Modify your navigation system
Old 04-02-2005, 07:38 PM
  #81
Go Giants
Whiskers's Avatar
Received 1,231 Likes on 821 Posts
Originally Posted by n3ok318
someone need to make this sticky..
And maybe a summary e-mail on what needs to be done and instructions.
Old 04-02-2005, 11:32 PM
  #82
Professional Newbie
madmanmax3000's Avatar
wait, i just thought...can we change the voice directions??? that'd be awesome
Old 04-02-2005, 11:34 PM
  #83
kenji4861's Avatar
I think that takes "a bit" more work than
bypassing a warning screen or changing the opening image, but will let Byson give the final answer on that.
Old 04-03-2005, 12:10 AM
  #84
'05 TSX SSM/EB/AT/Nav
Mega's Avatar
I can't wait for "no nag". GO GO GO bysin!!!
I can say for a fact, my car will be safer without the nag screen. I never wait for the "OK" to pop up before I start backing my car out and then at some point between backing up, and getting into traffic I have to hit "OK" or the screen goes black.
Old 04-03-2005, 12:43 AM
  #85
HEKURTSEHU's Avatar
what "voice directions" ??? u mean the voice feedback ? isn't that all just data burned onto the DVD ?
BTW, bysin great job ! now i cant decide which replacement image to put up
Old 04-03-2005, 12:59 AM
  #86
Professional Newbie
well kenji, i was just thinking that if we are able to get into the different files on the Navi disc that all it would take was making our own recordings and swapping them with the factory ones. as long as we kept the same name and file type there shouldnt be an issue....at least i would assume
Old 04-03-2005, 01:05 AM
  #87
Delta Sigma Pi
jeffreytchui's Avatar
well technically you can change the voice response wavs, but they would have to be encoded in the same format/bit rate/ and size just like the BMP.
PS. Thank your parents for having you bysin, your awesome man. Where are you from? I work for an IT firm and we could use (paid) interns like you.
Old 04-03-2005, 01:14 AM
  #88
Delta Sigma Pi
Oh BTW: bysin,
Any luck on hacking the functionality of the PC Card slot.............imagine a world where you could hook up a WiFi card and surf the internet with your touchscreen navi and a CE based web browser(O WOW). Or plug in a USB/Flash PCMIA reader and MP3/Bluetooth support. But that seems impossible because the last time I heard of the PC slot being of any use it was for Alpine/Acura/Honda service diagnostics.
Old 04-03-2005, 01:24 AM
  #89
HEKURTSEHU's Avatar
wow slow down there dude - small steady steps is the key.
Old 04-03-2005, 03:14 AM
  #90
bysin's Avatar
I'm in orlando florida.. its pretty easy to modify the .exes if you know SH-4.
Old 04-03-2005, 12:22 PM
  #91
Professional Newbie
alright i finally booted up my pc and tried to do this (i'm a mac user) and the "dumpnavi" doesnt seem to run anything. Is this just a problem with my comp (has a ton of viruses) or are you not supposed to double click the "dumpnavi" app?
Old 04-03-2005, 12:29 PM
  #92
abirvalg's Avatar
bysin, what type of a processor did you pick in IDA for navi.exe?
was that the default metapc or something else?
thanks!
Old 04-03-2005, 12:34 PM
  #93
matelot's Avatar
didn't you say you do Java ???
How do you compile your Java code ?
matelot who thinks teens just dont read nothing no more.
Old 04-03-2005, 12:40 PM
  #94
Professional Newbie
so ur saying a need something that compiles in C++?
Old 04-03-2005, 12:51 PM
  #95
dailo's Avatar
dumpnavi.exe on its own doesn't run anything. Look at the readme you need to use the command line to make it work. Just put all your bins file in the same folder in the dumpnavi.exe and follow the readme.
Old 04-03-2005, 12:59 PM
  #96
matelot's Avatar
^^^^ READ post#94 above for answer
Old 04-03-2005, 01:43 PM
  #97
Professional Newbie
alright, it was definitely some computer issues...
now i'm at another issue. I successfully extracted the files and was able to replace the old Back.bmp with my new one. However when i enter "dumpnavi BN2HN18B.BIN update Back.bmp" i get the message "unable to stat file Back.bmp"
what am i doing wrong?
Old 04-03-2005, 01:48 PM
  #98
abirvalg's Avatar
man! just read all the posts it's not that long
  #99
Professional Newbie
oops, my bad i got it
my problem is that the file is just a TINY bit too big, anybody know a good app to shrink the file size a tiny bit?
Old 04-03-2005, 01:50 PM
  #100
Licensed Driver
Axygos's Avatar
thanks!
Post #1 States it uses a SH-4 Processor...
Old 04-03-2005, 01:55 PM
  #101
abirvalg's Avatar
ok
i saw that
SH4 or SH4B?
and why does the built in code analysis say it's a metapc
Old 04-03-2005, 02:22 PM
  #102
Professional Newbie
wow this is driving me crazy....my new pic is 113,983 bytes and the old one was 113,068 bytes
cant seem to shrink the damn file size...what am i supposed to do???
Old 04-03-2005, 02:24 PM
  #103
abirvalg's Avatar
open the old one in photoshop
put the new one over it
save
Old 04-03-2005, 02:29 PM
  #104
Professional Newbie
k, thanks, i'll try that
Old 04-03-2005, 03:25 PM
  #105
Professional Newbie
^finished
Old 04-03-2005, 03:52 PM
  #106
goddsmack's Avatar
One of the bin files, specifically the BN2HHMLD.BIN states that there is an invalid: "ECEC Header"...and i can't extract it.
Also do I need to update the "back.bmp" file for all 9 of the binary files? It seems it's on almost every one of them. Maybe I'm not getting this, but I find the "back.bmp" file, swap it out in each of the extracted binary directories, then do the "dumpnavi [binary file name] update back.bmp" command?
Old 04-03-2005, 04:06 PM
  #107
Team Anthracite Member
zax123's Avatar
OK I modified the navi.exe file using a hex editor, and saved it. It saved to the same (uncompressed) size as the original navi.exe. However, when I went to update the .BIN, it compressed to two bytes more than the original file. All I did was change address 0x0900 to 90h. I found another NOP in the file and it was also 90h. I figure that's all we have to do. Why is it compressing bigger than the original? Can someone help me? Thanks!
  #108
Professional Newbie
nah man, when the disc was in your car ur supposed to check out which of the BIN files your car uses, then just change the Back.bmp in that one
Old 04-03-2005, 04:15 PM
  #109
zax123's Avatar
I'm doing the nag-screen fix too... that's much more useful to me than the BMP swap
Old 04-03-2005, 04:21 PM
  #110
Just dial 1911
joerockt's Avatar
the readme.txt file tells you how to do it. Might want to start there. You dont need to extract all the files...
Old 04-03-2005, 04:48 PM
  #111
goddsmack's Avatar
OOOH oops...my badd :duoh:. Anyway it worked, but my image is a bit too shrunk, it's basically a block on the left side of the screen, how can you stretch out an image so it fills the screen? I don't have photoshop though either.
Old 04-03-2005, 05:06 PM
  #112
Professional Newbie
zax if you get the no-nag working can u post the *.exe for us
Old 04-03-2005, 05:07 PM
  #113
bysin's Avatar
The origional Back.bmp is uncompressed, I'm working on a new version to over write it with a compressed Back.bmp to allow for a slightly larger file size.
Old 04-03-2005, 05:09 PM
  #114
bysin's Avatar
You dont have to do it for every bin file, only the one that your car reads. Read the first few instructions to see what file that is.
Old 04-03-2005, 05:10 PM
  #115
dailo's Avatar
Bysin said he's releasing a GUI that will work on all versions of the navi soon.... just gotta wait guys. As for the image not fitting try opening the original Back.bmp in paint or something and just clear it and paste your new picture on top and make it so it fits. Then it should show up fine on the navi.
  #116
bysin's Avatar
nops in SH-4 are 0x0900.. 0x90 is x86
Old 04-03-2005, 05:13 PM
  #117
AndsX's Avatar
Awesome work bysin ... Its really cool ...
I am trying to make it work on my nav system .. but for some reason i get disc error when i try to load the new bin files from a CD disc.
BTW i have a different set of bin files in my system .
ADD.bin
BN2HH12C.BIN .... (6 bin starting with B)
zzz10.bin
zzz100.bin
Any one has similar kind of bin and made it work ?
Old 04-03-2005, 05:34 PM
  #118
Professional Newbie
ya andsx i had that same file list and i also got the disc read error. I just restarted the electronics in the car after i got the error (with the cd i burned in the back) and held map, menu, cancel and i still got into the diagnostics menu. From there i just hit load disc and it worked out fine, it loaded and i put the original back in
Old 04-03-2005, 05:50 PM
  #119
bysin's Avatar
I just updated the software http://www.linuxkiddies.com/bysin/navi.zip
It allows you to update your Back.bmp even when the filesize is a little bit over the origional filesize. I also included an example modified Back.bmp. I'm comming out with a navi-nonag.exe within the next couple hours.
Old 04-03-2005, 07:19 PM
  #120
Professional Newbie
awesome, cant wait for the nonag
you da man bysin
Quick Reply: Modify your navigation system
