Installing LED strip lights under headlights???
Old 08-11-2012, 02:02 PM
splew's Avatar
Since we're showing off LEDs...
Mine are Hella DRL modules though, not strips.
Old 08-15-2012, 12:35 PM
ogroncal's Avatar
Hi, Does anybody know what the best quality LED to install under bumper in grill? I saw a Momo one which I think got better quality than the rest. I saw some reviews that LED fails on some other product. I'm not sure about review for the 9 LED Audi Style. Momo 6 led I think is the best quality when it comes to big LED but is shaped as straight instead of curve looking at the top view. Does anybody know a curve shape that is good in quality? I did saw a MOMO 28 LED Daytime Running Lights but it might not look as good as the 6 LED.
links:
Momo 6 = http://ltbautosports.com/mo6hileddadr.html
9 LED Audi Style = http://www.dashzracing.com/Acura-TL-...udi-Style.html
MOMO 28 LED Daytime Running Lights = http://ltbautosports.com/mo28leddarul.html
Old 08-15-2012, 12:58 PM
ogroncal's Avatar
Unhappy Momo led daytime control unit
MOMO LED DAYTIME CONTROL UNIT
what does this really do?
Is it a sensor that turns the LED light on days only?
please send manual & install instsructions. thanks
Old 08-15-2012, 03:56 PM
splew's Avatar
^I have Hella LED DRLs. They are curved and fit the lower grilles well. There are pics of them in my previous post.
Old 08-15-2012, 03:59 PM
ogroncal's Avatar
how were these installed?
do you have a relay of some sort?
How do they operate? Continues on when ignition is on?
Do they adjust brightness when headlight is on?
Old 08-15-2012, 04:03 PM
splew's Avatar
1. By cutting out an opening in the lower grills and gluing them with epoxy.
2. Yes, a relay is included in the kit.
3. Yes, you can wire them to come on with the ignition.
4. Yes, they dim with the headlights.
I made a thread on them: https://acurazine.com/forums/3g-tl-2004-2008-93/hella-universal-led-daytime-running-lights-my-06-tl-847286/
Old 08-15-2012, 04:28 PM
  #47
ogroncal's Avatar
I'm getting the Audi Style 9 LED Daytime Running Light Universal Fitment
what relay or switch should I get for my LED DRL? I want them to turned on when ignition is on. I also want them to dim when headlight / tail light is on.
just like yours. thanks
Old 08-15-2012, 04:44 PM
splew's Avatar
You can have them come on with the ignition by tapping the relay power wire into the green windshield wiper motor wire under the hood (pictured below, not my pictures BTW).
Here's a somewhat crude diagram I made of how to wire the lights and relay:
As for the dimming with headlights, it is a built in feature on my Hella DRLs. I know most of the cheaper Chinese brands like those "Audi style" lights don't have the built in feature though, so I don't know how you would get yours to dim.
Old 08-15-2012, 04:59 PM
  #49
ogroncal's Avatar
1) So the white w/ red stripe is the same as the blue wire you mention above? white w/ red stripe comes from the module correct?
2) Your diagram above, the wire going to the ignition sense (wiper) green is for it to turned the LED when ignition switch is on. Where is the wire that connects to the tail light for dimming the LED's?
Do you think this will work? LED Daytime Running Light (DRL) Automatic Control On/Off Switch Relay Harness
link
http://www.ztechid.com/LED-Daytime-R...ess_22303.html
I found this also from Momo.
MOMO LED CONTROL UNIT
link
http://ltbautosports.com/moledcoun.html
it says: LED lamp kit control unit automatically regulates brightness: 100% brightness at ignition, 50% brightness when used in conjunction with head lights.
Old 08-15-2012, 06:06 PM
  #50
ogroncal's Avatar
Would you know the wire to tapped into headlight? Also the tail light. Thanks
Old 08-15-2012, 07:03 PM
  #51
Ciroqboy's Avatar
Those are hot. Im gonna try these on mine.
Old 08-16-2012, 04:07 PM
  #52
ogroncal's Avatar
Do you know where the wiring for the headlights to tapped into?
Old 08-16-2012, 11:11 PM
  #53
splew's Avatar
link
link
The picture I posted is just to show where the green windshield wiper wire used for ignition sense is. The other wire colors are not important.
Basically I just tapped into the green wire to power my relay. I then ran wires from the battery, though the relay to the lights. So basically when the key is on, the green wire is powered. That power goes to the relay, closes the switch which completes the circuit between the battery and the lights.
As for dimming, like I said, my Hella lights had the feature built in. They had a third wire coming from the lights (the other two being power and ground) for the dimming sense. I tapped this wire into the positive wire for the front parking light bulb (orange wire IIRC).
Those "Audi style" lights don't have built in dimming and I can't really comment on those "DRL control modules" since I've never used them and I don't know how they work.
Thanks.
Old 08-16-2012, 11:54 PM
  #54
ogroncal's Avatar
thanks for the response. How about the headlight wire. I want to tapped it into that wire so the led dims when headlight is on, not the tail light. also, how did you run your your wires from the drl to the ignition wire (wiper)? You drilled a hole under the car to the engine bay?
Did you add a fuse like 3amp inline with the + battery?
Old 08-18-2012, 01:03 PM
  #55
splew's Avatar
If you want the DRL to dim with the headlights and not the parking lights, you can just tap the dimming signal wire into the HID ballast positive wire.
Also, there is no drilling, all the wiring is under hood. The green wiper wire is part of a harness that's next to the brake fluid reservoir. You have to remove one of the plastic engine bay covers up near the cowl to access it, but those pics I posted previously make it pretty easy to find. As for fuse, I didn't use one. I'll probably add one in the future though, since they're a good thing to have.
Also, this DIY is a good reference as it covers some of the wiring and wire locations you will need. https://acurazine.com/forums/showthr...&highlight=drl
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
handsom-hustla
11-13-2015 05:04 PM
JnC
09-11-2015 06:06 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Installing LED strip lights under headlights???
