TSX Dynos
Old 04-20-2005, 11:16 AM
  #201
Audi Driving Snob
TinkySD's Avatar
Interesting. Exhaust on it's own hasn't been proven to affect dynos more than a negligible amount, but headers have. I'm wondering if hondata affects this some how.
Old 04-20-2005, 11:46 AM
  #202
I spend 2 much time here
jiggaman's Avatar
so who has posted the best dyno so far?
Old 04-20-2005, 11:56 AM
  #203
JTso's Avatar
Since the posted results are from different dynos, the more meaningful numbers are from our own before and after results. I gained about 30hp and 15tq at 6000rpm range.
Old 04-20-2005, 11:57 AM
  #204
Photography Nerd
Dan Martin's Avatar
Comparing dynos is pointless since there are so many variables to consider:
-manufacturer/type
-location (altitude)
-temperature/humidity
-calibration
A stock TSX on a poorly calibrated dynapak dyno at sea level on a dry -30° day could probably put down 200whp. Then you could get someone in the middle of summer in CO on a mustang dyno put down 150whp.
The only thing you should look at is the difference between runs on the same dyno preferably on the same day.
Old 04-20-2005, 12:05 PM
  #205
Audi Driving Snob
TinkySD's Avatar
I agree fully with your statement about the different dynos. I'm just wondering if one wouldn't expect a slightly different change to the torque curve.(it's hard to tell if your improvement under 3k is due to the headers or that he wasn't full on the throttle until that point)
anyways, I still want to see a dynojet of someone with comptech i/h and hondata to see how the torque curve compares!
Old 04-20-2005, 03:55 PM
  #206
tekn0mage's Avatar
I'm going to add a header, possibly Comptech in the new few weeks/months. I'll definitely get it dyno'd again. I do anticipate that making a good jump in horsepower. By doing so, I can still free up some lost potential in the Hondata reflash due to it being optimized for a header. Combine that, with actually adding a header for its gains alone, and I am hoping there is around 10 whp to be gained, peak.
As far as who has the best dyno... I nominate me :-D
Old 04-20-2005, 04:01 PM
  #207
Audi Driving Snob
TinkySD's Avatar
From vtec.net on an accord 2.4 comapro: http://www.vtec.net/articles/view-ar...ticle_id=80004
Note: Interpreting dyno charts - Dynapack runs are somewhat different than Dynojet measurements. In particular, the Dynapack loads up the engine for a second or two before making a measurement run. This leads to somewhat high torque numbers at the start of the run because the engine is making maximum output without accelerating, which means there are no accelerational losses to speak of. Its a minor factor for NA cars, but for automatics the torque converter will often slip and cause excessively high readings that don't correspond to actual engine output, but they do reflect real world torque at the ground.
Readings between different sorts of dynos can not be directly compared, but in general the Dynapack will read at least 10 hp and 5 lbs-ft of torque _higher_ than a Dynojet. Also note that the charts say "flywheel torque" and "flywheel power". This is an artifact of the Dynapack software. Note the "tcf" factor in the lower portion of the screen. When set to 1.00, the graphs reflect the power measured at the hubs. If one wishes to, the factor can be changed to try and estimate back to crank or flywheel outputs. I don't believe in doing this as its a rough estimation at best, introduces another source of confusion, and really doesn't tell us anything useful.
TCF on all the dynapack runs from hondata/church = 1 = hub hp and tq.
Old 04-20-2005, 04:36 PM
  #208
04 remembrance
iamhomin's Avatar
Hm, interesting.
Old 04-20-2005, 05:19 PM
  #209
n00b
vwong's Avatar
I like to think of it this way. The numbers from a Dynapack means hp and torque applied to the wheels, while the numbers from a Dynojet means hp and torque applied to the ground.
Old 04-20-2005, 05:44 PM
  #210
Audi Driving Snob
TinkySD's Avatar
this is mainly for those members, who shall remain nameless, who didnt' believe me that the dynapack was measure hub torque past all the internal engine losses as opposed to fly wheel torque.
As an aside anyupdated impressions of hondata? Still enjoying it?
Old 04-20-2005, 05:49 PM
  #211
n00b
vwong's Avatar
Yes........when I drive it.
I only get to drive it on the weekends sometimes. Occasionally week nights when my wife and I go out for dinner.
Honda should tune the TSX like the Hondata reflash from the factory.
Old 04-22-2005, 06:58 PM
  #212
Member
hondata's Avatar
Vincent's stock TSX before and after reflash:
Old 05-13-2005, 09:05 AM
  #213
LI_NY_1's Avatar
On the dyno chart above, interesting that the torque is slightly lower after the reflash in a few spots in the lower rpm range. Guess that is due to being stock. I don't know much about reading dyno charts, so perhaps those points are meaningless anyway in real world situation.
I am just recently reflashed on a 5AT, with only an icebox intake, and I could swear that there is no point where my car pulls any less now. And it clearly pulls harder not only in the higher rpm range but it also seems much more responsive in the lower rpm range too. And even before WOT.
Is it just me thinking this, because I thought I read that Hondata only modified mapping at WOT, but I seem to feel more response than before even at partial throttle.
And Hondata - was there ever a clear response (or did I miss it) about implications of using lower octane gasoline on a reflashed tsx. Doubt it will ever happen, but just want to know how serious it might be if it does happen by accident. thanks.
hondata + kindle + tsx = good, very good...
Old 05-13-2005, 09:25 PM
  #214
Moderator Alumnus
sauceman's Avatar
Originally Posted by hondata
Originally Posted by sauceman
Hondata, while you're here, can you answer this, please.
-Will the re-flash still allow me to obtain CELs for problems like O2 sensors and etc? Will it be still diagnosable for Acura dealers?
-About the increased cutoff, why is it possible, and not already done by Honda? Are there potential issues of riding the engine to 7600 regularly, and into the redline zone for prolonged times like in 4th and 5th gear? Or should we just use the extra few revs in case of it really being needed only, like on the occasionnal drag race, but not more?
The ECU functions normally as far as CEls and dealer servicing. No changes were made here.
Why did Honda not lower the VTEC point and do the tuning we did? To get the exact answer you will need to ask them.
In general, the ECU is tuned for worst case scenario - poor fuel and poor maintenance. Users of the reflash are expected to use high octane and look after their cars.
Honda may have limited the performance in this model to enable a bigger HP upgrade in a future model.
The increase in rev limit is only small - 300 rpm. We do not believe it will have any adverse effect on the engine's life. Do not bounce your car off the rev limiter. That is much harder on the engine, even with a 7300 rpm limit.
Add this comment:
You may (or may not) feel some part throttle improvement at lower RPM under 3000 rpm. For everything else, only WOT was optimised (about the last 20% of throttle)
Now, WOT = Wide open throttle = open loop mode on the ECU.
Meaning that mostly open loop mode has been optimised and closed loop has been left to stock settings. Which lead me to these conclusions:
As long as you don't WOT your car, then you should be okay, since Hondata modifications to the fuel maps concern open loop mode only.
Open loop mode is used for the most part when you are full throttle.
I remember Hondata saying in that large thread that Honda hadn't programmed their ECU as aggressive as Honda because they need to consider that some users don't take as good care of their car as they should, and would use 87 octane, whereas Hondata, with an aggressive fuel map assumes that only premium will be used.
In other words, it looks as though their revised fuel map has no provisions to retard ignition in case of knock when at WOT. So obviously, 91 octane is very advisable if you don't want to damage your engine internals.
Hondata, please comment further.
hondata, I'd still like it if you could confirm or correct my affirmations if possible please.
Old 05-16-2005, 02:40 PM
  #215
LI_NY_1's Avatar
thanks to sauceman for his proposed answers and for compiling the questions... thanks!
Old 05-16-2005, 04:27 PM
  #216
Member
hondata's Avatar
- We always recommend using 91.
- The ECU with reflash still retards ignition at full or part throttle if it detects knock
- Most of the optimisation has taken place at full throttle, but there is some ignition advance at part throttle low cam to improve response.
Old 05-16-2005, 07:11 PM
  #217
Moderator Alumnus
sauceman's Avatar
Thanks Hondata.
Old 05-16-2005, 11:52 PM
  #218
Triz08's Avatar
im going to a dyno day on May 25. Its 30 bucks for 3 runs. I have an a/t with hondata, injen cai, dc header, and comptech exhuast. I'm looking foward to getting the results. Will post.
If anyone lives in south florida area near Broward send me a message if your interested in attending.
Old 05-26-2005, 12:33 PM
  #219
Rep'n Taxbrain.com
Tsx536's Avatar
^^ Triz, Do you have the results yet?
Wow....$30 for 3 runs is cheap. Around here they want $80-$100 for 3 runs.
Old 05-28-2005, 07:56 PM
  #220
Beware of leakage
Chopsie's Avatar
Interesting Thread. I'm quite impressed on the Hondata for the TSX.
Hello from CL and OT forums
Can't wait till CT comes out with the S/C for the TSX (K20A2 ?)
Old 05-29-2005, 01:05 AM
  #221
Computer Nerd
jonnerd154's Avatar
here's my dyno - 176.38 HP | 153.5 TQ before correction.
http://tashaworld.ath.cx:10254/aw/dyno5282005/5.28.2005 dyno.jpg
Old 05-29-2005, 01:14 AM
  #222
Triz08's Avatar
the date changed til tomorrow (sunday) so ill have the dynos posted up late tomorrow
going to be pretty hot out tomorrow, just like every day down here in south florida
Old 05-29-2005, 03:50 PM
  #223
Triz08's Avatar
just got back from being at the dyno all day. Didnt even run my car yet. IM going back around 7 when it gets cooler out to run my car. 90 degree humid weather there all afternoon, hoping it drops tonight.
Alot of clubrsx is there and their turbonetics car rsx team was also there. None of them are running their cars until the end of the day, gonna be some fun.
Old 05-29-2005, 09:18 PM
  #224
Triz08's Avatar
Well finally got my runs in. Im not dissapointed with the results, but i am also not pleased. I ran the car at nighttime, it was 82 degree when doing the dyno and just finshed raining. Now what i do not understand are the torque numbers i got. Why are they so low? The hp looks about right the the torque is nowhere near what it should be. I have an AT with i/h/e and hondata. Comments appreciated.
Old 06-10-2005, 11:54 PM
  #225
JTso's Avatar
Big bore TB dyno
Here is the dyno result after the big bore throttle body mod comparing with Hondata reflash.
Old 06-11-2005, 01:15 PM
  #226
Computer Nerd
jonnerd154's Avatar
Do you have the a/f graphs also? I bet some tweaking to the fuel maps could give you even more power.
Old 06-11-2005, 03:10 PM
  #227
Photography Nerd
Dan Martin's Avatar
And how do you plan on doing that?
K-Pro isn't available yet...
Old 06-11-2005, 11:32 PM
  #228
Computer Nerd
jonnerd154's Avatar
I know, I'm just pointing out the possibilities of kpro (either via a native application, or by dumping DBW and the TCS)
Old 06-11-2005, 11:33 PM
  #229
Computer Nerd
jonnerd154's Avatar
clarification: I know I don't have to justify the kpro to anyone I'm just making notes out loud
Old 07-07-2005, 03:10 AM
  #230
Special-K
PrecyseStylez's Avatar
I dyno'd 172WHP max and 148WTQ max on DynoJet. It was 89 degrees out. And also before i drove to TurboTrixRacing, i went to fill my car up with gas..i asked for Super and the guy started putting Regular!.. it was alil over 1 1/2 gallons of Regular before i saw it!! I was about to catch a case! But i dont think that killed some horses
Old 07-07-2005, 06:52 PM
  #231
Bye TSX, hello domestic?
xizor's Avatar
pretty good dyno if you're stock like your sig says
Old 07-08-2005, 10:17 PM
  #232
Special-K
im fully stock! I will dyno again when i get intake/intake manifold gasket/Headers/exhaust/and VTC to 45 degrees and again after that with hondata
Old 09-06-2005, 10:12 PM
  #233
JTso's Avatar
Added Tanabe exhaust and Carsound cat.
Old 09-28-2005, 01:15 PM
  #234
Computer Nerd
jonnerd154's Avatar
JTso, you've still got me on torque, but I now have the highest HP. :tounge:
This is my newest dyno. The correction factor was 0.99 so if you remove the correction factor I'm putting out 193.939 WHP and 166.161 WTQ.
Old 09-28-2005, 01:39 PM
  #235
JTso's Avatar
Nice numbers! Do you have the actual dyno file? I can compare them with the DynoJet software to see where are gains are.
Old 09-28-2005, 01:55 PM
  #236
Computer Nerd
jonnerd154's Avatar
I'll have them shortly. I asked them to email them to me.
Old 09-28-2005, 01:58 PM
  #237
JTso's Avatar
Please forward the file to me as well, and I will put them together for comparison.
Johnnytso@hotmail.com
Btw, what performance mods do you have?
Old 09-28-2005, 02:04 PM
  #238
kenstyle on 20's
tsxondubs's Avatar
I wanna dyno my car so bad but i cant just yet .I think i will have around 225+ whp
Old 09-28-2005, 02:55 PM
  #239
Computer Nerd
jonnerd154's Avatar
What do you have on the car?
Old 09-28-2005, 03:03 PM
  #240
Computer Nerd
jonnerd154's Avatar
Will do. Wanna trade files?
If so, jonnerd154@aol.com .
Injen Cold Air Intake
Throttle Body Bypass
Hondata Intake Manifold Gasket
Comptech 4-2-1 Stainless Headers
Comptech Catback Exhaust
Hondata Reflash
Quick Reply: TSX Dynos
