TSX Dynos
Old 03-31-2005, 12:51 PM
  #161
Stokeless
Stokeless_TSX's Avatar
I really wanna see a dyno with a CAI, Header and an exhaust. Along with Hondata.
Old 04-01-2005, 09:48 AM
  #162
n00b
vwong's Avatar
Ok, since my site is back up, here is the dyno plot for my car. Again, it was dyno'ed at Church Automotive Testing (same place Hondata did theirs). And since I forgot to get a print out from him, but I got the raw data. I plotted them in Excel.
Old 04-01-2005, 02:55 PM
  #163
Master Graphic Artist
PixelHarmony's Avatar
I thought lift hits at 5k?
Old 04-01-2005, 03:11 PM
  #164
Stokeless
vwong's dyno is stock.
Old 04-04-2005, 08:51 AM
  #165
Moderator Alumnus
sauceman's Avatar
Originally Posted by Dan Martin
Simple solution:
-don't fix brakes
-girlfriend goes off cliff: leads to new girfriend opportunites
-now have money for hondata + playa status
I really love your schemes!
Old 04-06-2005, 10:16 AM
  #166
Stokeless
Just evil isn't it?
Old 04-07-2005, 02:22 PM
  #167
tekn0mage's Avatar
Here's my Dyno. I will post another one later today. I am getting an Injen CAI installed now. Will do two more dyno pulls once installed.
2005 TSX 6MT w/ 1980 miles
Mods: 2004 Hondatafied ECU, Comptech Exhaust
Old 04-07-2005, 07:41 PM
  #168
tekn0mage's Avatar
With an Injen CAI vs. Best run without Injen
Old 04-07-2005, 07:46 PM
  #169
Photography Nerd
Dan Martin's Avatar
Wow the injen gains are very impressive.
Old 04-07-2005, 09:11 PM
  #170
gfd1182's Avatar
does anyone know when the comptech supercharger is coming out?
04 TSX
Comptech headers, Exhaust, AEM SRI
W/Navi Nighthawk Black
Old 04-07-2005, 09:28 PM
  #171
Photography Nerd
Dan Martin's Avatar
04 TSX
Last update had it at early May.
Old 04-11-2005, 11:28 AM
  #172
Stokeless
Then when May hits it might be June. Don't hold y our breath. Just hold on tight and wait.
Old 04-16-2005, 03:12 PM
  #173
JTso's Avatar
Hondata reflash dyno
This is a pre and post Hondata reflash dyno. The only component change was the Hondata reflash.
K&N CAI
TB bypass
Hondata gasket
Hondata reflash
DC header
Stock exhaust
5700 miles
Old 04-16-2005, 03:16 PM
  #174
Stokeless
Just a fatter curve what happened to 200 whp Johnny? hehe. I bet it pulls hard at 5500 though huh?
Old 04-16-2005, 03:24 PM
  #175
yup.
kangjin's Avatar
Here's pre-reflash vs. post-reflash. I also added the hondata gasket and coolant bypass between dynos, so take that into consideration.
Numbers still seem really weak to me, might have to hop on the DC Header bus.
Old 04-16-2005, 07:44 PM
  #176
taewlee's Avatar
is your car an auto? and did you dyno at the same place as jtso?
Old 04-16-2005, 08:24 PM
  #177
yup.
kangjin's Avatar
sadly, it's a 6mt with 15.6k miles and no problems. and i dyno'd minutes before johnny at the same place.
Old 04-16-2005, 08:40 PM
  #178
Audi Driving Snob
TinkySD's Avatar
Kangjin: your before dyno is just an injen right? Regardless of your peak numbers look at all that extra torque you gained below 3k rpms! Gains like that is what make me consider this mod for my auto.
Old 04-16-2005, 08:47 PM
  #179
JTso's Avatar
kangjin, I notice your dyno curves seem to show a little hesitation. You might want to check the condition of the spark plugs, as they might provide clues to the mysterious lower number. While you have the plugs out, a compression test won't hurt either.
Old 04-17-2005, 09:03 AM
  #180
Moderator Alumnus
sauceman's Avatar
JTso, your dyno was really with only Hondata, nothing else, no TB bypass, Hondata gasket, not even CAI?
Old 04-17-2005, 11:13 AM
  #181
Bye TSX, hello domestic?
xizor's Avatar
I believe he has all of the above mentioned plus DC header.
Old 04-17-2005, 11:14 AM
  #182
xizor's Avatar
were all of your runs the same? did you rule out heat soak as a factor if the first run was the same as the last?
Old 04-17-2005, 01:26 PM
  #183
JTso's Avatar
The dyno comparison includes the following mods. The only difference is one with Hondata reflash and one without.
K&N CAI
TB bypass
Hondata gasket
Hondata reflash
DC header
Old 04-17-2005, 10:53 PM
  #184
tekn0mage's Avatar
JTso thanks for providing that great comparison. It's quite a bit of work to dyno your car at every mod. I missed my baseline run with no mods Could you tell us how many miles are on your car?
I was happy to see your numbers. Makes me think perhaps I got a little bit of a freak on my hands. Our peak is right around the same, except you have a header, gasket and tb bypass goin on. Makes me wonder what I'll peak at with a header.
My car @ 2k miles (injen cai + comptech exhaust + hondata) = peak 180.79 hp / 158.06 tq
versus your peak of 181.4 / 157.69
Just a comparison thats all not trying to prove anything... hehehe.
Old 04-17-2005, 11:37 PM
  #185
taewlee's Avatar
i wish someone would dyno with injen cai, dc header, and hondata....
Old 04-18-2005, 12:03 AM
  #186
JTso's Avatar
My car has about 5700 miles. do you have the actual dyno files? If you do, send them my way and I can plot them together using dynojet viewer for comparison.
Old 04-18-2005, 02:11 AM
  #187
tekn0mage's Avatar
yep I have the actual dyno files. Brought my little mini USB flash drive with me hehe. I'll send them your way via email perhaps?
How do you want it...
Old 04-18-2005, 09:55 AM
  #188
JTso's Avatar
You've got pm.
Old 04-18-2005, 10:05 AM
  #189
tekn0mage's Avatar
I am looking at Kangjin's dyno... I bet he ran that in 3rd gear. The numbers are a little more erratic than a 4th gear pull. My bet is that it was done in 3rd gear.
That would also explain the slightly lower numbers than par.
Old 04-18-2005, 04:47 PM
  #190
yup.
kangjin's Avatar
both runs posted were the same, ~171.2 max hp. the first run (like last time) my tires slipped around 5k and screwed up the graph.
they were run in 4th gear every time.
the before dyno is with an injen cai and fujitsubo catback. after is +reflash +hondata gasket +coolant bypass.
i'm thinking about the dc header, and maybe dynoing the current setup -fujitsubo +stock exhaust just for kicks, but the dyno fees are adding up.
Old 04-18-2005, 04:54 PM
  #191
n00b
vwong's Avatar
Exactly why I think dyno'ing on a Dynapack is better. You can really eliminate these kind of things, and get a more consistent dyno. Just my humble opinion.
Old 04-18-2005, 06:56 PM
  #192
JTso's Avatar
tekn0mage and JTso post hondata dyno comparison
Here is a comparison of tekn0mage and my dyno results. Note the A/F and how it affects the gain when it becomes rich for both dyno results. The blue is tekn0mage and the red is JTso. I have to say this is a very close comparison.
Old 04-19-2005, 11:47 PM
  #193
n00b
vwong's Avatar
Here are my dynos. Before and after Hondata reflash (in a totally stock engine).
Old 04-20-2005, 07:40 AM
  #194
Moderator Alumnus
sauceman's Avatar
I am constantly amazed at how "handsome" the Hondata power curve is.
Old 04-20-2005, 09:19 AM
  #195
04 remembrance
iamhomin's Avatar
vwong, you're only modification is the Hondata and you're getting those numbers?
Old 04-20-2005, 09:47 AM
  #196
Photography Nerd
Dan Martin's Avatar
Don't forget that dynapak dynos read a little high but the gain over the baseline numbers is quite impressive. +22 hp and +21 lb ft at around 6000 rpm.
Old 04-20-2005, 10:18 AM
  #197
dom
dom's Avatar
Yup, One of the Ricer mags dynoed a stock TSX on a Dynapack at 180WHP when it first came out. His car is putting down some nice power though.
Old 04-20-2005, 10:26 AM
  #198
Audi Driving Snob
TinkySD's Avatar
Sweet gains! I like how the torque peak after is at 3k rpms, great for daily driving.
Old 04-20-2005, 11:04 AM
  #199
Audi Driving Snob
TinkySD's Avatar
JTSO -- he just has the injen and you have dc headers and injen correct? Interesting that they are so close while he doe snot have headers. I'm wondering if a different set of headers(comptech for example) would change the results.
Old 04-20-2005, 11:12 AM
  #200
JTso's Avatar
TinkySD, he has Injen intake and Comptech exhaust, and I have K&N intake, DC header with stock exhaust and Hondata gasket.
Quick Reply: TSX Dynos
