Acura ServiceNews Bulletins
#81
AZ Community Team
Received 7,770 Likes
Originally Posted by Ron A
It must be Honda. I did what I always do, which is copy the preceding month's data and then change the month code and the actual month, and it still doesn't work.
Maybe there's something in it they didn't want to get out, or whatever.
I'll check it occasionally and see if it comes back or if I can find out what's wrong.
I can't see PDF addresses anymore or I would've tried that myself. New laptop, new setting and PDF's open in the reader instead of as a webpage.
#82
http://www.in.honda.com/Rjanisis/pubs/SN/B08030A.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030B.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030C.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030D.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030E.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030F.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030G.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030H.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030I.PDF
Why? I have no idea.
#83
Administrator
The original March 2008 is working again.
#84
Administrator
June 2008 added.
Major topics for 3G TL:
The Best Way to Unwrap a New Oil Filter (applies to all cars-good information)
AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied (05-08TL)
#85
Administrator
July 2008 added.
Major topics applicable to 3G and 4G TL:
New Microphone Assembly Improves Voice Command Recognition (09 TL only)
Use Torque Screwdriver to Tighten TPMS Valve Stem Nuts to Spec (06-09 TL)
#86
Administrator
August 2008 added.
Dead Battery? Check for a Bad HFL Control Unit (07-08TL)
15 pages this month but only one topic for us. And that one is more for the techs than the owners but included it for info purposes.
#87
Administrator
September 2008 added.
Sorry, nothing new for you guys this month.
#88
Administrator
October 2008 added.
Can't Find the XM Radio ID? Just View It Electronically (04-09TL)
Body Creaks: Some Handy Tips to Find and Eliminate Them
#91
Administrator
November 2008 added.
Fuel Cap Message On? The Fuel Fill Cap Is Loose or Missing (general info for all models)
#92
thanks for the info
#94
Administrator
December 2008 added.
Transferring Personal Data To a New Navi Unit: A Few Facts and FAQ"S (all 08 and later equipped with navi except 09 TL)
#95
Administrator
January 2009 added.
Don't Overtighten Those Battery Hold-Down Nuts (general information)
#100
Administrator
February 2009 added.
Can't Program Home Link? Try This Tip. 99-09 TL.
Power Mirror Works Erratically? Replace Just The Actuator. 04-08TL.
#101
Administrator
March 2009 added.
Power Door Locks Won't Lock With Keyless Remote or Lock Switch (04-05 TL)
#102
Administrator
April 2009 added.
Nothing applicable to our cars, but for general information:
Check Out the New Battery Cold Cranking Amps (CCA) Job Aid: Gives the Cold Cranking Amps for all Acura models. Might be helpful if you need to determine what the CCA is for your car when checking the battery, or if you want to check and see what size battery you will need for a replacement.
#103
Administrator
May 2009 added.
Removing or Replacing Trunk Spoiler? Replace Clips and Grommets (07-08TL only)
#104
Administrator
June 2009 added.
Disintegrating Clutch Disks Explained. All models with manual transmission.
Engine Oil Leaks From the Main Bearing Cap Side Bolts. Currently applies to all compact V6 models. I don't really know what this means but it may help someone with an oil leak.
#105
Administrator
July 2009 added.
Broken TPMS Valve Stems Can Break Your Wallet (All models with TPMS) Deep well air chucks are dangerous for your TPMS
Tire Puncture Sealants Are Bad News for Tire Pressure Sensors (All models with TPMS)
XM Sound Cuts Out; OK After Cycling Ignition Switch (Non-Navi 06-09 TL)
#106
'06 NBP TL 5AT NAV
Thank you Ron A. I check these every month, they certainly help me with my Service Writer discussions when I have a problem with my TL, especially when that problem is covered in one of these articles.
#107
Administrator
August 2009 added.
Connecting Rod Breakage Explained. General Information. May be helpful to those with CAI's who live in areas with lots of rain or are prone to flooding.
Trouble Resetting That Power Window Control Module? Check This Out. 04-09 TL
#108
Administrator
September 2009 added.
Properly Set ATF Dipstick to Avoid Starter Motor Failure-04 and later TL
Fix-It Tips For a Faded or Blotchy Dashboard-04-08 TL
#110
Administrator
October 2009 added.
Major topics applicable to 3G and 4G TL: None.
General information: effective July 1, 2010, any automotive shop doing repair or maintenance in California must check the tire pressures.
#111
Administrator
November 2009 added.
Trunk lid leak? Keep reading. 2009-10 TL (Base model only with the accessory spoiler)
#112
Administrator
December 2009 added.
Slow month. Nothing to add.
#115
Administrator
January 2010 added.
General information applicable to all models:
HomeLink transmitter won't learn remote transmitter's code.
A few words about 0-20 engine oil.
#116
Administrator
February 2010 added.
No music with iPhone plugged into USB adapter cable (09-10 TL)
No road name at bottom of navigation screen (04-06TL)
Honda logo at bootup; Navigation system features won't work (04-06TL)
#117
Administrator
March 2010 added.
Red sticker inside keyless access remote means water damage. 09-10 TL with tech package
Limited warranty policy changes with '11 models. General information
#118
Administrator
April 2010 added.
Sorry, not a darn thing for TL's this month.
#119
Administrator
May 2010 added.
Sorry, not a darn thing for TL's this month also.
