Swapping hondata reflashed 06 ecu to 07 tsx!
Old 10-02-2010, 02:48 PM
stellarsteve90's Avatar
I'm on the verge of trying this out!Has anybody ever tried this without any ill effects?I know the only thing i would lose is the TPMS system but thats not a big deal to me....
Old 10-02-2010, 09:08 PM
Jimmy The Saint's Avatar
The part numbers are completely different - you lose more than just TPMS. There will be all sorts of other problems. Call your dealer and ask for the part numbers for an 06 ECU and an 07 - it will take you 5 minutes. Unless you plan to swap the entire engine - no dice.
You can't just swap it and expect the computer to work. Unless you don't care about all sorts of weird warning messages and CELs coming on you are out of luck.
Besides, if it were this simple, HONDATA would just offer an ECU swap and double their customer base.
Old 10-02-2010, 11:06 PM
feuss2's Avatar
What do you mean by "all sorts of other problems"?
We know they changed the processor in the 07/08 ECU's - who is to say all the other sensors, signals, etc are different?
And as for having to swap the whole engine? Where did you get that from?
Besides the fact that the part numbers for the ECU's are different, do you have any actual facts to back up your last post at all?
Old 10-03-2010, 07:38 AM
My thoughts exactly....I know there have been guys that already swapped the 05 ecu with the 04 n they haven't reported any weird effects...
Old 10-03-2010, 03:50 PM
feuss2's Avatar
Please let us know how it goes when you try it!
Old 10-03-2010, 04:49 PM
go ahead and try it. There are countless threads about this - try searching.
The encryption between the 2 ECUs are different. But go ahead buy an 06 and plug it in - be curious if the car even starts
Old 10-03-2010, 08:06 PM
Did that an didn't even find any that someone actually tried it!...Until i find proof that someone tried it an it didn't work,i think i might just try it myself once i get ahold of an ecu...
Old 10-03-2010, 08:57 PM
feuss2's Avatar
Really? Enlighten us...
(Don't forget to back it up with facts - 2nd time asking...)
This is a true statement that proves nothing!
BS!
What messages and CELs should be expected?
Where did you get this from? The customer would have to buy the ECU (list price is $579) and have the dealer set everything up to work together (at least 1h of labor - my dealer is charging $110/hr now...), then send of the key, immobilizer and ECU off to hondata. Considering the reflash is $295 now for the other cars, this is a relatively expensive option for the same gain.
Can't find one with results. What kind of encryption are you talking about? Are you talking about chip key/immobilizer/ECU communication? Please post a link to where you got this info. Even if there is something different, a few more '06 parts might get things going...
Old 10-03-2010, 09:18 PM
StealthTSX's Avatar
I totally admire your willingness to give this a try & if you are able to complete this ECU swap you will be a hero!
There are some risks that haven't been mentioned. If the wiring harness is that different, you could cook the 2006 ECU or some devices in the car once you plug it in and connect the battery.
You really should study the wiring diagrams of both the 2006 TSX and the 2007 TSX to see what the differences are.
I would also try to unplug as many devices as possible when 1st plugging in the 2006 ECU. ie, stereo, navigation, factory alarm, ABS module, VSA module, etc, etc.
Go to "minimum configuration" on your car to avoid cooking any of those modules.
I don't want to dissuade you but if it was easy, Hondata would've already done it & simply sell 2006 TSX ECU's with the reflash already in for 2007-8 TSX's.
The immobolizer module is fairly cheap new from Acura so don't let that hold you back but if you buy an ECU without the matching immobolizer & key, the car will not start, only crank, & will need to get it to the dealer to program the RFID/chip keys.
Research, plan & proceed carefully....
Old 10-03-2010, 09:52 PM
Fesus- obviously you believe it can be some done so go for it.
People on this board have been talking about it for years yet nobody
Has ever done it. That tells me its not possible, but you seem to think we are
All just idiots. So do it man. Buy the ECU and have at it.
Doesn't take more than 5 minutes to swap what are u waiting for?
you could put hondata out of business. - cause obviously they tried
this but determined it wouldn't be good business sense to
Add that heavily requested product to their lineup.
Old 10-03-2010, 09:58 PM
StealthTSX's Avatar
You are not contributing to the technical discussion here.
Keep it technical, keep it accurate, keep it friendly...
Old 10-04-2010, 11:58 AM
Part numbers:
RBB-A04 & A05 - 06 TSX
RBB-A59 & A61- 06 TSX Auto
RBB-A71 - 2007 TSX Auto
Old 10-04-2010, 04:36 PM
Just got done checkin around on a acura oem store website an all of the part numbers on sensors an wire harnesses are the same for the 06 an 07 models except for 1 thing-instrument panel harness...Wonder if that has something to do with the added wires for the TPMS system...So from what i gathered it looks like they 06 an 07 models use all of the same sensors an harnesses but just a different ECU an the added wires an sensors for the TPMS system...
Old 10-04-2010, 05:08 PM
also compared the 04 an 05 models an there were a couple different part numbers for the wire harnesses an guys still did a ecu swap in there cars.HMMMMM!!!..
Old 10-04-2010, 07:57 PM
feuss2's Avatar
The TPMS is probably communicated via CAN. The panels is probably different because it does something to make an indication based on these messages.
If anyone will get this to work, it's you! You've already done more than any of the slackers that just posted about this and hoped that someone else who did it would hand them the answer...
Old 10-04-2010, 08:10 PM
You should call Hondata. It can't hurt, if anybody knows the answer it's
Them.
Old 10-04-2010, 09:53 PM
Surely tho alot of guys did that already an they will prolly say the same old thing that it prolly won't work...I mean why can't they give us at least an explanation why it won't work rather than just give us a straitforward answer an then just leave us guys hang!...with my research i'v done so far its looks like there would be a big chance that it would work!....Damn,i just need to get ahold of a 06 MT ecu once!...
P.S....I'll send them an email about it tho an just see what they say...
Old 10-04-2010, 10:23 PM
MrOtocinclus's Avatar
^ Probably a liability issue, they don't want to say anything just in case it doesn't work and you sue them for "misleading" you.
Old 10-05-2010, 09:05 AM
So would you need some kind of adapter for that?
Old 10-05-2010, 09:12 AM
bunch of ECUs on Ebay but they are all for AT
Old 10-05-2010, 11:34 AM
Don't know i highly dout it tho!The 04 an 05 models have different instrument harnesses too an guys did the swap without an adapter....
I know i saw that...i'm gonna try keep checkin ebay every day till i find one for an MT....Don't wanna buy a brand new one their way too expensive for a project like this....
Old 10-05-2010, 08:41 PM
feuss2's Avatar
car-part.com
Old 10-06-2010, 11:14 AM
StealthTSX's Avatar
I did some poking on www.AcuraOEMparts.com also.
The immobolizers are different p/n's btwn 2006 & 2007.
39730-SDA-A11 IMMOBILIZATION UNIT 2006 TSX 44.92 33.69
39730-SCV-A01 IMMOBILIZATION UNIT 2007 TSX 74.92 56.19
I would plan on getting a 2006 immobilizer also. A 2006 matched key, immobilizer & ECU out of a wrecked TSX would be ideal but hard to find.
So disconnect the battery, disconnect as many items as possible, Nav, stereo, VSC, ABS, etc..
Temporarily plug in 2006 immobolizer. Temporarily plug in 2006 ECU. Connect battery, turn key on.
The cluster should power on & light up. The car will not start but it should crank.
Perhaps at this point, plug in the orginal ECU & immobolizer & start the car to make sure all is still ok.
Then start plugging in the disconnected components in one at a time. You are going to need a OBDII code reader to clear any codes but these are cheap and everyone should have one anyway....
Old 10-06-2010, 11:25 AM
Thanks for ur help Stealth!I was plannin on gettin a immobolizer an i have a spare key layin around so i'll just use that when i get it synced....All of the gadgets(Stereo,VSC etc.)plugs should be rite underneath the dash(driver's side),right!?
Old 10-06-2010, 11:43 AM
StealthTSX's Avatar
The ECU & immobolizer are easy to swap as you likely know...
http://www.hondata.com/tsx_ecu_removal.html
As for unplugging the various devices, I'm not sure. You may have to unplug them right at the device.. (the ABS under the hood for example).
Or dig around under the dash to unplug them.
Or you could find the fuses corresponding to them & pull the fuses.
You really should be studying a wiring diagram before trying this swap. Perhaps one of the connectors right at the ECU is simply for all the external devices???
Perhaps some of these devices are not even connected to the ECU??
The wiring diagram will tell you this.
Once the ECU is swapped & all is looking ok, you will have to take the car to the dealer.
Either tow it or re-install the original parts, drive it to the dealer & then swap in the 2006 parts at the dealer & have them configure the keys there.
Then the car should start & run.
Old 10-06-2010, 07:36 PM
Just found a key,immobolizer & ecu online for 275$ shipped!!Yes,exactly what i wanted!....Also ordered a service manual to study on some of the wiring diagrams...Man,i sure hope this is goin to be worth it!!
Old 10-07-2010, 04:00 PM
StealthTSX's Avatar
Nice pick up & great price.
I looked all summer for a 2006 TSX MT ECU so I could get the Hondata flash with no down time for our car. I never could find one for a reasonable price.
Some things to watch for:
- the ECU p/n. (Hondata website has the ECU p/n's.)
- the immobolizer p/n.
- there won't be any way to confirm that the key is actually matched to the ECU & immobolizer.
Where are you located Steve? If you were close, I'd be over helping you with this swap...
Old 10-07-2010, 07:40 PM
Live in Lancaster,PA...I'll try an keep u guys posted when i get the parts..
Old 10-14-2010, 04:00 PM
Update..I got my ecu today an it ended up bein the wrong one so i called them an told them bout it an they said they will give me a refund for it...he also said the 06 ecu that i wanted was sold long time ago an he couldn't figure out how i found it online cuz he thought he had put it off when it was sold...GRRRR!!
Guess i'm back to the searching mode again for awhile....
Old 10-16-2010, 09:46 AM
feuss2's Avatar
Keep looking... I think your persistence will really pay off!
Old 10-16-2010, 03:53 PM
I definately won't give up!!!
Old 10-20-2010, 11:43 AM
Does anybody know the difference from the 37820-RBB-A03 to 37820-RBB-A05 ecu...i thinkin one is for the navi model an the other non-navi....I looked around to try an find a difference an can't seem to find an answer...
Old 10-20-2010, 01:44 PM
StealthTSX's Avatar
Well I'm glad you are still working on this Steve....
From the Hondata website:
  • RBB-A04 & A05 - 06 TSX (MT)
  • RBB-A59 & A61- 06 TSX Auto
Any K24A2 TSX Manual transmission owner with the ECU part numbers :
  • RBB-A02 - 04 TSX
  • RBB-A03 - 05 TSX
Any K24A2 TSX Auto transmission owner with the ECU part numbers :
  • RBB-A54 - 04 TSX
  • RBB-A55 - 05 TSX ** New: added Jan 09 **
So the 2005 A03 MT ECU is not compatible with the 2006 A05 MT ECU.
There are a few newer ECU p/n's that Honda released for the 2006. A Honda dealer employee purchased a brand new 2006 MT ECU from Honda & it had a different suffix in the p/n than any of these. This was posted on T S Xclub.
Old 11-03-2010, 08:16 AM
UPDATE....I finally found a 06 mt ECU, key @ immobilizer that i need so within the next 2-3 weeks hopefully i can start workin on this swap...
Old 11-12-2010, 07:12 PM
Honda's wiring diagrams indicate the 04-06 ECU should drive the 07/08 TSX.
They also indicate the 04-06 ECU installed in this car loses the ability to communicate with the stock OBD II connector, so there is no way of datalogging from the stock ECU for things like drive by wire problems etc. It would require the installation of a wire from the ECU to the OBD II connector.
If someone in SoCal would like to would like to make contact with us, I could test the dual adapter harness on an 07-08 fairly quickly with an 04 ECU.
This is from a guy that works for hondata...
Is he sayin that since there is no communication between the ecu to the OBD II connector that i would have drive by wire problems?...
Old 11-14-2010, 11:13 AM
feuss2's Avatar
I took it as additional wiring would be necessary...
Old 11-15-2010, 06:54 PM
neoryan7's Avatar
Hes probably talking about the K-line which is used for communication with the OBDII port. It might have moved to a different pin location in the different years. I have a dual harness for my accord and had to add the k-line pin to the ODBII port.
Old 12-08-2010, 12:53 PM
916PWP's Avatar
Any luck so far? Updates?
A for effort.
Old 12-08-2010, 08:23 PM
A for effort.
havn't started on it yet!..have all the parts i need but just have been to busy lately with work an goin away weekends...so one these times!..i'll def. keep u guys posted!
Old 12-10-2010, 12:43 AM
04-6mt-atx's Avatar
Check K-Tuned website; it states they can K-Pro the 07-08 TSX with their new dual harness. Might be worth looking at instead of spending too much time & money for the reflash when K-Pro is back.
Quick Reply: Swapping hondata reflashed 06 ecu to 07 tsx!
