iJDMtoy Led DRL Harness Install w/Pics
Old 04-09-2012, 07:25 PM
The Machine's Avatar
I recently bought the ijdmtoy LED DRL kit seen here: http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r3.htm
It was a pretty straight forward install even though it didn't come with any instructions, so I figured I would do a little write up for anyone looking to buy the kit and install it.
I used this video as a reference even though it's the V-Leds kit, but the ijdmtoy kit is very similar.
Here is a picture of the ijdmtoy kit laid out:
After taking off all the plastic engine trim, remove your factory halogen bulbs from the socket. The driver side is a pain compared to the passenger side, but you can do it with some patience as there is not much room for you to work.
Connect the the inline resistor harness to the factory bulb socket.
Now connect the white connector from the inline resistor harness to the black connector on the main harness. NOTE: YOU MUST HAVE THE RED WIRE IN LINE WITH THE BLACK WIRE! The connection looks like it should be made the other way because there is a tab on the black connector from the main harness that the two white pieces from the resistor harness hold on to when connected, however, the lights WILL NOT work if you connect them that way and the black wires from each harness are inline with each other.
RED IN LINE WITH BLACK
Now you can attach the ground wire from the main harness. It is a 10mm bolt.
Next insert the LED bulb into the main harness connector. You may need to remove the lime green rubber piece otherwise it makes it very difficult for the connector and bulb to meet fully. (I took the green piece off.)
Next mount the gold inline resistor to the frame. I used double sided tape squares for this and cleaned the area well before attaching the resistor so it would stick properly. There are small holes on the resistor you can utilize if you prefer to use self tapping screws to attach the resistor to the frame, but that is up to you.
Repeat the same steps above for the drivers side. After making all the proper connections on the driver side, connect the red wire from the main harness to the positive battery terminal, which is also a 10mm bolt. Be careful not to remove the lead to the battery when removing the bolt as there is no need to remove the lead from the battery terminal.
Button everything up and enjoy your new LED DRL's with NO DRL light on the dash!!
The following 16 users liked this post by The Machine:
@cura_driver (01-03-2014), BlueAc (01-13-2013), BSpecialist (04-09-2012), ff4930 (04-11-2012), gatrhumpy (08-18-2018), great08 (09-18-2012), j_u (11-10-2013), KJ TL-S (04-18-2012), LoveMyTL-S (04-23-2012), manuel9210 (07-03-2015), Mondo375 (04-10-2012), ParaSurfer1979 (06-08-2012), Relentless84 (04-15-2015), rossv1 (12-26-2012), sauceja (06-05-2012), Undying Dreams (10-29-2017) and 11 others liked this post. (Show less...)
Old 04-09-2012, 07:31 PM
BSpecialist's Avatar
Just got my kit, will hopefully be installing the next nice evening.
Old 04-09-2012, 07:34 PM
It's easy man, the biggest pain is getting the driver side bulb in and out because there isn't a lot of room because of the battery. Best advice is try to remember how the bulb came out when you loosen it. That way when you go to put the bulb back in you'll know what way the tabs have to go when starting to twist it in.
Old 04-09-2012, 07:42 PM
guitarplayer16's Avatar
Nice DIY =)
I wonder if they sell something similar for us Canadians with DRLs.
Old 04-09-2012, 07:44 PM
I'm a pro at getting the bulbs out/putting them in. I've had them in and out so many times with all the kits I've tried lol. So on both sides it will be red to black? or just red to black on the side with the red only. Thanks for the write-up/clarification.
Old 04-09-2012, 08:04 PM
Mondo375's Avatar
funny, i actually just installed mine today. Im waiting on a resposne from them because for some reason mine only come on if i tap or flick the relay on the harness. Once they are on they stay on but if i turn the car off and crank it back up they don't come on unless i tap or flick the relay
Old 04-09-2012, 08:10 PM
Yes, both sides have to be red to black or they won't come on. An no problem for the write-up, I hope everyone that plans on doing this finds this useful.
That sucks man. Maybe there is a loose connection where the big relay is at the end of the harness. I'm sure they will send you a new one or be able to diagnose what's going on with the one you have.
lickkmykickkz (04-09-2012)
Old 04-09-2012, 08:18 PM
lickkmykickkz's Avatar
@the machine...install mineeee...
Old 04-09-2012, 08:30 PM
Mondo375's Avatar
Yea hopefully! I was going to crack open the relay but i dont see a way how with out breaking it so ill just see what they say lol. Other then that they are very nice!
Old 04-09-2012, 09:29 PM
paperboy42190's Avatar
i have the same kit from ijdmtoy...works well and you are correct about the red to black connection, it is very important but most people mess it up.
Old 04-09-2012, 09:57 PM
Chapter Leader (Midwest Region)
McCollins23's Avatar
I know this has been covered several times, but is the only reason you need the harness is for the dash light warning?
Old 04-10-2012, 04:17 AM
I thought this as well and tried just putting LED bulbs in and only half the tree lit up and some people nothing lit up. So you need the harness to get the power the LED's need in order for them to light up properly or even light up at all. You can't put LED's in the DRL like you can with front and read turn signals LED's.
Old 04-10-2012, 06:48 AM
truonghthe's Avatar
nicely done, I like the write up.
Old 04-10-2012, 09:48 AM
KJ TL-S's Avatar
Thanks for the write-up! I've been waiting to hear some success stories with this, and now I think I'll finally pull the trigger. Anyone know if these kits ever go on sale? I probably won't get to this for a few weeks so I figured I could wait if there is a chance of a sale or promo code, otherwise I'll probably just order it up.
Also, anyone have any shots from farther away during the day? I've seen a few people with LED DRLs that are only visible from a few car lengths away. It looks like these are plenty bright, but some more pictures would be nice.
Old 04-10-2012, 10:28 AM
tl08newbie's Avatar
thx for the write up I have the jdm harness and resistor set but got my bulbs from ebay.......I'll be installing mine next week when I'm on vacation
Old 04-10-2012, 10:48 AM
Not too sure if they ever go on sale, but $55 plus shipping isn't too bad for all the wiring plus bulbs, so I would just order them. I will try to take some pictures from farther away tomorrow and post them up for you. Not sure how bright you're looking for them to be from a distance, but the bulbs have a bluish tint to them and will probably be hard to see super bright from a far distance when it's really sunny out. You would probably need a darker color bulb to see them better at a greater distance.
KJ TL-S (04-10-2012)
Old 04-10-2012, 12:49 PM
sapanpatel123's Avatar
Do you think this would work for the 05 TL? Since the original DRL module is discontinued, I don't know any alternatives.
Old 04-10-2012, 04:07 PM
Hmm, that's a good question. I guess you could hook all of it up and see what happens. I can only assume it would work as long as the LED bulbs get the correct power that they need I guess it really wouldn't matter if you had the module or not. And since you don't you don't have DRL's to begin with I guess you really don't have to worry about the light on the dash, lol.
Old 04-10-2012, 07:26 PM
allin's Avatar
Funny, but I installed the IJDMtoy kit about 5 months ago and it worked for one day, then the DRL warning light came on and cut power to the lights so they did not work. I had to return it to them. But the kit i received had a black resistor and not a gold one. Anyone know if the gold one is updated? I would consider buying a new kit from them if it works.
I have an 07 base w/nav. Wonder if the year and/or equipment makes a difference.
Old 04-10-2012, 07:59 PM
UA7 6MT
TmaX's Avatar
Nice DIY =)
I ran the iJDMToy DRL with my Canadian base TL actually.
I had the DRL light showing but it didn't bug me.
These are 6000K btw and I am now looking for a 5000K DRL this time around.
Old 04-10-2012, 08:01 PM
Yeah that's the old kit I had too, they just replaced it with the new one. I will be installing the next sunny day
Old 04-10-2012, 09:56 PM
dano4o8's Avatar
i want to replace mine with tiger piss yellow...
Old 04-10-2012, 10:04 PM
ff4930's Avatar
These are 6k?
Also, would you advise DIY for a 100% car newb? (Just got my first car 2 weeks ago).
Old 04-11-2012, 05:43 AM
Mondo375's Avatar
I'd say they are 6k. Next to my 5k switchbacks they are def more blue then white. It's pretty hard to mess up the install IMO. Just unplugging and plugging stuff in. Just watch the video in the original post a few times or while you ate doing it.
Old 04-11-2012, 07:18 AM
Originally Posted by ff4930
These are 6k?
Yes, I believe they look to be 6k. I have a set of LED bulbs from ebay that are more white than these. I mixed up the bulbs when putting them in and I was pressed for time before work. The driver side had the blue bulb and since it's a little bit more difficult to get the bulb in an out of that side, I just changed the passenger side to the blue bulb. So now I have an extra set of white bulbs incase one of these goes out.
And yes, you can do this install being a 100% noob. It's really not that difficult to do as it is just plug and play. Just watch the video and read my write up as you do the install and everything will come together nicely. The hardest part of the whole install is getting the driver side bulb in and out because the battery is there and it makes it a tight squeeze. Other than that, it's a piece of cake.
Old 04-11-2012, 07:42 AM
ff4930's Avatar
Thanks Mondo and Machine for clarifying! I am just worried because I don't want to f**** anything up since its my first car and all =P. But I got to try sometime =).
One other question, I do plan on getting new HID/fog kits to replace my 08 TL OEM HID/fogs. This way I can do that and get the DRL LED kit replaced at the same time. Is replacing HID/fog lights a easy DIY for a first time noob like myself? Or should I go to the shop and have it done?
Old 04-11-2012, 08:13 AM
All About Trance
mn2trance's Avatar
Nice write-up! However, your resistor won't be sticking to the car for much longer due to the resistor running really hot. I had used double sided tape for my LED turn signals and the resistors caused the adhesives to melt. That's when I had to mount it with some screws.
Old 04-11-2012, 09:32 AM
From what I have read, I believe the fog light kit should be easy as well because that is also a plug and play kit. I ahve not personally done it so I can't really offer you any more insight into installing it, however, I would recommend getting the harness' for the hid kit though. You don't have to, but it is recommended so you don't burn out your factory harness over time.
Yeah, I agree, the resistors do get pretty hot and very quickly I might add. I kinda rushed the install because I had to get to work, so the doubled sided tape is just a temporary setup for me. I am going to get some self tapping screws when I get some free time and then mount the resistors that way.
Old 04-11-2012, 04:08 PM
Ok I took 2 shots from about 100 feet away. There was a little overcast at the time of the pictures as well. The first was with no zoom. It's kinda hard to make out because of how far away I am, but I figured I would post it anyway. In person it still looked very visible from that distance though. The second picture was still from 100 feet away, but the camera was on full zoom.
KJ TL-S (04-11-2012)
Old 04-11-2012, 05:14 PM
KJ TL-S's Avatar
Thanks for the pictures! These will be on my list finally. I've been waiting for a dependable set, and it looks like this is it.
Old 04-12-2012, 01:11 AM
ok im gonna explain to you guys why the process isnt as simple as swapping out the bulbs. the DRL needs to detect a certain load from the bulb otherwise it will think the bulb is dead, the concept is very similar to turn signal hyperflashing. Except in this case, instead of hyperflashing, the DRL will shut off because you wouldn't want only one side DRL to come on. So that is why those gold resistors are needed. It produces the resistance a normal halogen bulb would give since now you have LEDs. Okay, so you ask, why is there a harness, why not just have the resistors and install the LED bulbs? The difference is that DRL stock voltage is 6v for half the power of a regular 12v bulb. If you plug in the LED like that, it's not going to be very bright at all. Ever seen LEDs on cars like the honda civic(06-11)? or the TSX(09+)? Those cars you can straight up just swap to LED bulbs, and it will only power it at 6v without needing any harness or resistor. It looks really dim. So in order for the DRL to be bright, it uses a relay harness. What that does is once it senses the 6v from the DRL, it will trigger the relay to give your new LED bulbs power straight from the battery, hence the battery connection on the harness. So that is why these harnesses allow our TLs to have such bright DRLs. I hope you guys understand now, I took awhile trying to reverse engineer the harness and I finally understand how and why it works. I actually got it free from ijdmtoy because I was there in person buying switchbacks and the owner saw my car and wanted to test fit the harness on my car so he gave it to me for free.
The following 5 users liked this post by paperboy42190:
3FIFTY'07TL (03-02-2016), NateTheGreat8 (09-25-2014), Relentless84 (04-15-2015), The Machine (04-12-2012), toosoonjr (06-14-2017)
Old 04-12-2012, 03:11 PM
^^Very good explanation of how everything works and why it is all in place.
Old 04-12-2012, 10:00 PM
ff4930's Avatar
How you get them $55? Coupon or promo code?
Right now it is showing $64.99.
Old 04-12-2012, 11:04 PM
Got mine installed tonight, it took maybe 15 minutes. Works great so far, we'll see if this kit lasts. Pics soon to come.
Old 04-12-2012, 11:22 PM
KJ TL-S's Avatar
Looks like $55 was the sale price, and they just upped it to $65. Kinda sucks, but Im not buying yet anyway after putting in my order for an A Spec kit this morning
Old 04-13-2012, 04:08 PM
geezr98's Avatar
My ijdmtoy kit looks totally different
I've had bout 8 months now installed
W that DRL light on always. I'm used to it. Guess I'll upgrade some time this year.
Old 04-13-2012, 04:22 PM
Oops, maybe the price was $64.99 and for some reason I thought it was $55. Sorry about that. Either way it's still a good deal and cheaper than the V-Leds kit.
Yeah, I think you may have the older version. They changed to this version not too long ago. It's only been a couple days, but everything still works great!
Old 04-13-2012, 05:50 PM
Mondo375's Avatar
I can't remember if I used the promo "JDMFAN" or "GOJDM" but I got a discount that pretty much covered shipping!
Old 04-14-2012, 11:08 AM
I was about to order these, and I noticed your light output varies from side to side. Is this common? It seems that one bulb is not getting enough power/ or too much. Is anybody else having this issue with these or is it just a camera issue that I'm seeing. I really want these, but not if they are not completely %100 perfect (I'm anal about these things).
Old 04-15-2012, 11:32 AM
I think it's just my camera. It's just a point and shoot, and no matter what setting I had it on, I really couldn't get rid of that blur that occurs when you take pics of the headlights. People with better cameras can usually take nice pics when looking right into the light and not have the issue I'm having.
Dmoney23 (04-23-2012)
Quick Reply: iJDMtoy Led DRL Harness Install w/Pics
