Old 05-28-2011, 05:53 PM
  #241
practice89's Avatar
quick question about the p/n. is the 3rd pressure switch 28610-ray-003 and the 4th pressure switch 28600-ray-003n or is it the other way around? planning to do this later toniightt
Old 05-31-2011, 02:07 PM
  #242
vietxquangstah's Avatar
i didn't think to buy any "o-rings" or "10mm gaskets" for my pressure switches and transmission filter.
are they mandatory? i already purchased my 3rd and 4th pressure switch along with the trans filter, am i still safe to swap out my old switches and filter without using a new "o-ring" or "gasket" ?
Old 05-31-2011, 02:58 PM
  #243
dwb993's Avatar
You should be able to re-use the existing units, if they aren't too dinged up.
Old 05-31-2011, 04:06 PM
  #244
thanks. car only has 40k. hopefully they are still good
Old 06-03-2011, 09:15 AM
  #245
8th Gear
andreyfalcon's Avatar
Just replaced my switches on my 06 tl. the gears switch somewhat smoother. =) . cost me $108 at honda dealer (including 2 swithces, 2 washers, tax).
Old 06-08-2011, 10:39 PM
  #246
I'm Craig
cjTL's Avatar
Acurazine rocks, as usual. I have to thank the OP of this thread for making this excellent DIY. And a huge thanks to I Hate Cars for bringing this procedure to everyone's attention. I just changed my 3rd and 4th gear switches and WOW! No my car didn't suddenly feel like it had a 7 speed transmission, but the difference after doing this is so amazingly noticeable. I never even realized how horrible some of the shifts were until I felt what they're supposed to feel like. I only did a 15 minute drive, but I no longer cringe at sloppy down shifts or feel the car lurch forward on an up shift. The car felt like it was just "ready" when you stepped on it. The shifts just feel firm and the way that they're supposed to. This might be one of the best things I've done to the car since I've owned it. Thank you guys.
Who knew these little guys could pack such a punch. Off to the garbage can:
JCash23 (06-25-2022)
Old 06-08-2011, 11:25 PM
  #247
AVB for President!
TLTrance's Avatar
I wondered about the same thing as well... I believe the 28610 part is the 3rd like you have correctly identified. Hopefully the parts fit differently so that there is no way to mistakenly switch them.
Old 06-09-2011, 12:24 AM
  #248
I'm Craig
cjTL's Avatar
28610 is 3rd gear. Other is 4th.
Old 06-12-2011, 06:32 AM
  #249
Stillmatic29's Avatar
Ok, just need to know if on 07 type-s. The 4th gear switch is the one on the bottom of the trans by the vin tag? I assume the two that you can access from the engine bay would be the 3rd gear switches.
Old 06-12-2011, 08:34 AM
  #250
'07/'08 Type-S pressure switches? Help please
This applies to 07/08 type-s owners only.
Those of you that have replaced all 3 switches. Are the two switches that are accessible from the engine bay both 3rd gear switches? If so, I would assume the one on bottom of the tranny by the vin tag is the 4th gear?
Thanks in advance
Old 06-12-2011, 10:40 AM
  #251
I'm Craig
cjTL's Avatar
The gear numbers are embossed on the actual transmission itself. It'll be hard to miss when you go to replace them. I'm not sure on the last part though- 07+ TLs have a different procedure than the 04-06s.
Old 06-12-2011, 11:16 AM
  #252
AZ Community Team
Bearcat94's Avatar
http://www.acuraautomotiveparts.org/...s=&view=normal
I think we're talking about items #12 (2 of them) and #13. Double check the "Pressure Switch Replacement" thread to be sure.
(Actually, I'm going to merge this thread to that one.)
Old 06-17-2011, 04:28 AM
  #253
MistaWet's Avatar
When do a parts search for 3rd Gear Pressure Switch (28600-P7Z-003) It comes up for vehicles older than a 2004. Can I use the same switches (28600-RKE-004) for my 2004 TL AT?
Old 06-17-2011, 12:18 PM
  #254
i'm not too sure, but i would advise you to go with the pressure switches that people been saying to use since you got a 04-06 model.
you should be able to find the part # on the first 2 pages of this thread...
Old 06-17-2011, 02:25 PM
  #255
umakemekissu's Avatar
Originally Posted by paperboy42190
i ordered 2 3rd gear and 1 4th gear.
i dont know why the service manual says that but here is a diagram:
you see how there's 2 #12 and 1 #13? #12 is the 3rd gear and #13 is the 4th gear.
but yes i will be taking pics when i install mine to clear up any confusion.
I was told by AcK and a local dealership the opposite. There are 2x4th gear and 1x3rd gear. #12 are 4th gears, #13 is third gear. Local dealership part rep. told me the switches have different color marks so you can match them with whatever you currently have on the car.
anyone else wanna confirm on the 07-08 issue here?
Old 06-17-2011, 02:35 PM
  #256
Majofo's Avatar
He put in 2-3rd gear pressure switches and 1-4th??? no wonder his transmission has issues. It is indeed 2-4th and 1-3rd.
Old 06-17-2011, 04:03 PM
  #257
yeah I was really confused as well since there's not much info on 07-08 trans in this thread. But the thing is, are the switches really have color marks on them
Old 06-18-2011, 05:54 PM
  #258
P1zzaman's Avatar
How much trust would you place in dealerships to switch these out for you? I bought the switches for my 07. But looks a bit complicated. (Mind you I installed my intake)... or maybe I should just do it myself. I work better if there is a video tutorial though.
samplemonster (06-28-2011)
Old 06-18-2011, 05:57 PM
  #259
P1zzaman's Avatar
Wait, TWO 4th pressure switch and ONE 3rd pressure switch?
I thought it was the other way around. I got the parts haven't installed them yet. I have read conflicting information on this thread.
Old 06-18-2011, 09:07 PM
  #260
the info I got came from AcK and a local dealership. Double check with whevever you got the parts. and do your switches have color marking?
Old 06-21-2011, 03:55 PM
  #261
P1zzaman's Avatar
Hey guys, damn I JUST realized the 07/08 diagram is for the Type-S only.
I purchased the parts, two 3rd and one 4th.
Questions:
1. Base TL 07 have same transmission diagram? meaning two 3rd and one 4th
2. Also, I purchased the sensors mentioned here... but realized it's for type-s tranmission, are those the same sensors for my 07 Base?
Old 06-21-2011, 06:13 PM
  #262
Questions:
The 5AT transmission for 07-08 Base and Type S should be the same (except type-s has a cooler), which means the same diagram. The posted diagram is indeed for Type-S, but here is the Base 08 diagram
As you can see for the switches, they are only numbered differently (Type-S diagram is 2 of #12 and 1 of #13, Base diagram is 2 of #13 and 1 of #14). Part numbers are all the same.
The only unclear issue here is which part number is 3rd and which part number is 4th. But that's just for curiosity purpose. Looking at the above link , you can order the parts correctly based on part numbers:
2 of #13 28600-RKE-004
1 of #14 28610-RKE-004
P1zzaman (06-22-2011)
Old 06-22-2011, 02:38 PM
  #263
oarichard's Avatar
Ok, there is like 5 different types of model numbers for the sensors.. I'm tryna get this asap because I'm experiencing some minor tranny issues and don't want to let this get bigger.
Is it
28600-P7Z-003
28600-P7W-003
or
28600-RAY-003
28610-RAY-003
I have a 2004 TL btw.
Any help would be appreciated.
Old 06-22-2011, 03:22 PM
  #264
Stock2004TL's Avatar
Is it
28600-P7Z-003
28600-P7W-003
or
28600-RAY-003
28610-RAY-003
i ordered mines from delray and they came with the RAY description and just got it done over the weekend. i searched the one with p7z and p7w and they came up as 03 CL parts. don't know if thats correct or not.
oarichard (06-22-2011)
Old 06-22-2011, 09:03 PM
  #265
oarichard's Avatar
Ok thanks.
Old 06-23-2011, 09:53 PM
  #266
P1zzaman's Avatar
I think your dealership and Ack might be right. I took a peep into the engine bay and transmission, the one sensor that's easily visible had the number 4 marked on it. Couldn't tell if there were a number on the sensor on the back of it. But judging how the 2 sensors visible from the engine bay are the same, i'd say these are two 4th gear sensors.
BTW, how to move the aftermarket intake out of the way? it's like one solid piece... I tried to loosen the bolts for the shroud with the intake on and it's really hard.
Old 06-23-2011, 10:22 PM
  #267
I hate cars's Avatar
And people blame the type f fluid.....
Majofo (06-24-2011)
Old 06-23-2011, 11:03 PM
  #268
I don't have aftermarket intake so I can't help srry! Try searching around if all fails, take pics of your intake and post a thread in Problem/Fix subforum.
Btw, where is the location of the switch that you see marked "4"? Is it about the passenger side? back of trans? or front of trans?
I wonder have he checked in here and realized what he's done wrong.....
Old 06-23-2011, 11:33 PM
  #269
i have a injen cai and was wondering the same thing...
Old 06-23-2011, 11:44 PM
  #270
P1zzaman's Avatar
The one under the intake, side of the transmission, not the back. Driver side.
Old 06-23-2011, 11:55 PM
  #271
P1zzaman's Avatar
Ya I am thinking I might need to take off the front bumper and disconnect the intake at that point. What a pain. Also here is a pic of where one of the 4th gear sensor is. Notice in the second picture the "4"
I don't know how to move my intake out of the way easily. I marked the sensor with the red
The following 2 users liked this post by P1zzaman:
magnod (06-25-2011), umakemekissu (06-24-2011)
Old 06-24-2011, 12:37 AM
  #272
Majofo's Avatar
Old 06-24-2011, 06:36 AM
  #273
saip15's Avatar
Just did mine on my 07 Type-S. The switches are also color coded, the 4th gear switches have a white connector and the 3rd gear pressure switch has a black connector. Acura made it very simple to recognize the differences. Marking it on the transmission housing and the color of the connectors.
Another reminder, these are only supposed to be torqued down to 14 ft-lb. Which is barely hand tight, so if your deciding to make this a routine don't over tighten these. This also makes it easier having to take them off in the tight space we have to work with.
The following 2 users liked this post by saip15:
Bearcat94 (07-27-2011), umakemekissu (06-24-2011)
Old 06-24-2011, 08:36 AM
  #274
how does it feel after the change? any significant improvement? and have you also changed the ATF?
and did you follow the dIY that a member posted couple pages ago?
Old 06-24-2011, 11:02 PM
  #275
Kevin_K's Avatar
I'd like to thank you all in this site for the info gathered here. I have ordered 10 qts of atf racing fluid, everything for the 105k timing belt replacement, these switches, and the filter, etc today. If it weren't for all of the info on here I wouldn't have known where to start with this car. I am going to be able to buy a ud pulley and a k&n drop in for way less than the labor it would cost for doing these maint. issues. Thanks again... on to another search!!!
Old 06-25-2011, 02:46 AM
  #276
So with all this craziness. The switch# labeled 28600-RKE-004 should be the ones installed from the engine bay correct? There should be 2 of these right? For the 07 tls
Old 06-25-2011, 01:16 PM
  #277
Correct.. but compare the color on your old switches to make sure
P1zzaman (06-25-2011)
Old 06-25-2011, 02:20 PM
  #278
P1zzaman's Avatar
Here is a haiku for you
"Transmission sensors,
O seven third and fourth gears,
Get two whites one black."
Thank you
Old 06-25-2011, 03:08 PM
  #279
Thank you
I'm speechless... That's so beautiful it made me cry.
Old 06-27-2011, 12:34 PM
  #280
Mons shaver
magnod's Avatar
For those who installed in an 07-08 TL.
Was the difference as noticeable as others have said? I always felt that it did shift inefficiently, but is this the key?
