2004 Acura TSX CarPC
Old 10-31-2012, 02:42 PM
demitrix's Avatar
So, I'm a little behind on posting this. A big chunk of my project is already done and I got excited and forgot to document a lot of it. Just made some changes and got excited again and decided to finally post.
Stock photo of dash for reference.
Test fitting LCD fab. 3/4" MDF
More testing and a bad cut on the left.
Countersinking front of Lilliput monitor casing.
Bondo and wood filler to fill in my mistakes.
Primered.
Di-noc.
Final product. Small gap on the left but this was my first interior fab project.
Audio equipment.
Original setup.
Onboard audio -> Car2PC -> HU
From the headunit everything went to stock speakers and the rear deck was removed to be used as high level input for a Rockford Fosgate Punch 500aII into an Atomic Manhattan 10" subwoofer. The amp/sub were a basement bargain from a friend.
Unfortunately about 2 weeks ago my amp died. Which jolted some life back into the project. New audio setup will be as follows.
Asus Xonar DSX -> Rockford Fosgate R600-5 -> 4 x PPI A2.65C component speakers / 1 x Atomic Manhattan 10" subwoofer.
I haven't wrapper the box yet and excuse my messy trunk. There are two trim pieces that insert along the sides to make the entire box flush across the back.
Mounting of PC (amp was mounted on opposite of the PC but the new one will be much larger and will be mounted on the back side of the box.
Old 11-17-2012, 01:34 PM
the OC, southern cali
949's Avatar
very nice. will you be hooking up extra sensors.
Old 11-24-2012, 02:46 PM
demitrix's Avatar
I do plan on adding an OBD2 scanner sometime in the future to read OBD info on the pc.
Old 11-30-2012, 02:05 AM
CGP Ebony
xenonhid's Avatar
Props for the custom fabrication mang! But not a fan of the location but can't really do much with our head unit anyways.
Old 12-07-2012, 12:09 AM
frodox's Avatar
the head unit you can do custom install. i have seen it on youtube
Old 10-27-2013, 12:03 AM
Nessquest's Avatar
Nice.. is it touch screen?
AndrewS
19
03-14-2024 06:59 PM
jriv7
05-08-2020 05:50 PM
jamestheunderdog
07-19-2016 07:58 PM
Heyzuez20
10-14-2015 07:18 AM
Gianni Formica
09-07-2015 08:28 PM
Quick Reply: 2004 Acura TSX CarPC
