Car starts but dies and won't idle?!?!?
Old 05-24-2014, 07:25 AM
TL202's Avatar
Exclamation Car starts but dies and won't idle?!?!?
Hey guys just did the timing belt and water pump bc my water pump blew a seal so everything that was bad has been replaced so far....I went to crank it for the first time since that install and it started but will not stay running and will not idle. I can give it gas and make it run for a little bit but after I release throttle it dies! Any thoughts of what could make this happen? I have ran out of options at this point and I'm hoping my fellow acura owners may be able to help!?!?!
It's a 2002 acura tl base
Old 05-24-2014, 10:30 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
did you have the intake manifold cover off?
the top gasket can be installed upside down and look correct- but block an important port
match gasket to cover then flip over and install
timing marks- valve marks were perfect?- the cam moves slightly during belt removal
Old 05-24-2014, 10:54 AM
Mr.Helpful Diagram
ErickUa5's Avatar
Timing marks are crucial, You can verify by taking off both upper timing covers and match all 3, crank and both cams.
Is the check engine light on ?
Old 05-24-2014, 05:17 PM
3.2TLc's Avatar
How was the car running before the water pump blew ? Inspect all wiring connections and sensors.
Perhaps ya have a head gasket issue ? Any codes ?
Doublecheck your T-belt work and if everything lines up, then maybe it's something electrical or fuel related causing a problem. Pressure check the fuel and load test the charging system.
Old 05-24-2014, 05:50 PM
01tl4tl's Avatar
iirc you have to be careful of the crank trigger sensor while dealing with tbelt
knocking it loose off position or damage a wire etc
actual performers of this job can be of more help there
Old 05-24-2014, 05:53 PM
01tl4tl's Avatar
exactly how badly was it overheated- how many times in the red before it got fixed?
guessing the wp seal was leaking from drip hole for a while?
The above question about head gasket is valid, an oft found problem of poor running after cooling prob with tbelt and wp replacement is a blown HG
Old 05-24-2014, 08:24 PM
TLZINE99's Avatar
That seems like his problem sad he's going to do it all over again.
Old 05-25-2014, 12:32 PM
BoriTL's Avatar
When i did mine i had the problem of the left cam being off one tooth no matter how many times i did it so i backed that left cam back one tooth and when i popped the tensioner into place it moved that left cam tooth perfectly where it needed to be, be careful though cause its literally on the border of taking another stoke when backing it up 1 tooth.
Also make sure you replace the tensioner, i didnt and thank god it held up cause when i took it apart was locked in place and belt was completely loose, the seal behind the timing pulley, and make sure no teeth broke off of that timing pulley, i broke one off and car would turn on for a 1 sec and turn right off, didnt notice i broke a tooth off until a couple days, talk about frustration for the stupidest thing. Good luck
01tl4tl (05-25-2014)
Old 05-25-2014, 08:55 PM
3.2TLc's Avatar
^^^ This is why it's really important to replace all of the miscellaneous parts associated with the T-belt replacement. After all it's the heartbeat of our TL's motor and the service should be performed properly for best overall performance and lasting results for the next 100k. Not a place to cut corners !
01tl4tl (05-26-2014)
Old 05-26-2014, 12:04 AM
01tl4tl's Avatar
every tensioner-idler pulley-belt should be replaced,,another 100 bucks to do it right
cam seals ckd. thermostat from Honda a WISE investment and new rad hoses-heater hoses and rad cap
these cars have been in service more than a decade, do the 105 right and the car will do another decade with ease
Look at our mega moderators car, an 00 with 500,000 miles!!, daily driver plus track day car..now sporting a 3.7 engine and 5 or 6 speed manual trans
1lowtc
1G RDX (2007-2012)
15
11-19-2015 10:52 AM
2012wagon
09-29-2015 04:21 PM
jordanboi
09-05-2015 01:33 AM
NSolace
09-03-2015 08:14 PM
bymotion
08-31-2015 05:00 PM
Quick Reply: Car starts but dies and won't idle?!?!?
