Battery Issue
Old 07-21-2014, 05:17 PM
jayroc619's Avatar
Battery Issue
Advise needed...
If my battery is not holding a charge for a day, what could be the problem. I changed the battery and the same issue happened. I went to get the battery and alternator checked and it checked out fine...What could be the problem???
Old 07-21-2014, 05:28 PM
FamilyGuy's Avatar
Something could be draining your battery after you shut the car off. Check your current draw a few minutes after you shut the car off.
Old 07-21-2014, 05:38 PM
Speeden6's Avatar
has your HFL been acting up?
I have had to replace the Alt on mine after 70K, my buddy just had his go out on his type s at 80K.
Old 07-21-2014, 09:33 PM
bauermd's Avatar
If your HFL is having issues, or not responding at all this could be your culprit. It's a known issue to constantly try to connect and drain batteries.
Here is a link to another thread with someone having the HFL battery drain. Could be useful.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/voice-navi-hfl-causing-battery-drain-838605/
Old 07-22-2014, 12:06 AM
A SiQ TL's Avatar
Yea, the HFL was the major cause of my battery draining prematurely also.
Old 07-24-2014, 10:31 AM
3rd Gear
williecoyote's Avatar
HFL was draining my battery too.
Look at the roof in the morning when there is dew or condensation on it.
If the roof is dry right over the rear view mirror area, this indicates heat from the HFL, which means that it is working when the car is off.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
scionxb3003
09-14-2015 01:52 AM
whitesoxsfan12
09-13-2015 02:09 PM
chrisr
5G TLX Problems & Fixes
08-31-2015 08:24 PM
Quick Reply: Battery Issue
