Vibration on acceleration for 2005 rsx
I just purchased a 2005 Acura RSX BASE MODEL with 67,000 miles on it and I noticed a slight vibration when I 1st accelerate from a complete stop. I replaced the air filter and the oil change and spark plugs were changed with in the month. Is there any thing else I can do? It's not a bad problem I was just making sure it doesn't lead to any future problems.
Check on your motor mounts. The usual one that tears on the RSX is the passenger side. It's sitting in plain view and should be easy to spot if it's broken. Happened with my old RSX. Then I got Innovative mounts and never had any issues after. $400? You should find one cheaper. It shouldn't run you that much.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
Joe Avesyan
09-29-2015 03:57 PM
MrHeeltoe
09-28-2015 05:43 PM
