Started on some in home porting
Old 11-20-2009, 01:47 PM
  #81
3.7L Nitrous Breathing CL
richardparker's Avatar
^ Also what is the bore size of our pistons/cylinders ?
That will probally be one of the first things I need to know.
Old 11-21-2009, 04:29 PM
  #82
CLsuperhero's Avatar
http://www.honda-performance.com/info-lv2.asp?id=366
forged pistons for the j series can be found there^
Do you plan on staying NA or boosting? You will need to resleeve the block if you're going to try something crazy like 3.5 + turbo... our stock cylinder walls cannot handle much.
I have an 04 odyssey crank if you're looking for a build up...
Old 11-21-2009, 05:05 PM
  #83
thanks for the link
I just want the lower end to be able to handle 150-175 shot run after run all day.
I'm pretty sure the block will handle that.
mostly worried about the rods.
Upper manifold and TB will be next in line for the pnp since I just located a type s TB.
Old 11-21-2009, 05:09 PM
  #84
wham bam thank you ma'am
Rajca's Avatar
sweet. but whats the compression ratio? and what kind of ring can be used? oem?
Old 11-21-2009, 05:18 PM
  #85
The vavle train set up will work on type s heads ?
It don't say how big the valves are. Looks like some people will be calling them.
Now we need to locate some sticks for a decent price.
Old 11-21-2009, 05:35 PM
  #86
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,143 Likes on 4,810 Posts
A 3.5 can handle 10psi. Its when you start going for the really crazy build (3.7l + any kind of forced induction) that it goes boom.
Old 11-21-2009, 09:03 PM
  #87
lowrd on tein CS biatch
CL-S progression 01's Avatar
hahahah like a mazda... ZOOM ZOOM BOOM
like my probe with a KLZE in it...
Old 11-21-2009, 09:49 PM
  #88
B A N N E D
friesm2000's Avatar
SWEET... finally some lovin for the j series, never heard of that company though
and othe performance parts are on their site for the v6
Old 11-24-2009, 05:04 PM
  #89
No PnP updates but,the headers showed up.
They look good but,I think inside the header where the 3 pipes are welded could have been cleaned up a little nicer.
TB hopefully will be here tomorrow so I can get some more PnP in.
Still waiting on the injetor base gaskets so I can open up the lower holes on the runners and match them to the heads.
I seen some one selling some in the BM and their going to open pretty large.
Once the gaskets are here manifold is coming off and getting done.
Also I think the header install will be much easier without the manifold there.
Old 11-24-2009, 05:52 PM
  #90
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
Damn, so shiny! I'd like to see some gains afterwards though
Old 11-24-2009, 05:54 PM
  #91
Your Garage
DC3328's Avatar
what headers are those?
Old 11-24-2009, 05:55 PM
  #92
I'm sure there will be a few found.
OBX
Old 11-28-2009, 04:33 PM
  #93
Got a type s TB today.
So I started on it but,ran out of sanding stuff. The TB plate is also knife edged.To help with flow.
It don't look too bad,I might go opening it up a little more.
Also started on the spacer.
It's trimed,and I polished 3 holes so far.
I'm going to make this piece look show quality.
Old 11-28-2009, 04:41 PM
  #94
B A N N E D
friesm2000's Avatar
what's that orange stuff towards the right in your tb, almost looks like high temp rtv sealent or something, but don't see why you be using it though
Old 11-28-2009, 04:43 PM
  #95
polishing compound
Old 11-28-2009, 04:52 PM
  #96
B A N N E D
friesm2000's Avatar
Originally Posted by richardparker
polishing compound
fair enough, did you do it with the plate still installed or disassembled everything
Old 11-28-2009, 04:56 PM
  #97
Plate came out but,there was no need to remove shaft and assembly.
Throttle plate was also thined and and beveled at the edges to reduce drag.
Old 11-28-2009, 05:05 PM
  #98
B A N N E D
friesm2000's Avatar
so it is still the factory bore just the casting marks on each end were matched with the fatory machining for the thottle plate ???
also throttle plate thinned??? like you put it on a belt sander or something to make it thinner , cause the 1 thing i be worried about it being too thin would be when you are under high vaccum (engine braking) and it collaspeing/bending inwards, then it accelerates when in realality you are wanting to stop/slow down
Old 11-28-2009, 05:11 PM
  #99
Factory bore where the plate is yes.The inlet and outlet are a little larger and all bad castings are smooth.
It's all good,The plate is thiner the last 1/8" to 1/4" .Then the back side of the blade is beveled so the rushing air will flow easyier than going over the blunt edge that was there.
I put up pics of the blade after.
Old 11-28-2009, 07:02 PM
  #100
Throttle blade, The TB is farther along than this.
Close up to see beveled edge on blade.
Again tb is further along than this,
blade is fully buffed now.
Old 11-28-2009, 07:05 PM
  #101
Rajca's Avatar
if its possible. id rivet in the plate instead of using them screws which can mess up the air flow.
Old 11-28-2009, 07:12 PM
  #102
I was actually thinking of thinning the shaft to picking up some more but I don't know because it might take away from the strenth.
might just try to blend the sharp edge of the shaft thou.
Quicker throttle response soon.
Old 11-28-2009, 07:20 PM
  #103
B A N N E D
friesm2000's Avatar
or you can be like nissan on their VQ35 engines with drive by wire (~01 to 06)(especially the car ones) where they put a tsb out about the throttle plate screws backing out and going into the engine, you know the end result with them not always warrentying them, so i would loctite them in place at a minuinum (spelling?)
yeah i proably would just smooth out the edges
Old 11-28-2009, 11:18 PM
  #104
I don't feel like messing with it anymore.
This throttle body should perform well the way it sits.
Old 11-29-2009, 12:36 PM
  #105
civicdrivr's Avatar
Did you get a new throttle plate to seal it up? If not, you may have idle issues due to air getting past it.
Old 11-29-2009, 01:20 PM
  #106
B A N N E D
friesm2000's Avatar
still factory bore, so new plate not really need, just the rounded edges might not seal as well, but by the looks of it, it should be alright
Old 11-29-2009, 03:12 PM
  #107
plate is perfect.
The od of the plate was never changed.
If you look at the pic above you will see I left 1/3 the thickness and tapered off the back.
It makes a perfect seal doing it like this.
also reduces on drag
Old 11-29-2009, 10:00 PM
  #108
civicdrivr's Avatar
Ahhh, I didnt read it, I thought you bored it.
Old 11-30-2009, 12:12 AM
  #109
so I was board about a hour ago and took the manifold and throttle body out.
I took a pic with the mdx spacer sitting on the manifold to show how much will be getting taking out of the manifold holes to port match.
This manifold will flow crazy when fully macth port and polished
Old 11-30-2009, 04:39 AM
  #110
Rajca's Avatar
nice. but wish u can do some before and after dyno's
Old 11-30-2009, 09:57 AM
  #111
little too late for the before and after's.
I'll let everyone know how it will perform from behind the wheel.
I want to get the plenums off to work the whole intake.
Is there reusable under them ?
Old 11-30-2009, 10:08 AM
  #112
ThegreatGATHby's Avatar
If you are worried about the shaft, you could always throw in a little [epoxy of choice] to smooth the transition from the throttle plate to the shaft.
Old 11-30-2009, 05:14 PM
  #113
stripped and cleaned the manifold today.
and only opened up the TB inlet to match the type s TB.
maybe I little making it larger and when it goes threw finishing steps it will be perfect.
every passage in these manifolds has a overlap.
I cant believe how bad the passages are lined up from factory.
Old 11-30-2009, 06:07 PM
  #114
B A N N E D
friesm2000's Avatar
reusable maybe, but they are metal gaskets under the plenums like the lower one (next to the mdx spacer), so kinda your option i guess
Old 11-30-2009, 06:11 PM
  #115
B A N N E D
friesm2000's Avatar
you also gotta remember they mass produced our engines, so you gotta give them some leeway, but yeah i thought honda would be able to do it better than what i have seen on mine
Old 12-01-2009, 12:51 AM
  #116
here's another pic
TB inlet opened up a little more. everything is rough,tomorrow everything should be looking good.
This is a pic from inside the runner to see if the TB is lined up.
Tomorrow the rest of the manifold will be completed.
I finished the spacer tonight.
Old 12-01-2009, 03:08 AM
  #117
CH46ESeaKnight's Avatar
You could be in for some trouble doing that man. You may end up with a high idle. Its your can and do as you will, (I know you will) but messing with that butterfly could be bad news. Myself, I would not have done that.
Hope it works out for ya though.
Everything else looks good!
You might be able to ge a few video screens into the top of the manifold???? J/K!
Old 12-01-2009, 03:13 AM
  #118
Did you remove any material from the TB where the butterfly sits when it is in the closed position?
Old 12-01-2009, 04:30 AM
  #119
Rajca's Avatar
^no he didnt. thas why its gonna be all goo.
Old 12-01-2009, 11:58 AM
  #120
^ x2
here's a pic of the manifold matched to the spacer(in the rough).
Quick Reply: Started on some in home porting
