DIY: door handle LEDs
Old 04-01-2007, 11:32 PM
  #81
3.2TL
ThreePointTwoTeeEl's Avatar
Damn wtf guys, your NOW doing this? I did this the night he put this DIY up lol..Took me 2 days but well worth it, White FTW!
Old 04-02-2007, 12:03 AM
  #82
I'm stock and hating it.
lokee99's Avatar
i gotta add i didnt shave mine. Didnt have the tools.
Old 04-02-2007, 05:50 AM
  #83
05 Acura TL: a-spec
Topher707's Avatar
ebay. thats where i got my dremel.
Old 04-02-2007, 09:30 AM
  #84
lokee99's Avatar
I think ima check that out then.
Old 04-02-2007, 10:43 AM
  #85
3.2TL
I didnt have a dremel, Just got some sand paper that was laying around and just went at it with that.
Old 04-02-2007, 11:18 AM
  #86
Prick of the month
02TLSfan's Avatar
Wow, that must have been time consuming.
Old 04-02-2007, 11:58 AM
  #87
3.2TL
not really, its only 4 LEDs. I just layed the Sand paper on the surface, and took the LED with my fingers and just started going back and forth with some force, the LEDs are very strong.
Old 04-02-2007, 06:14 PM
  #88
lokee99's Avatar
I wonder if I should just sand some down and solder them up and sell them on here LOL... I have 45 more leds and resistors.
Old 04-02-2007, 07:26 PM
  #89
3.2TL
I have like 70 something...who knows what I could do with them, possibilities are endless.
Old 04-02-2007, 09:47 PM
  #90
Davinci27's Avatar
Do you even HAVE to shave them down? whats the point of shaving them?..never thought about just putting them in full.
Old 04-02-2007, 10:29 PM
  #91
Prick of the month
02TLSfan's Avatar
Shaving the LEDs flat disperses the light at a wider angle, thus making it brighter. If you leave the top rounded you are really creating a pinpoint of light. I think flat the angle is 100 degree spread of light, versus like 20 or 30 degress if left round.
No, you do not have to shave them, it just makes them brighter. Which for this application isn't as critical as shaving them down for the dash, but it still helps to shave them.
Old 04-03-2007, 03:13 AM
  #92
05 Acura TL: a-spec
Topher707's Avatar
pshh i have like 500 just sitting around
Old 04-04-2007, 08:30 PM
  #93
Sean
seanranger3's Avatar
shoot i would by some if the right price
Old 04-24-2007, 12:37 AM
  #94
No He Can't
6MTUA5's Avatar
i just started doing this earlier tonight. i got them all wired up and ready to go and when i started to run the wires through the handles, they wouldn't fit.
i used some 16 ga wire i had sitting around instead of the recommended 20 ga.
the wire was too thick and i really had to force it through. then, when i opened my door, the handle just stuck out because it was getting caught on the wire. gonna go to get some 20 ga tomorrow and just cut down the wires to the shrink tube and make the rest of the wire 20 ga so the handle will be free to move.
Old 04-24-2007, 01:22 AM
  #95
Davinci27's Avatar
Also make sure that the wires inside the door are not in the windows way. I didn't check my front windows and when a friend put them down, the window cut the wire. Just take your time.
Old 04-24-2007, 01:29 AM
  #96
No He Can't
6MTUA5's Avatar
so just make the wires in the door long enough to go under the window when it is all the way down?
Old 04-24-2007, 08:25 AM
  #97
Davinci27's Avatar
No, all you have to do is follow the metal rod that connects to the door handle... when you take your door panel off, you'll see the window track. All you have to do is pass the wires behind the track.
Once you put the wires in the door handle..just follow the 2 metal rods that you see in pic above.
Old 04-24-2007, 12:21 PM
  #98
brandonnguyen's Avatar
for anyone who hasn't done this yet, i also found that it was easier to get the wire through the rubber boot, by pulling out the entire boot from both sides and then passing the wire through. After that is done you can just put the boot back. The wires end up behind the little foam piece where the seat belts are anchored. So peel that back a bit and feel around. That's how i got it to pass through. I also used a zip tie to snake through the rubber boot, but that wasn't necessary.
awesome diy calichris. you the man
Old 04-24-2007, 01:42 PM
  #99
No He Can't
6MTUA5's Avatar
quick question for everyone about LEDs in general... does it matter which way you put the resistor? there is no kind of marking on them.. is there a positive/negative side or can it go any way??
Old 04-24-2007, 04:18 PM
  #100
it can go anyway. But the resistor must be attached to the postive end of the led.
Old 04-24-2007, 06:09 PM
  #101
No He Can't
6MTUA5's Avatar
thanks
HELP!!!! I did most of the LEDs but ran out of wire so i have to go to Home Depot to get some more but there's only one problem.... my car won't start!!
did i blow a fuse somewhere or something? the radio and everything still works and it doesnt sound like a dead battery, just won't start. maybe blew the fuse to the starter or ignition?? please help!!
Old 04-24-2007, 06:16 PM
  #102
Davinci27's Avatar
Hmm....my battery did die out on me..all I had to do was give a quick jump-start. (the kits you plug into the wall outlet) There shouldn't be any reason why you would blow a fuse for the starter, the DIY tells you what fuse to tap into. When you do get your battery charged, next time you are going to be testing or adding more leds, disconnect your battery, so you won't blow any fuses. Good Luck
Old 04-24-2007, 06:18 PM
  #103
No He Can't
6MTUA5's Avatar
i just checked the fuse for the starter relay (#13) in the driver side kick panel and it looked fine... any other suggestions?
Old 04-24-2007, 06:27 PM
  #104
How about checking some of the other fuses, only way to know if YOU blew a fuse is for you to check its possible you tapped into the wrong one but its unlikely that it would cause the car to not start.. Or maybe a just try a jump start to see if it helps.
Old 04-24-2007, 07:13 PM
  #105
No He Can't
6MTUA5's Avatar
i wasn't asking people to come pull my fuses, i was just wondering if someone had an idea on where to start.
i checked all the fuses in the driver's side kick panel and all of the small ones under the hood. none of them seem to be blown.
i don't see what happened. i tapped into the correct fuse and even did that with them unplugged from the harness. tried to jump start, but it didn't work. i couldn't have fried the starter or something could i? i just got a new one too
Old 04-24-2007, 07:45 PM
  #106
Davinci27's Avatar
I doubt you fried your starter... Try jump starting it, might help...did you check the fuses on the passenger side?
Old 04-24-2007, 07:50 PM
  #107
I wasnt implying to have some one come help pull your fuses.
Did you check the other fuse panel on the Passenger side dash? You didnt blow your starter. Is there just no cranking at all ?
Old 04-24-2007, 07:55 PM
  #108
No He Can't
6MTUA5's Avatar
It cranks, and for as long as I hold the key, it makes the ttttttt noise like it's trying to start. Not just that one click like when your battery's dead. It just never makes a spark I guess. I recently installed NGK Iridiums but they have been fine until I started this mod
Old 04-24-2007, 07:58 PM
  #109
No He Can't
6MTUA5's Avatar
I tried jumping it several times with my roommate's 4Runner, but nothing. I am going to check the passenger side in a few, I just wouldn't think that any of those would cause the car to not start after reading the panel to see which ones were in there.
Old 04-24-2007, 08:45 PM
  #110
Davinci27's Avatar
I ALSO doubt that the LED mod killed your car. I think you are getting a lil to ahead of yourself with the spark plugs. Like i said before, when I did my Door LED's, my battery did die. However all I had to do was just charge it a lil, for a few minutes, maybe you need to give it a lil more time charging with your friends 4Runner.
You follow the LED DIY to the T?
Old 04-24-2007, 08:52 PM
  #111
No He Can't
6MTUA5's Avatar
Yea, I have a laptop so I just had it sitting there on the table when I was soldering and then took it out there with me to my carport. Maybe I will charge it for some more, but it doesn't sound like it is dead, since everything else works.
Old 04-25-2007, 12:17 AM
  #112
Davinci27's Avatar
hmm...well try disconnecting the LEDS, everything was working fine untill you started with the mod. So disconnect the LEDS and re-trace your steps. If the car still doesn't work, then I would start to worry.
Old 04-25-2007, 10:26 AM
  #113
When i did this mod, at the same time with the door sills, i unhooked the battery so it wouldn't drain while i was doing everything, and to prevent accidentally shorting the car. Hopefully it's just the battery.. Goodluck and hope everything works out.
P.S. I am assuming you had to unplug the 3 harnesses on the driverside, did you push them in all the way and make sure they are in tight?
Old 04-25-2007, 11:06 AM
  #114
No He Can't
6MTUA5's Avatar
i only had to unplug two of the harnesses. maybe i did tap into the wrong ones. they were the right color wires and it looked the same as it did in the picture. when i unplug the harness that i have the wires tapped into, my inside courtesy door lights go out, so im pretty sure i have the right harness. maybe i'll go back over the DIY and see what happened. not til later though, gotta study for finals.
Old 04-25-2007, 12:51 PM
  #115
Mz.Tre D..YEAH IM A GIRL
Korinny's Avatar
Yo, that is nice as hell! I might have to copy that
Old 04-25-2007, 01:07 PM
  #116
i don't think that tapping the wrong wires would prevent your car from starting but who knows. Make sure you didnt short anything, its easy to have the wires accidentally touch each other. But to be sure i would just disconnect all the new wiring you just put in. Also what kind of taps did you use?
Old 04-25-2007, 01:57 PM
  #117
No He Can't
6MTUA5's Avatar
i tried just using the (=====) connector where you put in wires from each side and press down on them with pliers, but you have little room to work with around the plugs, so they started to slip out. i ended up soldering the rest, and fixing the ones that were coming lose with soldering. so, it is going to be kind of hard to undo all the wiring if i want to redo it because when i cut the wire, i am going to have even less room to work with when hooking everything back up.
i will keep everyone updated as to what i did and what to look out for during your install
Old 04-25-2007, 03:16 PM
  #118
you need to get the correct size taps. Get the taps for a bigger wire guage. They ran out of 18-22 guage taps at radio shack so i had to use 16-14 which sucked. I had to cut some insulation off before tapping the wire to make contact. goodluck to you though.
Old 05-02-2007, 03:39 AM
  #119
99tlguy's Avatar
Thats pretty slick and sexy! great job by the way
Old 08-08-2007, 10:14 PM
  #120
9th Gear
inthezone's Avatar
hey I need help putting LED's on my truck, here's a pic.....
My car needs some bodywork and led help also
Quick Reply: DIY: door handle LEDs
