2G CL Frequently Asked Questions No New Threads Please.
DIY: Springs & Shocks (And how to remove rear seat)
Old 08-30-2006, 01:09 PM
vidhartha's Avatar
alrite guys, if anyone can help, i cant seem to get the f**king sway bar link off, i turn that bitch and nothin happens... anyone else had this problem, the bolt turns, but doesnt actually come out.... im tryin to do this RIGHT NOW... so any help now wuld be great
Old 09-06-2006, 03:15 PM
ChairmanMaoSaysRTFM
SatinSilverTypS's Avatar
did you know you have to hold the inside of the bolt with an alan wrench? it slips in the shaft of the bolt. but if you can avoid it don't undo this bolt. they strip easy and never tighten all the way back up and cause rattles. just unbolt the whole bracket the link is connected to if you can.
SSTS
Old 10-08-2006, 05:57 PM
jpgolf14's Avatar
great directions for removal of the strut assembly. i needed it to replace a failed stock strut with a replacement. instructions were perfect, but for others interested, i did it without any help. once you position the strut assembly back into the car, you can hold it with one hand and put one or two nuts on the top to hold it in place.
Old 10-17-2006, 12:34 AM
efhead's Avatar
Nite,
can you elaborate on the 'rail car' feeling? Did your work make you feel more in touch with the road / make it more of a drivers car?
Thanks, that DIY is excellent - seriously - this posts saves $$
Old 10-31-2006, 04:46 AM
03 CL-S
truexh's Avatar
Originally Posted by NiteQwill
Thanks.
H&R Sports were $150, Bilstein was $419 off ebay. Camber is car specific, not suspension specific, although it is a given with some (Tein, Race springs, etc.). My car needed no camber kit, I'm only off by hundredths of a degree.
PM me and we can talk about price and installation. It's all dependent around school and work. But my friend and I are willing to do any suspension install for a fee.
why does your bilsteins off ebay cost so much? because on AJUSA is only 271$ for both front + rear, Is there something more you are getting from the ebay one? what is the AJUSA missing? Im just curious because its so much cheaper from that site
Old 11-08-2006, 12:18 AM
03 CL-S
truexh's Avatar
nevermind, found out it was only for 1 shock... anyway ill ask more question if i get stuck trying this installation...
Old 04-26-2007, 02:06 PM
  #47
i heart latin chicks
nbennettksu's Avatar
Bringin this back, but its going to come in hand next weekend!
Old 05-02-2007, 12:05 PM
Itch71's Avatar
Awesome DIY!!
Wow NiteQwill....who needs Helms whith this DIY?? I need to change my rear shocks on a 99 TL. All is stock and want to keep it that way. Thinking of using KYB GR-2's. Are these OK? I have 100K miles on the car, I'm wondering if I have to change my coils at the same time, or should these still be good? Is there a way to check? Last question....re. marking the alignment, obviously this does not apply when changing just the shock right?
Thanks for your help!!
Itch
Old 05-02-2007, 02:27 PM
  #49
ya, NiteQwill is the shiz
Old 05-14-2007, 10:31 AM
  #50
Itch71's Avatar
So I followed NiteQwill DIY for changing my rear shocks on '99 TL. Anyone who follows these instructions, will be able to attest to the fact that this job is very manageable for the handy do-it-yourselfer. I was faced having to tackle the project without a helper. Once I pounded the old shock absorber inward and free of the lower mount, it was fairly easy for me to remove the coil-shock assembly from the vehicle by pushing down on the hub and sliding the assembly to the center-rear of the car...i.e. behind the upper control arm (leading) and then downward. I then had enough clearance and "wiggle-room" to remove the assembly top hat out first. My 8$ rented spring compressors worked like a charm. I now know what is meant by aligning the vertical position. Once the shock is replaced and the coil decompressed, the 2 top hat bolts and the bottom mount (bottom shock bolt) have to line up perfectly to re-assemble. If not you almost have to recompress the coil and re-align....which indeed is a PITA. That being said side 1 took me about 1.5 hours and side 2 about 40 mins.
Car handles great again, and I'm happy with the $$ I saved!!
Itch
Old 05-14-2007, 10:34 AM
  #51
dah, I still haven't had the chance to do it yet, and now I'm about to be out of the country for two weeks...
Old 05-14-2007, 11:00 AM
  #52
ridin slow'n'low
smokendsm's Avatar
Someone above mentioned that the sway bar end links need not be disconnected to do this. Is this confirmed?
Old 05-15-2007, 06:42 AM
  #53
Sound-Mind's Avatar
I can confirm this. Just finished mine without removing the end-links. I removed the lead and trailing bar bolts to give me some extra play (these are much easier to deal with). Then I just took my time and worked them out from under the well. It will take some pushing and pulling but it *is doable*.
Old 05-15-2007, 08:46 AM
  #54
Itch71's Avatar
Interesting....I didn't have any probs removing the end-links.....course i just replaced them about a month ago so the nut came off no problem. I actually thought you had to remove the links to be able to drop the hub assembly down to make room for removal.
Old 05-15-2007, 06:27 PM
  #55
Sound-Mind's Avatar
My end-links were being a PITA. Reminiscent of those found on an exhaust system. Impact wrench just had them spinning so went back to using the hex wrench in the end of the bolt but still didn't have any luck, and that was after soaking them PB Blaster. Yeah you're right, it was hard to do without removing the end-links... but based on my experience this time I would go the same route again. But you bring up a good point, although some say it is hard to get the end-links snug after removing them, if you can get them off without struggling that is probably the preferred route.
Old 05-15-2007, 06:30 PM
  #56
Sound-Mind's Avatar
Oh 1 note for TL-S owners trying this DIY, the Helms manual says you should remove the rear shelf and not the rear seat to get to the rear towers. I went the rear seat route anyways b/c it is actually easier to remove. About a 5 minute job if you have done it before. You will just have to use a short extension to get up over the cap and under the shelf but it isn't really a hard thing to do by any stretch of the imagination.
Old 05-16-2007, 10:06 AM
  #57
Itch71's Avatar
The good thing about removing the seats is that you get to clean up all the stuff the kids drop down there at the same time....usually not a pleasant thing to do, if you let them eat in the car!!
Old 11-27-2007, 11:20 AM
  #58
CL-S_undance Gold's Avatar
fantastic post-thanks for the detail and time you took to share this info with others.
thanks drop looks great!
q-how low did u go front and back?
Old 11-27-2007, 02:08 PM
  #59
140,000 miles young
underst8's Avatar
NiteQ great DIY I am going to use it this weekend. Question - somebody asked this earlier but it wasn't answered:
Did you cut the bumpstops, leave them in as is, or take them out completely with the bilstein dampers (which I will be using)? I ask because I need to know and I have heard that bilsteins have internal bump stops so I may not need the oem one with them??? Pls help Thanks
Old 02-08-2008, 03:38 PM
  #60
ridin slow'n'low
smokendsm's Avatar
Installed my coilovers thanks to this guide! awesome writeup!
Old 02-19-2008, 01:21 AM
  #61
Advance
gc86's Avatar
wheres the pictures
Old 07-09-2008, 07:37 PM
  #62
MystaNyce's Avatar
^^ Where are the pictures?
Old 07-09-2008, 07:38 PM
  #63
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,766 Likes on 1,230 Posts
Gone since it's a four year old thread?
Old 10-25-2008, 12:13 PM
  #64
Adventurist.
NiteQwill's Avatar
I asked the mods to change accordingly, here is the new reformatted PDF file:
http://dl.getdropbox.com/u/102381/DI...%20Install.pdf
Catfisha (11-27-2012)
Old 10-30-2008, 11:39 AM
  #65
Trust Me I'm Better!
5thgen's Avatar
Where's the best place to get a hold of these Bilstein's and H&R Springs? Does Excelerate sell them?
Old 10-31-2008, 02:49 PM
  #66
9th Gear
Stealth Mode's Avatar
Dropped CL
What was the final drop in inches?
Old 11-23-2009, 08:32 AM
  #67
Not 4 Wheelin Anymore!
womey's Avatar
This is such a great thread and DIY I wanted to bring it back from the dead! I installed my Pro Kits and Koni Yellows on Saturday and everything went smooth. The only thing I changed because I hate messing with End Links is that I took the Sway bar bracket off and unbolted the Sway Bar bushing brackets. This allowed enough play to shimmy the rear shock/spring assembly out. Also, I forgot to cut my bump stops but so far it rides really well (all shocks set to soft). Also, NiteQwill says it's a two man job, and I wish I would have had someone help (I'm hard headed like that).
Old 06-03-2010, 12:22 PM
  #68
PDGCLS01's Avatar
Well I was hoping to use this but both links are dead, i open them and get nothing...any help?
Old 06-03-2010, 03:05 PM
  #69
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,134 Likes on 4,804 Posts
Pull the back seats out, button cushion first (lift up on the front lip, gently). Unbolt the center console (4 bolts total), unbolt the rear seat cushion (bolts located at the bottom the seat), lift the seat up towards the rear glass, it will slide up. Carefully pull it out of the car (its easy to scratch up the interior panels at this point).
You will be able to see the top hats for the shocks.
Where are you located?
Old 07-09-2012, 12:58 PM
  #70
@Mikeshlong On IG
mikebikelife's Avatar
I know I know , thread revival.
I cannot get the backseats out.
I have the rear center console out already.
It seems at though there are some sort of cables holding in my rear bottom seat cushion. like maybe a sensor or something. It's driving me absolutely crazy, I'm trying to install my coilovers tomorrow and if I can't get the rear bottom seat out I don't see this happening.
My buddy Steven is helping me tomorrow with the coils, so its not gonna be a problem he is very mechanically inclined. (Motor swap/auto to mtx swap) in his car.
Old 07-12-2012, 03:18 PM
  #71
aznboi2424's Avatar
Just pull hard and up at the front end of the seat.
Old 07-13-2012, 02:44 PM
  #72
civicdrivr's Avatar
The seat back goes straight up to unclip it, then you can squeeze it out of the car.
Old 11-27-2012, 05:19 PM
  #73
Hot Ass!
Catfisha's Avatar
WOW NiteQwill....that's so detailed!!! If only I had an air compressor and impact tools.....
I'm also glad you put the before and after picture; my car sits exactly like the before picture, and it drives me crazy!!!
Old 11-28-2012, 07:09 PM
  #74
aznboi2424's Avatar
I got an impact wrench for you
I mean
Old 12-05-2012, 11:42 AM
  #75
Hot Ass!
Catfisha's Avatar
I mean
Old 12-05-2012, 12:01 PM
  #76
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
I mean
Yeah, chicks dig guys who listen to Taylor Swift
Old 12-07-2012, 03:47 PM
  #77
aznboi2424's Avatar
I'm just being myself. I think chicks dig that though. Plenty of girls at her concerts too.
I like Taylor, I'm not ashamed of it.
Old 12-13-2012, 11:42 AM
  #78
(Mid-Atlantic)
Old 06-26-2013, 09:40 AM
  #79
DaFunk_80's Avatar
Hey - The links to this DIY PDF are all dead. I can't find a working link anywhere. Can someone please re-post?
Old 06-27-2013, 05:24 AM
  #80
Oldsman71's Avatar
The link in the very first post is not dead. I just checked it. It will come up in a separate window, and is very detailed and makes this job a breeze.
Quick Reply: DIY: Springs & Shocks (And how to remove rear seat)
