Headlight Assembly
Old 07-26-2014, 10:50 AM
quim22's Avatar
Headlight Assembly
Hi All, I am a newbie to this forum so please bear with whatever protocols I have already screwed up on. I recently pulled a 2001 Acura CL 2 Dr Type S headlight assembly from an Auto Wrecking yard hoping it would fit my 2003 Acura CL. It looks identical. However when checking Ebay sales, the compatibility tool indicates it is not compatible. Does anyone know if that is correct? Can I swap a 2001 Acura headlight to put on a 2003 CL?
Old 07-26-2014, 10:55 AM
rossv1's Avatar
While I can't tell you if the parts are compatible, I can tell you that the eBay parts indicator has been wrong before with my car. I'll look at a part and it says it's not compatible even though I know 110% it is.
Old 07-26-2014, 11:06 AM
quim22's Avatar
Thanks Ross! Yes, that's how I feel about this. The Acura dealership says they look identical but there is a small difference in the part #'s probably because one part comes with the bracket and the other doesn't, anyway, thanks for your informative answer and I will definitely keep your answer in mind.
Old 07-26-2014, 11:32 AM
rossv1's Avatar
Have you already bought the part? Why not just install it and see if it works?
Old 07-26-2014, 02:31 PM
YeuEmMaiMai's Avatar
01-03 assemblies are the same
Old 07-27-2014, 10:54 PM
M90booosted
03-6/6's Avatar
only difference is the 01-02 have chrome housing and 03 is black
hashbrown
02-18-2022 11:20 AM
Mr.Tea
10-02-2015 10:32 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: Headlight Assembly
