Acura ServiceNews Bulletins
Old 07-07-2006, 08:39 AM
cM3go's Avatar
So if I don't have my Turanzas on I can't get the the TSB done?! I switched tires cause they sucked.
Old 07-29-2006, 03:58 PM
Administrator
Ron A's Avatar
July 2006 added.
Major topics:
Tire puncture sealants bad news for TPMS sensors
Backup sensor system-how it works and how to troubleshoot it
Old 08-29-2006, 09:31 PM
backthatACup's Avatar
sup guys i was talking to -2 dealers in my area,cleve that said that i have to pay $100 for a diagnostic in order to see if my hfl does need replaced, i told them it does since it doesnt recog. voice comm, and they said they have to confirm it to see what it is ,anything i can do or say, any of you vets round here, i could sure use some help
Old 09-03-2006, 10:50 AM
Administrator
Ron A's Avatar
August 2006 added.
Major topics:
Engine oil looks dark.
Say "buh-bye" to those adhesive goo blues.
Navigation system DVD handling tips.
TPMS problem in 06-07TL's.
Acura precision crafted MTF: It's even better than before.
Old 09-05-2006, 03:07 PM
gammah's Avatar
Originally Posted by Lister00169
Very nice finds with great info (especially the Dash Fade issue)
Where do you see this? I went through all of 2006 and did not find a thing regarding Dash Fading issues.
Gammah
Old 09-05-2006, 03:23 PM
CFIMEI's Avatar
Gammah
It's in the December '05 issue.
(edit by mod Ron A: It's been moved to the Sept 06 issue)
http://www.in.honda.com/Rjanisis/pubs/SN/B051200.PDF
Old 10-05-2006, 10:16 AM
  #47
Administrator
Ron A's Avatar
September 2006 added.
Major topics for 3G TL:
Nitrogen inflation: What's our position?
Dashboard looks faded or blotchy?
Acura music link stops working (06 TL only)
How to force-retrieve maintenance item codes
Don't swap TPMS valve cores with standard valve cores
XM satellite radio reception is unique
Old 10-30-2006, 12:03 PM
Administrator
Ron A's Avatar
October 2006 added.
Whiny A/T: Consider this before ordering a Reman (This is really for the mechanic/service manager but might give a user some info to remind them)
Automatic transmission shock or noise? Neutralize the engine mounts.
That's it. Not much new this month.
Old 12-01-2006, 03:07 PM
  #49
Administrator
Ron A's Avatar
November 2006 added.
The lowdown on accessory rooftop luggage carriers.
Navigation system doesn't match map or gets lost.
Keyless access remote must be linked to keep customized settings.
Moonroof visor bracket gap causes wind noise.
Save yourself time and effort: Know your tire pressure indicators.
Old 12-06-2006, 02:01 AM
  #50
MiaQbn23's Avatar
thanks!!
Old 01-04-2007, 02:26 PM
  #51
Administrator
Ron A's Avatar
December 2006 added.
Never use chrome wheel cleaner on alloy wheels (general information)
New TIME-SERT head bolt thread repair instructions.
Old 01-23-2007, 11:22 AM
  #52
Tennisjon2002's Avatar
Does anyone here have access to the Honda service bulletins?
Old 01-23-2007, 11:25 AM
  #53
sasair's Avatar
Honda bulletins are the same links, just change the B to A in the file name....
Old 02-01-2007, 10:15 AM
  #54
Administrator
Ron A's Avatar
January 2007 added.
Stiff Shifting? Popping Out of Gear? Replace the MTF
Check out That Cool R-134a Refrigerant Oil Guide
Side Moldings Coming Loose or Falling Off?
Acura Music Link Stops Working
Old 02-27-2007, 11:41 AM
  #55
Administrator
Ron A's Avatar
February 2007 added.
Replace Solenoids or Replace A/T? How to Decide
Oil Fill at Top of Damper Working Chamber is OK
Homelink: Before You Troubleshoot, Consider This
Proper Care and Feeding of an Acura Battery
Old 03-31-2007, 08:25 PM
  #56
Administrator
Ron A's Avatar
March 2007 added.
New Daylight Savings Time Schedule Poses Navi Clock Problem
Outside Temperature Indicator Logic Explained
Old 05-01-2007, 10:07 AM
  #57
Administrator
Ron A's Avatar
April 2007 added.
Water on Top of the Taillight Housing? It's not a leak. (07 TL's only)
Replacement HID Headlight Bulbs Look Yellow at First
Old 05-01-2007, 10:27 AM
  #58
Kaa - Ching !!!
SteveP66's Avatar
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Originally Posted by Ron A
April 2007 added.
That's funny - I remember a couple of "WTF" threads a few weeks ago about the water on the top of the headlights. These updates are great
Old 06-01-2007, 01:47 PM
  #59
Administrator
Ron A's Avatar
May 2007 added.
New policy for steel and aluminum wheel repair
HFL locked and forgot the password? Read this. (for 04-06 TL's only)
No sound from XM or no real-time traffic? Check the battery. (for 07 TL's only)
Old 06-17-2007, 03:35 PM
  #60
black07's Avatar
wow thanks my man!
Old 06-22-2007, 08:20 AM
  #61
Administrator
Ron A's Avatar
June 2007 added.
Sorry, nothing this month for 3G TL. Just about everything in the news is for the dealer technicians.
Old 07-01-2007, 11:06 PM
  #62
JeffsTL's Avatar
Very useful...
Old 07-13-2007, 06:12 PM
  #63
AZ Community Team
Bearcat94's Avatar
RonA,
Thanks for keeping these up to date. I've been reading them monthly as well as several "back issues".
Knowledge is Power.
Old 07-26-2007, 02:29 PM
  #64
NBP REPRESENT
BlacuraTL-S's Avatar
07 Type S Knock or Clunk From Rear Suspension
As of July 20, 2007
Acura Service Bulletin
There is a knock or clunk coming from the rear suspension. The noise can sound like loose items in the trunk or on the rear shelf.
Cause:
One or both of the rear damper assemblies are faulty.
Old 07-26-2007, 04:32 PM
  #65
CEO, Team Anthracite
Lore's Avatar
Originally Posted by BlacuraTL-S
As of July 20, 2007
Cause:
Do you have a TSB number or a link to the TSB itself?
Old 07-26-2007, 04:44 PM
  #66
NBP REPRESENT
I think this is the correct number...
07-039
it affects From VIN 19UUA7...7A000001 through 19UUA7...7A031980
Failed Part: P/N 52610-SEP-A17
The defect code is 06201
Symptom codeL 04201
Old 07-27-2007, 01:07 AM
  #67
Lore's Avatar
07-039
Symptom codeL 04201
Here is a direct link:
http://www.in.honda.com/Rjanisis/pubs/SB/b07-039.pdf
Old 08-01-2007, 10:09 AM
  #68
Administrator
Ron A's Avatar
July 2007 added.
Security System Sounds by Itself (applies to 04-07 TL's)
After Market Window Tinting Can Cause Noisy, Binding Windows
(my note here: Don't forget the moleskin!)
Old 09-01-2007, 10:25 AM
  #69
Administrator
Ron A's Avatar
August 2007 added.
Everything this month applies to other models or is for technicians use only.
Old 10-07-2007, 10:38 AM
  #70
Administrator
Ron A's Avatar
September 2007 added.
Remember to Reset Power Window Control Unit (04-07TL)
Old 11-03-2007, 06:55 AM
  #71
Administrator
Ron A's Avatar
October 2007 added.
Excessive Steering Wheel Shimmy or Chassis Vibration - Part 1 of 5 (General information applying to all vehicles)
Brake Judder Comebacks (04-05TL with A/T)
Old 12-02-2007, 08:55 AM
  #72
Administrator
Ron A's Avatar
November 2007 added.
Window Film Can Block Electronic Device Signals (general information)
Blue Arrows Mean One-Way Traffic (All navi models-08 only)
Excessive Steering Wheel Shimmy or Chassis Vibration - Part 2 of 5 (General information applying to all vehicles)
A Trouble Shooting Guide to HandsFreeLink - Part 1 of 5
Accessory Trunk Spoiler is Loose or Lifting Up (04-08 TLs)
Old 12-31-2007, 07:21 PM
  #73
Administrator
Ron A's Avatar
December 2007 added.
Excessive Steering Wheel Shimmy or Chassis Vibration - Part 3 of 5 (General information applying to all vehicles)
A Trouble Shooting Guide to HandsFreeLink - Part 2 of 5
Replacing Just Two Tires? Mount New Tires on the Rear.
Seat Won't Go to Memorized Driving Position When Opening Door (Along with the technical stuff there's some basic troubleshooting info.)
Old 02-01-2008, 03:10 PM
  #74
Administrator
Ron A's Avatar
January 2008 added.
The format has changed and is much easier to read, with each topic starting on a new page.
Check Out the Latest Word on A/T Flushing-defines the word "flush" used in this procedure, and eliminates the need to actually drive the car when doing the 3 dran and flush procedure.
VSA Activation Inidcator Stays On After Doing S/B 07-041
Excessive Steering Wheel Shimmy or Chassis Vibration - Part 4 of 5 (General information applying to all vehicles)
A Trouble Shooting Guide to HandsFreeLink - Part 3 of 5
Old 03-01-2008, 10:23 AM
  #75
Administrator
Ron A's Avatar
February 2008 added.
Ticking, Creaking, or Rattling From Front Door
Navi Display Won't Switch to Night Mode With Headlights Turned On
Poor XM, CD, Aux Sound Device Quality; Weak Volume From Speakers
Excessive Steering Wheel Shimmy or Chassis Vibration - Part 5 of 5 (General information applying to all vehicles)
A Trouble Shooting Guide to HandsFreeLink - Part 4 of 5
Old 04-03-2008, 11:21 PM
  #76
Administrator
Ron A's Avatar
March 2008 added.
Now Available: Extreme Cold Weather Antifreeze/Coolant Type 2 - General information
A Trouble Shooting Guide to HandsFreeLink - Part 5 of 5
Old 05-01-2008, 10:19 AM
  #77
Administrator
Ron A's Avatar
April 2008 added.
07-08TL: Automatic lighting and automatic lighting off are different features
06-08TL: Cant turn off the VSA: Check to see if the TPMS indicator is on.
(Note: If you install wheels without TPMS, the VSA and the TPMS indicator will always be on.)
Old 06-01-2008, 10:07 AM
  #78
Administrator
Ron A's Avatar
May 2008 added.
Replacement Lens in Stock for Audio-HVAC Display Module Assy (07-08TL only without navigation system)
M/T Intermittently Pops Out of 1st Gear (05-07TL with M/T)
Old 06-11-2008, 06:08 AM
  #79
coinnetnet's Avatar
Thumbs up Good writing
Good writing. Keep up the good work.A good beginning is a half done
I love this site, just do it! Power levelingl up,
Making more money. Runing a runescape money store ,Mini-sell ,Good luck, and enjoy it!
Old 06-12-2008, 02:25 PM
  #80
Administrator
Ron A's Avatar
Originally Posted by Bearcat94
Hey Ron A,
Link for March 2008 seems to be broken. Can you check it? Maybe it's just me?
It must be Honda. I did what I always do, which is copy the preceding month's data and then change the month code and the actual month, and it still doesn't work.
Maybe there's something in it they didn't want to get out, or whatever.
I'll check it occasionally and see if it comes back or if I can find out what's wrong.
Quick Reply: Acura ServiceNews Bulletins
