Lost Features after 6 spd swap
Old 07-20-2014, 06:32 PM
DEPTLS's Avatar
Wussup guys...
So long story short. I have a 02 TL S that has been 6 speed swapped.
My concern is once i had the swap done i lost three features to this car which after not having them for so long I feel the need to try to regain them..
1st I've lost my reverse lights, when I throw the car in reverse. There is no indication I'm backing up and i think it's more annoying and dangerous to the motorists that may be behind me.
2nd I've lost the feature for my passenger mirrow folding down when I put the car in reverse.. i Love thag feature and miss it dearly. .
3rd, I have no cruise control anymore....
Does anyone have ANY knowledge they can contribute to me regaining 5 hose features? ?
Old 07-20-2014, 07:05 PM
M90booosted
03-6/6's Avatar
most likely lost it in the trans range switch or related wiring. youll have to compare wiring diagrams between your car and 03cls6 to rewire yours.
Old 07-21-2014, 08:45 PM
DEPTLS's Avatar
Hey thanks 03-6/6, I know it's in the wiring, but I'm looking for something a little more specific, or to see if there is anyone out there who has fooled around with the wiring and may know where I'd have to start.. I'm not great with wiring and i guess I need a good kick in the right direction.
Old 07-21-2014, 09:40 PM
Unregistered Member
Karanx7's Avatar
Well how did you swap the car? RV6 module or true manual?
I did the true manual swap in my 02 TL, and those features worked without custom wiring.
Old 07-22-2014, 12:05 AM
DEPTLS's Avatar
It was a true manual swap. However when the swap was done by my mechanic, the Dash harness was a part I didn't have, I ended up getting a connector from a Tsx that plugged right into the ecumenical and my mechanic re pinned the connectors to make the car start and run with no cel.. i am under the impression that this was done because the dash was already put back together and he did not want to take the dash apart again. I hope this helps.. if not I will try to get more information from him.. i would be asking him to take a look at this. But he is really dragging his ass to the point where I just want to get it done even if he is not the person fixing it. Every time i ask he act like he has ten million and 1 things to do and I'm getting impatient.
Old 07-22-2014, 09:24 AM
6mt swapped..smart
AnthraciteTypeS's Avatar
Not that this will help you, but I have the same problems after my 6 speed swap, so let me know if you get anywhere!
Old 07-22-2014, 09:52 AM
DEPTLS's Avatar
No doubt.. will do...
FYI I've already reached out to paul.. He's no help and is a total Douche about it.. not to say the man dont know, but seems to be some animosity because I didn't take the swap work to him.
I also texed my mechanic this morning and tried to get him to give me all info he could. But this is what I got back below..
I'm still at a loss and am still looking for a way to correct this mess...
Also. Karanx7 do you have the ability to roll down your back windows? And lock your back doors? How's that work?
Old 07-22-2014, 10:31 PM
M90booosted
03-6/6's Avatar
not trying to be an asshat, but the guy is right. itll take A LOT of rewiring to make all that stuff work again unless you do get the cls6 dash harness.
Old 07-22-2014, 11:16 PM
DEPTLS's Avatar
Right or wrong.. i just want done what needs to be done for my features to work.. nobody is donating work or time. I'm of course willing to pay for it to be done..
Not taken as an Ass hat comment. I believe him and what he's saying.....
don't change the fact I want my features back.. and if I move to another state will i fail inspection for no reverse lights?? I just want things to work like it should..
Old 07-23-2014, 05:37 PM
Unregistered Member
Karanx7's Avatar
Your mechanic knows what he is talking about, except for a few points. Forget a custom wiring harness, you can get an 03 CL-S6 wire harness that will fix most things.
Some of my windows and locks work. Rear passenger works completely, but driver's passenger doesn't work.
Old 07-23-2014, 05:45 PM
Unregistered Member
Karanx7's Avatar
I'm actually pulling out all of the true manual wiring out of my car. I can sell it to you after I switch back to auto wiring if you want.
Old 07-23-2014, 07:37 PM
DLntheCL's Avatar
check with your state, but i know mine (nc) doesnt require working reverse lights to pass, i know from experience
Old 07-24-2014, 08:38 AM
DEPTLS's Avatar
Why are you pulling it all out?
Are you by chance going with the AEM ems?
I need the dash Harness for thr passenger side under the glove box
Old 07-24-2014, 08:41 AM
DEPTLS's Avatar
In my current state it's not a problem, however I may be moving soon, so I'm not sure if there are limitations where I end up moving to.
Old 07-24-2014, 12:58 PM
Its simple wiring. You just need to connect the wires. Everything on mine works.
Here are some of my wiring notes i had. Im missing some but some may help you.
http://s265.photobucket.com/user/fst...?sort=3&page=1
DEPTLS (07-24-2014)
Old 07-24-2014, 01:02 PM
Unregistered Member
Karanx7's Avatar
Yea, I'm installing the EMS 2 with the auto sensors. There are 5 wiring harnesses you need:
-Engine Wire Harness
-Driver's Engine Bay Harness
-Passenger's Engine Bay Harness
-Upper Dash Harness
-Lower Dash Harness
The fusebox is attached and part of the Passenger's Engine Bay Harness.
TypeS860
09-03-2021 06:42 PM
blacktsxwagon
10-27-2015 10:12 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Sue1910
2G CL Problems & Fixes
09-27-2015 12:34 PM
hpfiend
09-27-2015 06:59 AM
Quick Reply: Lost Features after 6 spd swap
