Acura ServiceNews Bulletins
#162
Administrator
March 2013 added.
Major topics applicable to 3G and 4G TL:
Sorry, not a darn thing for TL's this month.
#163
Administrator
April still not available. Will keep checking and update when available or if it is not available.
Edit update 14May13: April 2013 not published
#164
Administrator
May 2013 added.
Major topics applicable to 3G and 4G TL: Both of the following are too technical for hime use but you can check them out if you are having the problem.
Engine Shuts Off, but Power Mode Stays in ON or ACCESSORY
MIL On With DTC P2279After Throttle Body Cleaning or Replacement
#165
Administrator
June 2013 added.
Always Lube Oil Filter Gasket Before Installing New Oil Filter - General information
And a lot of technical stuff
#166
Administrator
July 2013 added.
General information: Interior Gaps, Squeaks, or Rattles? Try Urethane Foam
#167
Administrator
August 2013 added.
General information but very technical: Troubleshooting an Inoperative A/C
#168
Administrator
I posted and originally deleted this post, but I am opening it to show the reason why we probably aren't getting updates since it looks like Honda is publishing individual articles when, as said below, they don't apply to the average user. I can only hope they eventually publish a complete update to prove my theory.
Copy of PM from djarovsky with links to service news updates.
February 2013 is available via the individual articles, as Honda did not publish a monthly summary as they usually do.
http://techinfo.honda.com/Rjanisis/pubs/SN/B13020A.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B13020B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B13020C.PDF
April 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13040C.PDF
May 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13050A.PDF
June 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13060A.PDF
July 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13070A.PDF
August 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13080A.PDF
January 2011 is available via the individual articles, as Honda did not publish a monthly summary as they usually do.
http://techinfo.honda.com/Rjanisis/pubs/SN/B11010B.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11010C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11010D.PDF
October 2011 is available via the individual articles, as Honda did not publish a monthly summary as they usually do.
http://techinfo.honda.com/Rjanisis/pubs/SN/B11100C.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11100G.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11100I.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11100K.PDF
http://techinfo.honda.com/Rjanisis/pubs/SN/B11100L.PDF
No problem. Glad to help. I have access to the Honda and Acura iN (interactive network), so I check ISIS everyday. I also have access to Honda Service Express as well, as a backup source.
You can definitely find the articles and monthly summary yourself. You just change the last part of the links (i.e. 0A, 0B, 0C, 0D, etc.) and if there is an article or summary, the link will eventually work. Sometimes there are gaps in the letters though, so go up the alphabet. Honda/Acura used to use the 00 as the montly summary, but has since gone to the 0A consistently since May.
Originally Posted by Ron A
Thanks for sending me these. I merged your PM's so everything is in one place.
I believe they didn't post the summary because the individual articles do not apply to the average user in this forum, but I may post all of these in one post and put a note at the head of the listing to a link to the post. Still thinking about this.
How do you find these? Is it something I can do, or will you continue to furnish these for any missing summaries in the future?
April 2013:
May 2013:
June 2013:
July 2013:
August 2013:
#169
Administrator
September 2013 not published. See Post #168 above for more information on this subject.
#170
Administrator
LATEST INFORMATION 10NOV2013
Since I have been unable to access anything since April 2013, I will not be looking into this anymore.
If anyone finds a way to access new bulletins please post it here.
#171
#172
#173
Administrator
September 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13090A.PDF
October 2013:
http://techinfo.honda.com/Rjanisis/pubs/SN/B13100A.PDF
I'll try it that way next month and hope for the best, but if I don't get it right please post the links, if there is one.
#174
Administrator
September 2013 added.
#175
Administrator
October 2013 added.
Sorry, not a darn thing for TL's this month. Again.
#176
Forum Contributor
Received 1,391 Likes
November 2013:
http://techinfo.honda.com/Rjanisis/p...nu/B13110A.PDF
December 2013:
http://techinfo.honda.com/Rjanisis/p...nu/B13120A.PDF
December 2013:
#177
Administrator
November 2013:
December 2013:
December 2013:
#178
Administrator
November and December 2013 added.
#179
Administrator
I tried this link several times, and some variations of it, but no results yet.
Remove the space between "honda." and "com":
techinfo.honda. com/Rjanisis/pubs/SN/AH/B14010A/enu/B14010A.PDF
Will try again in a few days unless EE4Life can come to my rescue once again.
#180
Administrator
Nothing yet so until I hear differently, there is no bulletin for Jan 2014. I am subscribed to this thread so should get a notice immediately.
#181
Forum Contributor
Honda did not publish an Acura Service News for January 2014, hence why the link does not work.
The only Acura Service News articles published for February 2014 so far are the following:
B14020B - Intermittent SRS DTC 11-1x to 11-9x, 11-Ax, 11-Bx, and B0001-x to B0002-x
http://techinfo.honda.com/Rjanisis/p...nu/B14020B.PDF
B14020D - CMBS Indicator On with CMBS DTC P2583-97
http://techinfo.honda.com/Rjanisis/p...nu/B14020D.PDF
B14020E - Turn Signal Sometimes Won’t Cancel
http://techinfo.honda.com/Rjanisis/p...nu/B14020E.PDF
B14020F - Use ServiceExpress if ISIS Isn’t Available
http://techinfo.honda.com/Rjanisis/p...nu/B14020F.PDF
#182
Administrator
Thanks. It's good to get confirmation on that.
#183
Administrator
Nothing for February 2014 yet.
#184
Administrator
Nothing for March 2014. I did use the examples above and found a Service Article, so the system is working, but I didn't find a Service Bulletin.
Service Article example: http://techinfo.honda.com/Rjanisis/p...nu/B14030B.PDF
#185
Administrator
I found an article which might be of some help, but still no Service Bulletin.
http://techinfo.honda.com/Rjanisis/p...nu/B14040C.PDF
#186
Forum Contributor
Honda looks to have stopped publishing the monthly Acura Service News and is now only publishing monthly articles.
Below is an additional article for February 2014. Mods will need to update post 181 with this info.
mod edit-added to Post 181
#187
Forum Contributor
March 2014:
B14030B - New Software Version 3.013.014 Makes the HDS Easier to Install
April 2014:
B14040B - Apple iPod Stops Playing and iMID Flashes "USB Error" When Switching Audio Sources
http://techinfo.honda.com/Rjanisis/p...nu/B14040B.PDF
B14040C - Power Windows and Moonroof Won’t Automatically Open with Keyless Remote or Door Key
April 2014:
#188
Administrator
I didn't see any point in listing the articles that were not applicable to the average user.
Do you have to search for them individually like I did or do you have a method of obtaining them all together somewhere?
#189
Forum Contributor
I suspected that they weren't publishing any more but needed some confirmation.
#190
Administrator
Once a month ought to be good unless you get something important that needs to be posted immediately.
I'll put a note in the first post that there won't be any more updates and people can just check the posts to see what's new.
#192
Forum Contributor
July 2014:
B14070B
Engine Oil Leak From Main Bearing Cap Side Bolts
http://www.urvi.net/forumfiles/SN/B14070B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14070B.PDF
B14070E
2015 TLX Uses New ATFs and Fluid Naming Convention
http://www.urvi.net/forumfiles/SN/B14070E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14070E.PDF
B14070F
Understanding Auto Park Mode
http://www.urvi.net/forumfiles/SN/B14070F.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14070F.PDF
B14070H
Latch Plate Facing the Wrong Way? Don’t Replace the Seat Belt!
http://www.urvi.net/forumfiles/SN/B14070H.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14070H.PDF
B14070B
B14070E
B14070F
B14070H
#193
Administrator
Thank you for the information, EE4Life, and also for hosting the PDF so people can go directly to the article.
I added this information to the first page.
#194
Forum Contributor
August 2014:
B14080B
Front Passenger’s Weight Sensor Unit Won’t Initialize
http://www.urvi.net/forumfiles/SN/B14080B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14080B.PDF
B14080B
#195
Forum Contributor
September 2014:
B14090B
Battery Testing in 2015 TLXs
http://www.urvi.net/forumfiles/SN/B14090B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14090B.PDF
B14090B
#196
Forum Contributor
October 2014:
B970300
Before Replacing Electrical Parts . . .
http://www.urvi.net/forumfiles/SN/B970300.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B970300.PDF
B14100B
TPMS Indicator On or Low Tire Pressure Indicator Flashing on 7-Year-or-Older Vehicle? Check Tire Pressure Sensor Batteries
http://www.urvi.net/forumfiles/SN/B14100B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14100B.PDF
B14100C
Aftermarket Replacement Windshield May Cause Advanced Safety and Driver Assist Systems to Work Abnormally
http://www.urvi.net/forumfiles/SN/B14100C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14100C.PDF
B14100D
Center Rear Seat Belt Buckle Installation Is OK
http://www.urvi.net/forumfiles/SN/B14100D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14100D.PDF
B14100E
Keyless Access Won't Work with Front Door Handles and ENGINE START/STOP or POWER Button
http://www.urvi.net/forumfiles/SN/B14100E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14100E.PDF
B970300
B14100B
B14100C
B14100D
B14100E
Ron A (11-04-2014)
#198
Forum Contributor
December 2014:
B14020F
Use ServiceExpress if SIS Isn’t Available
EDITOR’S NOTE: This article revises "Use ServiceExpress if ISIS Isn’t Available," posted in February 2014. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/B14020F.PDF
B14120C
Dashboard Side Vent Reflection in Door Glass
http://www.urvi.net/forumfiles/SN/B14120C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14120C.PDF
B14120D
Ground Distribution Schematics Added to Next Generation EWDs
http://www.urvi.net/forumfiles/SN/B14120D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14120D.PDF
B14020F
B14120C
B14120D
#199
Forum Contributor
January 2015:
B150102
VSA Neutral Memorization Won’t Complete
http://www.urvi.net/forumfiles/SN/B150102.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B150102.PDF
B150102
#200
Forum Contributor
February 2015:
B15020B
Left-Foot Braking and the Brake Override System
EDITOR’S NOTE: This article replaces “Loss of Power While Driving? Could Be the Brake Override System,” posted in September 2011.
http://www.urvi.net/forumfiles/SN/B15020B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15020B.PDF
B15020C
Current EWD Column to Be Switched Off
http://www.urvi.net/forumfiles/SN/B15020C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15020C.PDF
B15020B
B15020C
Ron A (03-04-2015)
