All my Lights came on again .. P0740 .. Tranny...!!
a 150 dollar free loaner! wow what a bargain~
B A N N E D
Yeah from friday morning till monday morning $150 for RDX.. not bad...
Better then getting nuttin for my $150..
BTW anyone ever heard of Ledgewood transmissions, I got the # from someone on here and the guys said the most it will cost is $2700 if he has to rebuild the whole tranny.. He said they also use woven torque converters that r much stronger then the honds TQ, should I belive him or is he just pushing some BS on me so i go to him!
GO RANGERS!!!!!!!!!!!!!!!
2700 sounds outrageously high to me. I paid 1200.00 in L.A. in 2004 for my 97 3.0 CL and when I thought my CLS transmission was toast in February was quoted 1350.00.
I would really keep looking.
it depends on what parts have to be replaced internally- that varies the price
A good shop will tell you the highest amount, and hope to do it for less, but they cant tell you 1000 then make it 2700--you would not be happy
B A N N E D
Did that include any type of warrenty?
I could get one out of the junk yard for $800 and installed for $400 BUT that would have NO warrenty and I do not want to drive the car with no warrenty on the trans.. I found anouther place that is closed right now but on there site they rebuilt trans was like $1400 and instalation was $500 w/12 month unlimited miles warrenty so thats less the $2000..
Here is the website:
http://autotransparts.com/
The site looks very good and its like 2 miles from where my car is!
I am looking but need some help from u guys!! North NJ trans shops that KNOW about this trans and that did it!
1999 Acura 3.2 tl transmission slipping
hello, i have a 1999 acura 3.2 tl and the transmission is slipping, a mechanic told me that the linear solenoid needs to be replaced.
should i change the transmission fluid first or clean the linear solenoid?
how do i clean the linear solenoid?
#47
is it slipping as it shifts into 2nd and 3rd gear?
you have a 4 speed correct?
ck the DIY section on the selenoids- but slipping is usually failure of the clutchpack/disc on the gearset
was the mechanic a trans expert or some guy with a code reader or an acura expert of some type?
Codes are CLUES not diagnosis
First dam cars ever to have dam tranny issues without even attempting to do N dropps.......
anyone ever looked at the solenoids?? Or can tell why do they go bad?? I think they should have corrected that problem along time ago, mind u its a SOLENOID!
#49
better that than a transmission!
cars are built like everything else-- of parts made by the lowest bidder
Nothing last forever,,,so you have to do some parts changeouts now and then
#50
Hi, the problem I'm having is the D-5 light is blinking, the engine light is on and off, and the TCS light is also an and off. No transmission slips. I had the Acura dealership replace my tranny December 2008. i just had an alarm w/remote start installed, and the day I had this done, was the day these lights started malfunctioning. Prior to the alarm installation I had no problems. Any help or suggestions will be greatly appreciated.
#51
go back to the alarm shop- they screwed up something bad
#52
I already bought it back, they said they couldn't find the problem, so they reset the lights, but they came back on the next day. I noticed, that when the tcs light and the engine light is on at the same time, the car won't go forward unless you give it plenty of gas.
#53
go to aamco for a free transmission inspection maybe the trans died at the same time, or there is something wrong because idiots worked on your car~
Take it to another stereo shop for correction and bill the first place for it
#54
Change the solenoid it will fix the problem, it happened to my boy with his 99 4sp AT model,
BlkTxAcuraTypeS
10-18-2015 08:05 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
1999, 28250p6h024, 28600p7w003, 28600p7z003, acura, cl, control, honda, lockup, p0740, rebuilder, solenoid, tl, transmission, types
