2011, 05:29 PM
  #363
guitarplayer16's Avatar
Just did this.
I don't have any LED turn signals in yet, but when I turned on my 4 way blinkers to test out the job, I noticed the clicking was LOUDER than usual =(
Does that mean I screwed up? I can hear the relay clicking loud.
I don't know if it's just me.
Hopefully my LEDs come in tommorow.
Old 10-17-2011, 05:32 PM
  #364
vietxquangstah's Avatar
Just did this.
i think its either
1. just you
2. when you press the hazards, the left and right blink at the same time so it could be that both of them going off at the same time makes it a bit louder
have you tried signaling just left, or just right to see if it's loud?
i notice nothing in mines
Old 10-17-2011, 05:36 PM
  #365
Thanks dude!
I havn't tried that yet lmao
Is there a way I can signal left or right without starting up my car?
It's in the garage right now and it's cold out - I don't wanna start it up and let it warm just to test left and right signals lol
What you're saying does make a lot of sense, though (about how both signals going off could be loud).
Old 10-17-2011, 06:02 PM
  #366
Thojmoto's Avatar
You should be able to signal with the car off and the key in the on position
Old 10-17-2011, 06:16 PM
  #367
Hhmm never tried that yet. I've only tried without the key in and with the key in ACC lol.
I'll test it out tommorow on my daily commute =)
Old 10-17-2011, 06:37 PM
  #368
Thojmoto's Avatar
I think that's common for all cars, as im sitting in my work car right now, a nissan, and it works
Old 10-17-2011, 06:47 PM
  #369
you can turn your turn signals on as long as you turn the key to where it turns on the interior cluster lights.
i believe 1 click is ACC, 2nd click is ON (turn signals and headlights can turn on/off) , 3rd click is to START car
Old 10-17-2011, 07:03 PM
  #370
thanks fellas I'll be sure to find out tommorow on my drive lol
I just hope it's not because of my soldering job lol
I can only tell if they work once I get my front LEDs in =)
I was so excited to get them today, but turns out it didn't arrive yet.
Hopefully tommorow.
Old 10-17-2011, 07:30 PM
  #371
Hopefully tommorow.
pictures of the bulb and the packaging it was in please!
also are they switchbacks or rear signals
Old 10-17-2011, 07:31 PM
  #372
Will do!
They're front turn signals - 120 SMT Amber
I like my orange bulb as it contrasts lol
Old 10-18-2011, 02:30 PM
  #373
Just got the bulbs in the mail!
Now to install...
Old 10-18-2011, 02:41 PM
  #374
R.L. ina TL's Avatar
I fucked up bad and not sure what to do. I replaced the shunt resistor with the a .24 1w ohm resistor, installed my cleared/blacked out headlights by Jnc, then tested everything before putting the bumper and things worked great. I put the bumper on and right after that my car won't start, cluster lights won't come on and headlights won't come.
I just ordered a new relay and I'll try again. If worst comes to worst I have a great extended warranty that covers a crap load of electrical shit and hopefully this will fall under. Any thoughts on this?
Old 10-18-2011, 02:49 PM
  #375
BSpecialist's Avatar
You check your fuses? Better yet did you double check to make sure your battery is connected properly? Sometimes its small things that people (including myself) overlook. I don't see why it would work fine, then all of the sudden keep everything from working. I would bet it's not related to the resistor/relay.
R.L. ina TL (10-18-2011)
Old 10-18-2011, 04:38 PM
  #376
Bulbs installed, and no hyperblink.
Special thanks to everyone in this thread, and xavier25 for providing the .24 ohm resistors!
I can finally confirm (through my experience) that .24 ohm will work even if you're only doing the front LED turn signals and keep the rear turn signals halogen.
Will post a thread in Photograph gallery soon when I can get night shots.
Old 10-18-2011, 05:49 PM
  #377
Thanks BSpecialist, I took a break I'm gonna try to resolve this issue tomorrow. My pops said the same thing. The reason I ordered a relay was because it was cheap and I think my soldering what shitty and that could of possibly cause the fuse(s) to blow.
Guitarplayer16, awesome job with your mod man, hopefully I'll be joining this club soon enough lol.
Old 10-18-2011, 07:21 PM
  #378
Thanks dude
Make sure your accord fog wiring is good. I noticed my car had the same problem (NO power at ALL) after the accord fog install but I cleaned things up and it seemed to fix it.
R.L. ina TL (10-22-2011)
Old 10-19-2011, 09:19 AM
  #379
xavier25's Avatar
Good job and glad it all worked! The soldering wasn't all that bad after all, right? Enjoy the LED goodness!!!
guitarplayer16 (10-19-2011)
Old 10-22-2011, 05:48 PM
  #380
I'm happy to report that the bulbs work and I too have no hyperflash. The problem was my battery, some how it went completely dead. After charging it for 2 hrs at autozone then installing back in everything worked fine. Many thanks to everyone!!!
Old 10-22-2011, 09:56 PM
  #381
Thojmoto's Avatar
glad to hear you found and solved the problem. good job
R.L. ina TL (10-23-2011)
Old 10-24-2011, 02:50 PM
  #382
stavebomb's Avatar
Okay, so I did this and the LEDs don't flash anymore; however, both of my 60 LED switchbacks have failed. Furthermore, autolumination will not refund me or allow me to exchange them on the basis that 60 LED switchbacks require load resistors... What should I do fellas!? These things are damn expensive!
Old 10-24-2011, 03:32 PM
  #383
wow that's a first...
Are you saying you soldered a 0.24ohm resistor correctly and upon finishing and testing it out, you came to find out that both your front and rear LEDs are fried? They don't even turn on, or let alone flash at all??
Old 10-24-2011, 03:56 PM
  #384
Sounds like Autolumination is trying to take the cheap way out by making things up so they don't have to replace them. I'm no electrical engineer but I don't see why not having load resistors would cause things to stop working. They are still receiving 12v with the load resistor but I don't know what else would cause it to stop working. Make sure you have the module pressed in the correct direction and also make sure you press it in firmly so you hear the tabs click.
Old 10-25-2011, 04:08 PM
  #385
Cali_Joker's Avatar
I did this mod yesterday took me a while to remove the relay , kinda tight down here lol well finally it popped out n got me right on the bridge of my nose , ouch ! Lol I've never soldered anything before so I was a bit confoozed ;oP I too used nail clippers to cut the wires. I finished after 3 burned finger tips. worked out fine. Put it back together n ta da... No hyperflash. Although for some reason I feel they blink slower than before the hyperflash. Probably just in my head since I got used to the faster blink rate lol thanks for the great find OP . now, what else can I solder .... Hhmmm.... Lol
Old 11-01-2011, 04:02 PM
  #386
stavebomb's Avatar
No, everything worked fine for a while. They stopped hyperflashing. I do not have rear LEDs. The front LEDs only illuminate solid white. They do not blink either. Just white 100% of the time. They sent me a replacement bulb for one of them and that seems to be working fine...HMM!
Old 11-03-2011, 09:19 AM
  #387
Benny12's Avatar
In prep for my LED's for the rear and switchbacks for the front, I just tried this using a 1W 24 ohm on my 05 AT with halogen's in all 4 corners and neither turn signals right or left will blink, hazards will not blink either. I took the resistor out put the shunt back in, all lights flash. Any thoughts for help?
Old 11-03-2011, 11:19 AM
  #388
24 ohm or .24 ohm? You will need a .24 ohm resistor. If that's what you meant, make sure that your solder points are firmly connected to the legs of the resistor.
Benny12 (11-03-2011)
Old 11-03-2011, 07:06 PM
  #389
Benny12's Avatar
Thank you! I had the wrong resistors, after getting the right one all works fine now. I also received LED's for the rear today and installed those this evening and they work fine too. Now I'm waiting for JNC to ship my headlights and I'll install LED's in the front turns as well. Thanks again.
Old 11-03-2011, 07:13 PM
  #390
Cali_Joker's Avatar
where r u guys getting the rear leds from?
Old 11-03-2011, 07:16 PM
  #391
Benny12's Avatar
I have 7443 in the rear. I purchased them from Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OU:US:1123
Old 11-03-2011, 10:05 PM
  #392
I bought mines the same place where benny got his.... except i got the ones that were $5 cheaper.
http://www.ebay.com/itm/7440-Super-R...ht_1884wt_1269
2 of those = $24.48. free 2-3 day shipping.
the ones benny linked would cost $34.96 for the same 2 bulbs with the same 2-3 day shipping.
it's from the same seller btw lol
Cali_Joker (11-07-2011)
Old 11-06-2011, 08:53 PM
  #393
gogators22's Avatar
I'm about to pass out, but where can I order the resistors from?
Old 11-07-2011, 12:13 AM
  #394
Being an Acha Bacha in
Elegant TYPE S's Avatar
Someone want to make me a set ... hahaha... I'm just too dam lazy to do it myself. Can I do it.. of course.
Old 11-07-2011, 03:37 AM
  #395
Dsrtne1's Avatar
I did this mod a couple days ago. I was a little worried about soldering the resistor on the bottom side of the relay because I was afraid that my soldering might be too sloppy for such a tight space so instead of removing the oem resistor I cut it in the center and bent the two sides up and soldered the resistor to that. Seems to work just fine. Also, I used a .1 ohm 1 watt resistor. Great alternative to load resistors and it only cost me 58 cents!
Old 11-07-2011, 04:18 AM
  #396
gogators22's Avatar
interdating. where did you buy the resistor from?
Old 11-07-2011, 07:00 AM
  #397
tpham86's Avatar
any difference between buying a 1wt or .5wt resistor?
Old 11-07-2011, 09:39 AM
  #398
No.
And for those of you looking for where to buy these resistors, read earlier in the thread. Most questions regarding this setup have been answered.
Old 11-07-2011, 12:15 PM
  #399
Cali_Joker's Avatar
Just purchased these yay ! Thanks for saving me 10 bucks ;o)
Old 11-07-2011, 12:49 PM
  #400
no problem!
i bought those exact same bulbs about a month ago.
here's a video that shows how the LED looks while flashing compared to the halogen bulb
http://www.youtube.com/watch?v=au_sh...layer_embedded
sorry i didn't show both turn signals at the same time.. i was standing in my garage and i couldn't back up any further to show both turn signals because of a wall.
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
