Yungone501's- Excessive infatuation with the J-series
#161
Received a few photos from Hickam lastnight. The first photo shows how the cylinder heads exhaust port is actually smaller than the flanges ID therefore we should be able to use them. This is great news cause they were about to become Matt's "shelf stock". ;-)
The final 3 pics show the beginning of the manifolds from the heads and the last is the brace of which the turbo will be mounted.
Rear
Front
And the brace
Rear
Front
And the brace
#166
I'm happy your going the turbo route. I can't wait to see what type of power you make. I didn't know you have a auto trans. That will be consistent and fun!
#167
Brian6speed, this is for you:
32mm is the adapter you're looking for.
brian6speed (02-19-2013)
#168
takin care of Business in
Received 4,732 Likes
^^^ you are detuning for the transmissions sake
IMO the engine will hold up 450hp fine....the AT might not be able to (at-least thats what I have seen on the 3G Side)
eager to see more
eager to see more
1foxbody (02-18-2013)
The following 4 users liked this post by yungone501:
yungone501 (02-19-2013)
#174
#175
Edit: forgot hes running the honkin auto. Less room to work with
#177
Front bank all tacked up in place. Photo also illustrates how much room the man has to work with. All hoses will be thermal sleeved.
Went ahead and ordered a dual core all aluminum radiator along with two 12" Mishimoto slim cooling fans. This should help with reducing engine coolant temps as aluminum has way better heat transferring properties than plastic (side banks).
mikebikelife (02-21-2013)
#179
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
So glad to see this build going to the next level, which rad did you order?
#180
Might I add, he's made some good time considering he has limited time to work on the build. I'm very fortunate I have him to do the work. There's not many people one can trust whenever you're a car guy yourself.
Thanks. I ended up going with an eBay company that I have received firsthand feedback from called Radiator Classic. They also have a 99.3% feedback rating on eBay as well from 75,000 different people. I went with an 03-07 Accord dual core radiator (very close to AV6 specs) because it had the j-series radiator tube configuration. I payed $110 shipped and has a lifetime warranty against manufacturer defects.
#181
damn that is SICK !! so jealous...
not of the car, but of your skill level
#183
Had the pleasure of working on the Accord at Matt's shop yesterday. A close friend and I went after work to relocate the battery to the trunk and replace the radiator and install cooling fans. The radiator I ordered ended up not working due to the position of the upper hose but atleast we got the old one out. I ended up ordering a radiator from CSF that is specifically for the 3.0 6th gen Accord that was triple the price of the first one. Atleast we know this one fits.
Snapped a few pics while we there of Mr Hickams work. In person, it looks 10 times better.
#186
#190
SICK !!!
once you are done with that, we can work on my car
#195
I'm honestly not sure how the auto will do in regards of traction...which is what I'm assuming you're referring to. I have yet to put it on the road. At 300hp, the trans. doesn't appear to have to much trouble but I also have 10.5" wide wheels atm. Guess we will see...this may just be the ticket I needed for a manual swap instead. ;-)
97BlackAckCL (02-26-2013)
swoosh (02-26-2013)
#198
(Mid-Atlantic)
(Mid-Atlantic)
