Started on some in home porting
#163
Whats up with RDX owners?
Dunno. I was supposed to get measurements for RP, but Im lazy
#164
wham bam thank you ma'am
i wouldnt suggest dropping the sub frame either. but if u want to use the spacer with out milling it down and be able to have ur hood shut close, ur either gonna need the 09im (no sure if that will be enough, where the measurements at cd) or drop the subframe.
#165
One quick question, are the plenum gaskets metal/reuseable if I were to take them off to attempt a polish?
#167
If it dont fit.
I have to do something to the hood.
because my hood will close one way or another.
can you see the fuel injector rails with the spacer on. ?
#168
The metal gaskets can be reused. I prefer new ones though.
#170
B A N N E D
reuseable??? if you really wanted to you could, but i would absolutly not reuse them (unless they are only like a month old or something), but anyways they harden (and lose their eleasticity) up over time and take a seat to where they are positioned, and won't reseat exactly like before if you do decide to reuse them
but also if you do pull the valve covers make sure to put new seals on for the bolts and spark plug tubes too (most of the time they will come as a set with the cover's gasket)
#171
If Rajca cant measure his, I can get it later. Ive got it in the attic.
#173
K, well I can get the CL mani tonight or tomorrow morning, and the 09 TL manifold next week when I get my car back.
#176
not guaranteeing anything bc i dont know if ur gaskets are dry rotted or cracked. i looked mine over good before reinstalling them.
tl has 5k miles and my valve covers been on and off 3 times. same with my cl valve covers been off at least 5 times (damn bent valves) and they dont leak)
#177
here's a pic of one of the lower runners to compare lower holes.This is just most the weight out I think the front one had more work done.They also have not been cleaned up in this pic.
This is a old pic I just found in the cammera.
They are both completely done now besides paint.They are taped and pluged thou.
#179
B A N N E D
i got some ROC (or something like that, but you prononce it like rock)brand (i don't know there exact name, i just know the packageing is a white piece of cardboard with red lettering all over it), and have never had issues with that brand
#181
I always got to spend money.
My spare car was bouching in the front today.I lifted it up and 2 bad tires.So 2 more tires bought this week.
Since driving the car while my cl been down I've found a leaking valve cover gasket,tranmission mount riped so it bangs when I put it in reverse and 2 bad tires.
bad news but,a first some good news.
fed ex came by 2 days early,"Thats a first".
My last bolts showed up today and tomorrow I don't have anything to do yet.
So we might be able to have some fitment and performance reveiw tomorrow.
#185
Too much work. Skip it.
I would definately clean it really well though.
#188
I'm more than half way threw with the first grit on the TB now.
I'm starting at 220 so their wont be impossible straches to get out the tight conners.
This thing is going to be blinging when finished.
I'll put a pic up when I'm finished with it tonight,Also thinking I might go back into the front side of the TB again and do some more work since it dirty again anyway
#194
Looks great. Make sure you clean the throttle body real good when your done. You dont want those metal shavings getting into the motor.
#197
Thats all that matters
#198
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Keep up the good work RP
#199
