Old 07-30-2009, 10:39 AM
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
well i bought a 6spd so my parts will be in the bm next week,
Old 08-07-2009, 12:30 PM
8th Gear
nex1685's Avatar
just put in both switches, thank you for the post, i am a mechanic and this made it easy for me to find problem and repair
Old 08-11-2009, 10:04 PM
CUCU28's Avatar
I did this today, it was easy, i can notice a small difference, it does feel smoother, nothing major. I would say i could have done without this , maybe the previous owner of my tl did this before i bought it ?? Who knows
Old 08-12-2009, 10:26 AM
8th Gear
nex1685's Avatar
thank did this last night and also changed atf
noticed a great differance
04 tl 5at
just got car 2 weeks ago went back to dealer about transmission
and did it myself they said nothing wrong
i am a auto tech so was able to do job
thi acura forum has really helped
thank you all
Old 08-28-2009, 04:45 PM
Team Nighthawk member
MaFreCoLa's Avatar
05 TL 5AT here with 89K miles. So far, the tranny's been flawless. I have been hearing a little whine but no shuddering or held gears. I'll be changing out the sensors this weekend along with the 3x3 change.
Old 08-30-2009, 11:40 PM
got a set for sale in the BM if anyone is doing this soon
https://acurazine.com/forums/car-parts-sale-361/3rd-4th-gear-t-transmission-sensors-04-06-tl-washers-acura-atf-741527/
Old 09-29-2009, 11:46 AM
  #47
MaFreCoLa's Avatar
Thank you sixsixfour and thank you Acurazine. Because of this thread, it only took me 15 min. to complete this job.
Old 10-10-2009, 02:30 PM
redlinin616's Avatar
Does anybody know if this is different for the 07 TL-S auto tranny? Thanks in advance.
Old 10-10-2009, 02:46 PM
  #49
Majofo's Avatar
It is, but the 07-08 TL / TL type-s AT's are a tweaked trans from the 03-06 MDX. I did the swap on my '03 X. You guys have 2 - 4th gear pressure sensors on top of the case, which means you have to remove the intake duct from the throttle body & airbox to gain access. The MDX only has 1 - 4th gear pressure sensor on top, which is a testament to their function to maintaining appropriate line pressure to prevent excessive low pressure wear. You might also have to remove the battery. It shouldn't be that much more complicated though. You can check out my DIY link that I made for the MDX.
'03-'06 MDX - 3rd & 4th Gear Transmission Switches / Sensors DIY
Old 10-10-2009, 05:48 PM
  #50
Mistuh DRiiVA
maddsiick's Avatar
Its amazing how easy this was, it took about 30 minutes total to do this and the acura dealership was charging around 500 to do this work. This writeup is amazing. We just did this on a TL with 121,000 miles on it...it was long overdue.
Old 10-11-2009, 10:28 AM
  #51
So would I be changing 2, 4th gear sensors and 1, 3rd gear? Also are the part numbers that would be needed the same as the ones in the mdx thread? And finally, does the TL-S tranny have a filter that can be replaced? Thanks again!
Old 10-11-2009, 11:12 AM
  #52
Majofo's Avatar
Yes - (2) 4th gear pressure sensors & (1) 3rd gear pressure sensor
28600-RKE-004 x 2
28610-RKE-004
Yes - but unless you're able to drop the whole AT case, you can't change it out because it's internal to the housing.. unlike 04-06 TL's which are on the external area of the case. Just change out the ATF on accelerated intervals to prevent the filter from clogging.
Old 10-13-2009, 03:37 PM
  #53
8th Gear
arrancarTL's Avatar
Talking
Wow!
AFTER READING ALL THIS AND FROM WHERE IT ORIGINALLY POSTED I HATE CARS, I WONT HAVE TO DO ANYMORE RESEARCH. THIS IS AN EYE OPENER FOR ME. LIKE MANY OF YOU AGREE PREVENTING IS A LOT CHEAPER THAN REBUILDING OR PAYING 500 DOLLARS AT THE ACURA SERVICE CENTER.
MY 04 TL HAS 71K THIS WILL BE A GREAT INVESTMENT.
I DONT HAVE TO THINK ABOUT TWICE.
THANKS
Old 10-14-2009, 10:09 AM
  #54
Thanks for those part numbers! Did a 3x3 at 45K on my 07 TL-S and she runs soooo much smoother. I only did a drain and fill the first time around 22K but will prob be doing a 3x3 from now on. Didnt take too long anyways, the first one already takes the most time removing the splash panels, etc. Will order these pressure sensors now and install when I get them...I love this site!
Old 11-29-2009, 06:14 PM
  #55
AM To WDP In My Garage
acura_dipset_tl's Avatar
Awsome write up, i need to do this to my car.
Old 11-29-2009, 08:33 PM
  #56
rolan04tl's Avatar
This seems like great info. and the reviews are mostly possitive. I am getting ready to do this and I want to know how much should I tighten the switches. is there a specific spec or is this not an issue?
I am not adept at mechanics at all but this seems like a simple job. And I am soooo woried about loosing a tranny I think it is well worth the peace of mind.
Thanks to the OP for the info.
Peace,
Rolan
Old 11-29-2009, 10:58 PM
  #57
Sid05's Avatar
I have a 04 TL 5AT I am going to get these parts tomrrow to do the switch change and 3x3 tranny flush
Can i get the latest update on what parts i need ive read bunch of forums it its giving me different part numbers..
(SO please all the part numbers for a 2004 acura tl PLEASE)
Thanks in advance
Old 11-29-2009, 11:40 PM
  #58
sixsixfour's Avatar
Thanks in advance
afaik, the part numbers I referenced were the right ones. the chart provided by Majofo shows the distinct differences in physical appearance even though spec-wise they are the same.
This should be the physical verification:
They look the same except for the flush connection.. could be a redesign for several reasons including thermal / reliability, although the actual spec is the same.
as far as for the exact part numbers I used, they are:
x1 3rd Gear Pressure Switch (28600-P7Z-003)
x1 4th Gear Pressure Switch (28600-P7W-003)
x2 sealing gasket (90471-PW7-A00)
Old 11-30-2009, 07:45 AM
  #59
gerzand's Avatar
I purchased majofo's part #'s and they are IDENTICAL in appearance to the ones that came off my 2005 TL.
Old 12-07-2009, 06:52 PM
  #60
173rd Airborne!
ACE32TL's Avatar
I just installed the new switches today and now the transmission light is flashing on the dash. Could anyone tell me what i did wrong.
Also my 04 shifts so much smoother now, and the shuddering is completely gone. My car has 74k on it, before i changed the switches my trans shifted very sloppy especially 2nd to 3rd and 4th to 5th. If anyone has those symptoms id deffinately suggest doing this.
Old 12-09-2009, 07:17 AM
  #61
rolan04tl's Avatar
Installed the switches last Sunday. To be honest it did not resolve my shuddering issue. I do notice a difference with shifting but its only third and fourth now shift a little bit later.
I also noticed my TF is pretty brownish so Ima change it as soon as I get a chance.
Do I need to change the Washers (drain plug and fill plug) for the ATF change or could I forgo this?
Thanks,
Rolan
Old 12-09-2009, 08:49 AM
  #62
Inaccurate's Avatar
Rolan,
The politically-correct answer is to use a new washer. However, I feel comfortable in saying that you can reuse the old washer for this one time.
Old 12-09-2009, 01:48 PM
  #63
rollin fattys in
tlaspecteinss's Avatar
ok i called my acura dealer to order the switches today gave them the part number given by the OP and acura dealer told they were wrong and told me the ones i needed are the ones give em by MAJOFO....
im not sure if maybe the 2g switches are the reason eveyone's trans is workin better but i would like to kno what i should order before tomorrow thats when i plan to go get them.
is there really any difference in the switch between the gen's?
Old 12-09-2009, 08:27 PM
  #64
173rd Airborne!
ACE32TL's Avatar
The part numbers for my switches are 28600-RAY-003, 28610-RAY-003, and 90471-PW7-A00. The parts guy wasn't sure what part I was asking for so he printed off a paper with a breakdown of the trans and that's where we found these numbers. Ask your service dept to print off the sheet with all the tranny parts that can be ordered for your car. My switches were listed for a 04 TL so I know it's not from the 2g.
Old 12-10-2009, 09:22 PM
  #65
9th Gear
mmyers300's Avatar
Like Rolan, this didn't solve my shuddering issue either. I'm big time disappointed because it really sounded like this would fix it...
I'm changing my trans fluid next.
Old 12-12-2009, 08:22 AM
  #66
173rd Airborne!
ACE32TL's Avatar
I guess this works for some and not others. After driving my car for a year before doing the switches, I've always had the shudder going from 4th to 5th. Since the switches have been installed it's eliminated the shudder completely. If it wasn't for my exhaust I probably wouldn't feel or hear any of the gear changes. Very satisfied with the improvement and will probably change them again at 25k.
Old 12-15-2009, 12:59 AM
  #67
RTLNOOBIE's Avatar
ok we are talking 3rd and 4th gear pressure swich here. how about 1st and 2nd ? do this need to be change too?
Old 12-24-2009, 04:37 PM
  #68
TLX-S
wilztlxs's Avatar
i just bought my '04 TL with 44k miles on it, looks like i will be looking to do this and the tranny fluid too
Old 12-28-2009, 09:08 PM
  #69
Chapter Leader (Houston)
TLDude876's Avatar
I just bought my car recently with a 2 year warranty, is there anyway I can the dealer to cover the replacement of the both sensors/switches?
Old 12-29-2009, 12:09 AM
  #70
Majofo's Avatar
There isn't a 1st & 2nd pressure switch. The 1st & 2nd clutch pressure is directly regulated by the 1st & 2nd Accumulators, which is not serviceable like the pressure switches. I haven't heard of a faulty accumulators being reported though.
If you aren't experiencing rough upshifts or downshifts I wouldn't worry about it. If you are experiencing rough shifts or 3rd / 4th shudder, you can request the switches to be replaced in a professional manner. If they won't replace them.. it'll cost you $80 & about 15-20 mins of your time at most.
Old 12-29-2009, 05:56 PM
  #71
i just got this done today along with a 3 times 3 Oil change. feels alot better
i paid $120 plus tax for the pressure switches
paid $72 for 9 quarts oil tranny fluid and only $50 labor for the tranny oil change and the changing of the 3rd and 4th pressure switches.
Old 12-29-2009, 06:00 PM
  #72
173rd Airborne!
ACE32TL's Avatar
did the dealer charge you $120 plus tax for the switches? seems a little high.
Old 12-29-2009, 07:08 PM
  #73
yeah $60 each
Old 12-29-2009, 07:15 PM
  #74
TLX-S
wilztlxs's Avatar
yeah $60 each
they were only $35 each for me
Old 12-29-2009, 08:16 PM
  #75
173rd Airborne!
ACE32TL's Avatar
yeah $60 each
yea sounds like they got you lol. i paid $40 bucks each so its not that much more.
Old 12-29-2009, 08:42 PM
  #76
TLDude876's Avatar
Where did you guys get em for $30 and $40?
Old 12-29-2009, 08:52 PM
  #77
yeah i guess that balances for the cheap labor. lol oh well
Old 12-29-2009, 09:01 PM
  #78
dwb993's Avatar
Kaleb Cunningham from Hansel Acura.
kcunningham@hanselauto.com
Tell him you're from Azine.
1) 28600-RAY-003 SWITCH ASSY., AT OIL PRESSURE (TEXAS INSTRUMENTS) Quantity:1
2) 28610-RAY-003 SWITCH ASSY., AT OIL PRESSURE (TEXAS INSTRUMENTS) Quantity:1
3) 90471-PW7-A00 GASKET (10MM) Quantity:2
Here's the prices you were asking for:
1 & 2) $35 each
3) $1.75 each
dipset, didn't I send you this info earlier? Why did you take it to the dealer? What dealer did you use?
Old 12-30-2009, 09:31 AM
  #79
1 & 2) $35 each
3) $1.75 each
No, I did ask you for the prices on these in a different thread but I didn't receive an answer.
No biggie though.
I bough the switches at Norris acura west and got the ATF and the switches put in by a local mechanic.
Old 12-30-2009, 09:44 AM
  #80
No biggie though.
My mistake you did mention that they were around $35 but I don't think you told me where to get them from.
