TSX Dynos
Old 05-23-2006, 01:05 AM
  #321
JTso's Avatar
Originally Posted by oemtsxparts
i tried really hard to take off as much weight as possible. For every part i replaced i weighed the stock and the new. so far i've calculated my car to be approx 3230lbs - 96lbs = 3134lbs w 207 whp dynapack
I just notice your dyno chart indicates "Flywheel Power" at the title bar. Any idea what the actual whp is?
Old 05-23-2006, 07:18 PM
  #322
Tanabe USA's Avatar
Weight savings can be had from aftermarket exhaust systems. On a vehicle like the TSX, going with a single or dual exhaust on a stock vehicle will have very little difference in power, and is more of a preference on aesthetics.
One issue with very lightweight exhaust systems is that they tend to be very loud, and carry a lot of resonation.
Old 05-24-2006, 04:00 PM
  #323
oem tsx's Avatar
all dynapack charts have flywheel power title on top
Old 05-24-2006, 04:02 PM
  #324
oem tsx's Avatar
you guys should check out my exhaust, i designed it very well with a friend of mine, more power + 25lbs weight savings
also not very loud with only 1 magna flow resonators
you may be able to copy it for mass production
Old 05-24-2006, 04:19 PM
  #325
I spend 2 much time here
jiggaman's Avatar
got pics?
Old 06-18-2006, 10:19 PM
  #326
AP1
AP1's Avatar
I would be interested to see a single vs dual exahaust comparison, but I doubt it makes much difference like rmpage has mentioned. Unfortunately, we might never find out so all the speculations remain. However, if anyone is willing to send me a single exhaust for testing, I will cover the dyno fee.
i know its apples to grapefruit, but single make a BIG diff on s2k's. but it seems to me that the stock TSX pipes flow decent enough. i am having a custom test pipe made and having the resonator removed on my stock exhaust for better flow and some growl.
i figure that combined with a DC header should make some great gains.
oh and i think i met you at that alki meet last month, i was on of the S2k guys. i think i even talked with ya, i was the chubby itailan guy with the black S2k.
Old 06-19-2006, 07:10 PM
  #327
PearlWhite05's Avatar
anyone got a dyno of TSX with aftermarket I/H/E and high flow cat.??
Old 08-10-2006, 04:06 PM
  #328
h1coupe's Avatar
I read on a british forum that the only option for us europeans to get the reflash would be to buy a whole seperate ECU with the flash on it. therefor costing 919 british pounds, that´s 1750us dollars. to me with taxes and shipping that´s some where about 2500-3000us dollars! making it totally unobtainable for 90% of would be buyers like me
Is this our only option?
I am hoping that the australians come up with the sollution but I really don´t like the idea of sending my ecu to australia and not knowing if they can flash my ecu cause it does not have the same part number as theirs if I am not mistaken?
my ecu part number is 37820-RBB-E05.
is the difference between the two cars and ecus that great that there is no way a flash for the tsx could not work for the accord?
Old 08-11-2006, 10:46 AM
  #329
Member
hondata's Avatar
The part number for the 06 TSX is RBB-A05. It may be possible to reflash the US program into the European computer, but without a computer to try we will not know.
Old 08-11-2006, 08:36 PM
  #330
h1coupe's Avatar
I will be in the states in november, going to Sema. maybe I´ll take my ecu with me if there would be a chance to go to one of your dealers and have it checked out?
Old 08-11-2006, 09:14 PM
  #331
CL9 ABP
lcrazyaznl's Avatar
Word is today i dynoed my car at e-shift.
Got the same 175 hp actually lost power from that burned air and fuel ratio sensor. Mike told me it screwed up the spark plugs, and the lines are probably dirty cuz the car stuggled every pull.
So removing the grounding kit and 2 bottle of octane cleaner.
Then replace all 4 spark plugs should see some results hopefully...
Old 08-11-2006, 11:11 PM
  #332
CL9 ABP
lcrazyaznl's Avatar
Okay so i removed the voltage stabilizer that i had, and the grounding kit. It seemed that its been bottlenecking the car from mid range - redline.
I noticed i lose the smooth thottle response in the lowend and we put it in my friend's xa.
He gained low end and thottle reponse. His car actually sounds like its working a bit different.
So yea T1R grounding kit and voltage stab has is flaws. It should be one of the many factors holding my car back.
I last dynoed it at 175hp with a bad air and fuel ratio sensor. So hopefully it actually show some power next week.
Old 08-12-2006, 05:18 PM
  #333
h1coupe's Avatar
where would be the best place for me to bring or send my ecu for testing?
Old 08-13-2006, 11:48 AM
  #334
Member
hondata's Avatar
All testing is done at Hondata headquarters in Torrance Ca. Hondata will be at Sema, so you may bring the ECU to us there.
Old 08-13-2006, 05:17 PM
  #335
Time to Climb
godfather2's Avatar
Where The Helk Can I Get A Dyno Done In The Tampa, Fl Area? PLEASE PM ME WITH ANY RELEVANT INFO. THANKS.
Old 09-17-2006, 02:05 AM
  #336
psykotik's Avatar
anybody with a 06 AT with i/h/e/reflash/pulleys?
Old 09-17-2006, 12:22 PM
  #337
PJS
PJS's Avatar
There is another issue involved in buying the US reflashed ECU - we lose the immobiliser function/feature.
So, the only potential option is to take your ECU to SEMA and see if the guys can hook it up, read it, and reflash it.
I wouldn't imagine there's much difference between the ECUs aside from the immobiliser on the European Accord.
Old 09-17-2006, 12:45 PM
  #338
Reach's Avatar
You realize we have an immobilizer on the TSX right? When getting the reflash you have to provide hondata with your immobilizer, so I can't image anything you're "losing" along the way. In fact, I believe the whole reason they need it is to get the ECU to initialize (authenticate) with key and immobilizer.
Good luck to you Euro guys, it would be cool if our reflash worked for you as well.
Oh, and to psykotik maniak, I'm working on it.
Old 09-17-2006, 06:21 PM
  #339
psykotik's Avatar
me to.. i want to see some dynos on that
Old 09-24-2006, 07:14 AM
  #340
CL9 ABP
lcrazyaznl's Avatar
this is the dyno i took in toronto.
a before dyno ill try to scan later if i find it.
THe dynos before had some issues with the sensors and spark plugs.
IT turns out all us AT got around 175.
Old 09-24-2006, 08:07 AM
  #341
moda_way's Avatar
Here's my run...
Comptech I/H/E, Hondata IM Gasket and Reflash, TB Coolant Bypass and K&N drop in filter instead of the Comptech Foam one.
Old 09-24-2006, 10:23 AM
  #342
Time to Climb
godfather2's Avatar
^ damn, i thought you would've cracked 200 whp by now! what gives?
Old 09-26-2006, 12:44 AM
  #343
T.DoT P.I.M.P. lol
chuson's Avatar
I will post my dyno after, but as lcrazyaznl said, all of our 5AT got similar result.
I have done the following: DC Header, Injen CAI, Magnaflow High-flow Cat, UR Pulleys, Sun Automobile Voltage stabilizer and Grounding Kit.
Surprisingly, a 5AT with a Short Ram and a Greddy Evo2 exhaust has 170whpand 13Xtq.
Old 10-15-2006, 03:39 PM
  #344
h1coupe's Avatar
just dynoed my car.
it is a 06 Euro Accord type-S, 6MT, with K&N typhoon cai, and ebay stainless steel header.
I got pmax 150.1kw(201.3hp), pwheel 127.1kw(170.4hp)@6770rpm, and Mmax 224.7NM(166ft.lb)@4300rpm did not get @wheels torque rating?
everything seems about right for the stock car beeing 190hp@6800rpm and 223NM@4500rpm. some gain at least
next we´ll see if the geniuses at hondata will be able to reflash my ecu, I´ll be going back to a dyno once I get back from the US, if they manage to reflash it?
sorry but I don´t have a scanner so I can´t post up my dyno graph.
Old 10-15-2006, 04:05 PM
  #345
A Commuter
nahooneyya's Avatar
dynoed my car couple weeks ago before going down to cali to get Hondata..
I just had K&N Typhoon CAI and my car dynoed at 167 WHP~
Old 10-17-2006, 02:54 PM
  #346
Endless-Whitetsx's Avatar
HAHAHA CHUSON dont be suprised its the owner that makes it go faster.. (driving habits)
Old 11-07-2006, 04:13 PM
  #347
TodaSi's Avatar
just dynoed my car.
Hopefully you're able to do this, good luck
Let us know how it goes!
Old 11-25-2006, 03:35 PM
  #348
A DiRTBAG decal on my
TSX2345's Avatar
I just got off the dyno below are the results:
Mods:
'06 TB + bypass
'06 IM
Comptech Icebox + K&N Filter
UR Pulleys
Hondata IM Gasket
Power Rev Racing Gasket
Hondata Reflash
Old 12-01-2006, 01:10 PM
  #349
kai!
n1ke5h's Avatar
Does anyone have a dyno for an '06 TSX MT, stock and/or with aftermarket parts?
Old 12-13-2006, 11:38 AM
  #350
Reach's Avatar
I'm copying this here because I was looking for it and it took me a while to find it.
2006 6MT baseline dyno (completely stock) by member "jpt" on a Mustang dyno, 4th gear, SAE corrected:
He made this chart in excel based on the data provided. Link to his original post.
Old 01-13-2007, 10:00 PM
  #351
kwjustin89's Avatar
my 5AT with Injen CAI, Topspeed header, GReddy Evo 2.
Old 01-24-2007, 10:03 PM
  #352
is glad to be back!
tsxdriver's Avatar
gonna go on the dyno for the first time on friday. i'll post my results as soon as i get them.
Old 01-25-2007, 12:11 AM
  #353
is glad to be back!
tsxdriver's Avatar
i mainly wanna see if the single tip exhaust makes a difference or not compared to duals
Old 01-26-2007, 09:36 PM
  #354
is glad to be back!
tsxdriver's Avatar
man i don't know.... just got back from the dyno and i'm kinda shocked.... 173HP,158ft/lbs.... does that sound right?
Old 01-26-2007, 10:40 PM
  #355
Bye TSX, hello domestic?
xizor's Avatar
was that on a dynojet? seems kind of low, my 2004 did 175whp on a dynojet with only a K&N CAI. Your 2006 w/ intake and exhaust (not sure if you have pulleys or header) should do a bit higher
Old 01-26-2007, 10:52 PM
  #356
is glad to be back!
tsxdriver's Avatar
yeah that's what i was thinking... this was done on a dynojet. i have intake,exhaust, and reflash.
Old 01-26-2007, 10:56 PM
  #357
Rep'n Taxbrain.com
Tsx536's Avatar
Do you have a copy of your dyno to post? Yeah the numbers do sound kinda low but it also depends on what type of dyno you're on. Did you by chance do a baseline dyno?
Old 01-26-2007, 10:58 PM
  #358
xizor's Avatar
well the reflash doesn't give any peak HP anyways. don't get too caught up in the peak number anyways, its the whole curve that matters
Old 01-26-2007, 11:14 PM
  #359
is glad to be back!
tsxdriver's Avatar
no i don't have a baseline dyno
wait a minute... my ft-lbs. isn't 158.... wtf....
Old 01-27-2007, 02:21 AM
  #360
JTso's Avatar
The way the chart is scaled makes it hard to read. Ask for the dyno file and send it to me.
Quick Reply: TSX Dynos
