rockstar143's '04 NBP progress thread (part deux continues after 6 year hiatus)
Old 05-14-2011, 05:26 PM
  #361
rockstar143's Avatar
Oh, AND, lookie what my cousin bought me. LOVE IT!!
Still couldn't bring myself to put a sticker on my car though. Can't...worked too hard to have it looking, clean and stealthy.
Old 05-14-2011, 10:50 PM
  #362
CLtotheTL32's Avatar
Received 9,493 Likes on 6,165 Posts
Shouldn't it be "sex, drinking, Acura"?
You must be banging ugly chicks if you drink first
Old 05-15-2011, 12:40 AM
  #363
Hey hey hey...I'm only banging one...and she's gorgeous.
I just like a buzz while I'm at it, makes it last longer.
Old 05-15-2011, 12:47 AM
  #364
Steven Bell's Avatar
Rockstar, you're living up to your name. Nice audio additions!
Old 05-15-2011, 01:07 AM
  #365
Hey, thanks Steve, quite the compliment.
Congrats on becoming a super moderator too
Old 05-16-2011, 07:13 PM
  #366
Ok, so my clutch pedal started wearing past the rubber to underlying metal and since I don't need much of an excuse for a reasonably priced mod. I contacted Unique Style Racing for a set of aluminum engraved pedals.
Quality was amazing. Feel is great, can't wait to drive yesterday.
Install took about 1 hour and 15 minutes.
I thought the brake/clutch would be the toughest, but they weren't at all since you can actually get to the back of the pedal to feel to put the washer/nut on. Take off rubbers, line up new one using the top and sides as a guide. Then mark with a sharpee...then start off with a small bit to prevent "walking" (since metal is too hard and it moves you can't really use a tap set) and to make it easier to get thru. Gradually up the size a little at a time until you can get a bolt thru.
Easy enough. Rear bolts are 6MM...so if you have a socket that size and a 1/4" socket wrench. You'll be happy.
The accelerator on the other hand, probably ate up 30 minutes of the install. I tried taping the nut and washer to my finger tip, no dice. Then I figured it out...put the nut INTO the socket since it holds it straight...then I used 2 tiny pieces of painters tape to hold the washer onto the socket (perfectly lined up the holes of the nut and washer)...worked like a charm. Also, do the top 2 first so you can wiggle the peddle up and down to get the angle you need.
Overall, super happy...they look amazing. It's the little things and details that really set your car apart from others.
Enjoy...
Out of the box:
Stock
installed:
for the price he gave me, I wouldn't go any other route. Great product!
Old 05-16-2011, 07:18 PM
  #367
MechEng
03tLsNBP's Avatar
USR pedals really are great. I got mine engraved with the 2nd gen Type S logo.
nice progress
Old 05-16-2011, 07:59 PM
  #368
Congrats Jeremy! I'm glad you went that route and didn't make the mistake of getting the eBay pedals.
Old 05-16-2011, 08:44 PM
  #369
Thanks guys, very much. Yeah, sometimes I stray and go back to my old, frugal ways, but then I have you all to lead me back to the light. Glad I went this route too. The guy gave me a killer deal. When I've tried so hard to keep the car looking good, and not cheap with my mods, it would have been silly to save a few bucks. This looks OEM, to me.
Old 05-16-2011, 09:38 PM
  #370
Thanks man-keep up the good work!
Old 05-16-2011, 09:50 PM
  #371
Chapter Leader (Houston)
TLDude876's Avatar
Pedals look clean! Do you mind telling me how much the set ran you? I am thinking of getting these for my 5AT
Old 05-16-2011, 09:53 PM
  #372
takin care of Business in
swoosh's Avatar
dayum the USR pedals look good J....thanks for the tips on the install...am getting my supercomputer pedals in next month (yes, first batch of the new supercomputer pedals)
Old 05-16-2011, 10:18 PM
  #373
guitarplayer16's Avatar
The new pedals look awesome!
Old 05-17-2011, 12:10 PM
  #374
Thanks guys...very much. VERY happy...
I was asked not to divulge but if you contact Simon from USR and tell him Jeremy sent you, I'm sure he'll give you the same price. Trust me, it's worth the call/email.
Check out this thread for contact info etc.
https://acurazine.com/forums/3g-tl-2004-2008-93/unique-style-racing-group-buy-pedals-788799/
Old 05-21-2011, 04:12 PM
  #375
posted elsewhere in the forum, but I like to keep my progress thread up to date.
So...2004 TL. Hot Florida sun...
Been reading about the horror stories and cracking dashes so I preemptively babied the dang thing...303 on it...and sunshade all day at work. So sure enough, yesterday FORGOT to put it up and there's a crack.
Cute.
Fiance got some ideas from an RL forum elsewhere on the web and I applied it. Worked well...
taped off the area so only the cut shows and apply some silicone caulk (or cock depending on where you're from and how big the crack is):
then I worked it in with my finger...it retracts a little as it dries so leave the excess, I used a razor and lightly skimmed the excess. Had to come back and do it again. The black bathroom silicone from HD that I had actually matches pretty well. I used my finger motions to try and leave a little texture as the dash is obviously not totally smooth.
I missed a spot so after removing the tape I put a dab on my finger and filled it in...as it dries you can actually use your finger to kinda remove the excess in to little balls that you can blow off the dash.
From a distance, is there a crack, who knows...there's something but it's a LOT less obvious IMO.
Old 05-21-2011, 04:14 PM
  #376
also in the heat, I noticed the hot glue I had used didn't hold up so well to holding up my tweeter, both of them had sunken into the dash. Had to leave it out and let it warm back up to pry them out and then I used a blade to remove the excess glue and I drilled a little hold and ran a wire to hold them in place from the bottom.
Old 05-21-2011, 10:00 PM
  #377
Sounds like I'm not the only one who's having a rough go of it with my car right now. Sorry to hear about your dash but damn that's a great idea!
Old 05-21-2011, 11:47 PM
  #378
Thanks man...
Yeah, is it just me, or is it when I choose to mod the car, all is well, I run into self caused problems to fix.
But then when I kick back and decide to just enjoy the car and not mod for a while, I get a slew of shit that needs to be fixed.
Another I forgot to mention was I didn't affix the deadener on one door too well so in the heat it fell and got stuck against the window. An easy 20 minute fix but still... it never ends!
At least the car challenges my ingenuity and feeble attempts at engineering.
Old 05-22-2011, 09:30 PM
  #379
kowloonsniperhk's Avatar
very nice pedals. kinda wished i got those instead of mine. So freaking hot down here.
Old 05-22-2011, 10:16 PM
  #380
Thanks man...which did you get?
Old 05-22-2011, 10:37 PM
  #381
Took my first stab at some shots with a DSLR...did a little processing, probably too much, but happy with the results, overall.
My neighbor with an EK joined me...
Old 05-22-2011, 10:42 PM
  #382
Yeah a little heavy on the editing. Remember, simplicity is always best.
What kind of DSLR were you using? The 2nd to last picture is effing dope.
Old 05-23-2011, 07:11 AM
  #383
It's a Canon 30D! I'm working on it, I like it heavily edited to a certain degree...I love HDRish pictures but I see that there is a balance to looking cool and realistic and looking like a cartoon. I'll get there...first set of pics, pretty much.
PS...thanks for the compliment!
The least touched up one then, huh?!?! I do love that one too!
Old 05-23-2011, 07:32 AM
  #384
veggiemonster's Avatar
yeah the sunset one is wicked. keep it simple and clean sir!
Old 05-23-2011, 08:14 AM
  #385
Gonna make me change my Avatar, huh?!?!
I do love that one...thanks for the compliment.
Old 05-23-2011, 11:37 AM
  #386
swoosh's Avatar
your car is fucking clean J....
here is Kansas where it rains every other day for 2 mins ruins the car....wanna move to FL
Old 05-23-2011, 02:16 PM
  #387
Don't move to Florida where it's so fu**in hot the dash cracks
LOL...plus, you'd be swapping tornado's for hurricanes!
At least we have the Heat!
Thanks man...trust me, it normally rains day after I clean the car. EVERY time.
Old 05-23-2011, 02:23 PM
  #388
swoosh's Avatar
i bet all acurazine members will be saying the same....
rains everytime after i clean my car....EVERYTIME
Old 05-23-2011, 02:25 PM
  #389
Yeah man, it's so annoying, I actually have a different set of tire shine gel I use during the summer that won't come off with rain vs. the less sticky one I use for the winter. Whatever...it is what it is. I guess better some rain than have to drive thru snow and salt.
Old 05-23-2011, 02:45 PM
  #390
swoosh's Avatar
yeah right rub it in my face LOL....
Old 05-23-2011, 04:34 PM
  #391
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
u can come move to Cali
Old 05-23-2011, 04:42 PM
  #392
swoosh's Avatar
so its like going from tornadoes to hurricanes OR earthquakes
from the frying pan into the fire
miami (fl) is higher in my books than cali....anyway....back to J's ride !!!
Old 05-23-2011, 08:46 PM
  #393
LOL...all good, man! PS...guess who WISHES he could live in Cali!
THIS GUY RIGHT HERE...San Diego all day long. I wish...perfect weather, nice people, can drive to beach OR mountains. What more can a guy want? One day I have a feeling I'll end up there!
Ok, so today, backing into a spot at jury duty...I figured I'd hit the parking bump before i hit the metal pole sticking up...WRONG. MAN, I hit it hard...dented Aspec. Oh well, I've convinced myself that all these little things are just battle scars and give the car character!
Touched it up a bit so not too noticeable...also, noticed my right rear tire is eating up on the inside. Dammit...those morons at tire kingdom don't know what the f*** they are doing. Since I'm going to have to swing by again anyway and get it REaligned, decided I'd lower the car a bit more, just to see. I'm seriously considering removing the camber kits to have the car sit and handle the way it naturally wants to. Not sure about it yet though. Pretty happy with the drop though...lowered it about more than 1/4" more of threads. Sitting LOW now.
I'll get some shots soon.
Old 05-23-2011, 10:29 PM
  #394
Damn Jeremy that sucks dude! It just doesn't end for us does it?
Can't you just adjust the camber kit instead of having it removed? Let it run -2.5 or something like that and just have the toe corrected.
Old 05-23-2011, 11:21 PM
  #395
Haa, we all wish we could live in Cali........where the cost of living is sky high and fuel is WAY over $4.00 a gallon. I just saw regular gas today for $3.65.
This has been a wet Spring. I just got new !uick Detailing Spray by Griot's Garage and it hasn't stayed on the Type S for more than a day....it's all good though. I love cleaning my car!
Come on Swoosh-KC isn't that bad. Besides, you'd miss me and Buda if you lived somewhere else!
Old 05-24-2011, 06:30 AM
  #396
jsonkimz's Avatar
I'd rather live in Cali with high cost of living and gas prices than in Baltimore with high cost of living and gas prices... At least maybe the awesome weather would lessen the pain. Snow and salt just rub it in....
Saw gas for $4.05 yesterday.... and was relieved.
Old 05-24-2011, 08:18 AM
  #397
i got mine from strut king.
Old 05-24-2011, 10:06 AM
  #398
MATT
06cmv6's Avatar
wow im late but those pedals look good!
Old 05-24-2011, 10:21 AM
  #399
was bored so i took some pictures i liked and played with them. maybe you'll like them, or not but i'll throw them up.
Old 05-24-2011, 11:01 AM
  #400
Thumbs up
Maybe I'm just baffled at how these morons can be THAT confused by the 2 arm lower camber system that's on the TL. Who knows...it just pisses me off that I've wasted countless hours waiting at this place and the attitude of the manager when I had to take the car back last time. And there's no repercussion...they won't buy me a new tire if i go down to the wires showing so they basically give me a printout and say 'well, looks to be in spec'. But the tires don't say that.
Whatever, just frustrated, I guess I won't remove the camber kits...that would be stupid. At least they are MOSTlY wearing evenly. Actually..just looked at the car...with the Tein's almost all the way down. MAN does that look good. I'll take some pics today or tomorrow if i think of it. There IS a HEAT game you all know!
I gotcha Steven...I agree...but yeah, even in Sofla, I paid $4.29 for premium last time. And I'm NOT near the mountains AND beach...and most of the younger hot girls don't go topless on South Beach anymore so THAT'S not even a balance and it's humid and we have a convergence of the worst drivers South America and the Carribean have to offer all in once place. Crime rate is great...but
at least we have the Miami Heat and Key Biscayne and Coral Gables and Downtown and the Grove.
Grass is always greener...main reason I haven't picked up and moved.
and you think these are nicer? We'll have to compare next time we see each other...got a canon30D now so I'm trying to learn how to take nice pics.
Thanks man...love em! Seriously...and another benefit I didnt' think of till yesterday...since your foot only makes contact with the rubber nubs...you actually don't feel as much engine vibration and feedback when cruising on the highway. Sweet!
i DO love em...thank you very much!
Quick Reply: rockstar143's '04 NBP progress thread (part deux continues after 6 year hiatus)
