CLOSED: Accord V6 6MT 06 Turbo 7.5 PSI. Charleston, WV
Year: 2006
Make: Honda
Model: Accord
Price: $14000
Mileage: 136629
Color: Satin Silver
Location (State/Prov): WV
2. Mileage: 136,629 (will go up since it is daily driven)
3. Color, Transmission-auto or manual, Navi: Statin Silver, MT, Non-navi
4. Reason for selling: Posting up my daily driven accord v6 6mt 06 turbocharged car. Looking to get a truck to haul all my stuff back to california in May/June. Dyno chart is provided below @ 7.5 psi. Perfect sleeper since it has full interior with all luxury items working. Dyno chart provided below for before and after. See list below for mods
5. Location: (Also, please enter the location of the car in the thread title.): Charleston, WV
6. Pictures: (Links are ok here, but please post actual pictures after item 12 so all the text is in one place and easier to see): See below for pix
7. Are you the first owner? If not, how many owners were there (to the best of your knowledge)? 3rd owner, bought the car in 2010 with ~60k on it. To the best of my knowledge the car was leased by the first own. Bought buy the second and then sold to me. It was orginially from California, but I drove it to WV for Graduate school.
8a. Title is clean/clear/rebuilt/salvage/if other, explain further (select one): Clean Title
8b. Do you have title in hand or it is being held by a lienholder: I have the pink slip
9. VIN (would be nice to have but I can understand that some people do not want to publicly post this): PM me for vinn
10. Modifications:
Suspension work
Koni/ neuspeed supercup kit SP3 (5 perches, aka the good kit)with sport springs on the lowest perche
front polyurethane sway bar bushing
Moog lower control arm
Moog lower front lower ball joints
Moog tie rod ends (greasable)
Mevotech front endlink (greasable)
Adjustable rear camber kit upper arm
TLs rear sway bar
Rear polyurethane sway bar bushing
MB weapon in gunmetal 17 x 7 with cooper RS3-A tires 235/45/17
Winter MB weapon in Bronze 17 x 7 with 215/45/17 with hankook icepike snow tires
Brakes
Willwood 4 piston caliper with stainless steel lines (with semi-metalic pads)
Centric 12.8in nissan maxima v6 front rotors
Rear mdx caliper brackets (with wagner ceramic pads)
Centric MDX rotors
Interior
Hardwire radar dector for escort and belltron with mute button
Hardwire dash camera included with car
Skunk2 weighted shift knob
Comptech short shifter
Metal shifter bushing
Pioneer avic double dinn (non-navi)
Metra double dinn kit
ASWC-1 steering wheel integration kit
AEM AFR gauge
Turbosmart analog boost gauge
Custom build dual gauge pod cluster
Fatmat sound deadener lines on all doors. On layer on the back side of the paint/ car skin, and another layer facing the interior side. Rear seat as 2-3 layers, and truck floor and truck has 2 layers on it to keep the car from rattling while bumpping up the bass
Front Hifonics zues componet speakers rated at 100 rms each with crossover and tweeters installed on door sails.
Rear speakers are rockford speakers
4 channel pioneer class D amplifier to power the front and rear speakers
PrecisionPower class D amplifier for the subs
Subs in a sealed box with a pioneer 12in subs (forgot the model number)
Honda carbon fiber interior kit
Rear autodimm mirror
Rear backup camera hardwire to the pioneer double dinn
Performance Parts
Stock j30a4/5 bottom end
TL type s port and polished cylinder heads with type-s valve train and j37a1 camshaft
P2R throttle body spacer for methanol injector NPT port
MDX milled spacer with P2R thermal gasket
RDX 410cc injectors with injectors clips
TL type S internally polished intake manifold
Richie Rv6 high flow primary catalytic converter
All O2 sensor was changed prior to turbo build
Aquamist HF-2/3 Water-methanol kit
Custom open scroll t3 turbo manifold
Holset HX-35 turbo with Custom Garrett GT30 A/R .63 hotside
2.5 in to 3in down pipe
2.5 inch magnaflow catback with extra 18in resonator to keep the car sleeper
K&N intake filter
type RS Real F*ken loud blow off valve (Extra new turbosmart veeport blow off valve if you don't like the RFL one **see image**)
2.5 gallon devil own water-methanol tank in the trunk.
Turbosmart Ultra Gate 38mm wastegate, currently set at 7 psi but do have the springs to make it 14psi.
Open dump tube.
Innovative 75a motor mount
Tl-s 07 ecu
Hondata flashpro
Custom adaptor harness to get hondata to work on the accord
canbus harness
Custom oil pan with AN -10 drain for turbo
Clutch
Custom Stainless Steel braided clutch line
Clutch Slave valve delete
Luks Dual mass flywheel (replaced when the car had around 80k)
Luks OE clutch and pressure plate (Replaced when the car had around 80k)
11. Service record: Only what has been done at firestone and honda. I do my own maintenance regularly.
12. If leased, provide details, such as length of lease, payoff amount, etc.: Paid off a long time ago
I am sure there is some minor stuff that I am missing, but this is the bulk of it. Send reasonable offer if you are interested and tired of getting smoked by WRX and STI.
Posting a list of stuff I got from Autocheck
Accident Check
Not all accidents / issues are reported to AutoCheck.Your Vehicle Checks Out: There have been no accidents reported to AutoCheck for this 2006 Honda Accord EX (1HGCM65596A000995). AutoCheck receives its accident data from government sources and independent agencies, and based on the information available to us, we have found that no accidents have been reported on this vehicle.Title and Problem CheckYour Vehicle Checks Out: AutoCheck's database for this 2006 Honda Accord EX (1HGCM65596A000995) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and Event Check for reported accidents that can affect vehicle safety and value.0 Problem(s) Reported:15 Title/Problem areas checked:No abandoned title recordNo damaged title or major damage incident recordNo fire damaged title recordNo grey market title recordNo hail damage title recordNo insurance loss title or probable total loss recordNo junk or scrapped title recordNo manufacturer buyback/lemon title recordNo odometer problem title recordNo rebuilt/rebuildable title recordNo salvage title or salvage auction recordNo water damaged title recordNo NHTSA crash test recordNo frame/unibody damage recordNo recycling facility recordOdometer CheckYour Vehicle Checks Out: AutoCheck examined the reported odometer readings reported to AutoCheck for this 2006 Honda Accord EX (1HGCM65596A000995) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.0 Problem(s) Reported:MileageDate Reported1709/18/200547,56911/17/200847,56911/19/200847,56911/24/200847,66801/11/200962,26109/28/200990,78105/03/201294,01008/06/2012Vehicle Use and Event CheckInformation Reported: AutoCheck shows additional vehicle uses or events reported to AutoCheck for this 2006 Honda Accord EX (1HGCM65596A000995). This includes reported vehicle uses such as rental or lease, and events such as whether the vehicle has been reported to have had a loan/lien or a duplicate title issued. Other events show if the vehicle has a reported accident and how many calculated accidents or if it has been reported stolen or repossessed. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase.0 Event(s) Reported:6 Vehicle uses checked:No fleet, rental and/or lease use recordNo taxi use recordNo police use recordNo government use recordNo livery use recordNo driver education record1 Event(s) Reported:9 Vehicle events checked:No accident record reported through accident data sourcesNo corrected title recordNo duplicate title recordNo emission/safety inspection recordLoan/Lien record(s)No fire damage incident recordNo repossessed recordNo theft recordNo storm area registration/title recordDetailed Vehicle History
Calculated Owners: 4
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date September 24, 2016 6:46:59 PM EDT
Vehicle: 2006 Honda Accord EX (1HGCM65596A000995) Event dateLocationOdometer readingData SourceDetails09/18/2005CA17Motor Vehicle Dept.ODOMETER READING FROM DMV10/05/2005FREMONT, CAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL10/07/2005FREMONT, CAMotor Vehicle Dept.TITLE (Lien Reported)07/21/2008SAN JOSE, CAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL09/05/2008SAN JOSE, CAMotor Vehicle Dept.TITLE (Lien Reported)11/17/2008PACIFIC SW REGION47,569Auto AuctionREPORTED AT AUTO AUCTION AS DEALER VEHICLE11/19/2008PACIFIC SW REGION47,569Auto AuctionREPORTED AT AUTO AUCTION11/24/2008CONCORD, CA47,569Dealer RecordVEHICLE IN DEALER INVENTORY (COLOR REPORTED AS SILVER)
VEHICLE REPORTED TO BE UNDER WARRANTY01/11/2009CA47,668Motor Vehicle Dept.ODOMETER READING FROM DMV01/30/2009DISCOVERY BAY, CAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL01/31/2009DISCOVERY BAY, CAMotor Vehicle Dept.TITLE (Lien Reported)09/28/2009CA62,261Motor Vehicle Dept.ODOMETER READING FROM DMV10/28/2009SAN JOSE, CAMotor Vehicle Dept.TITLE (Lien Reported)11/05/2009SAN JOSE, CAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL10/05/2010SAN JOSE, CAMotor Vehicle Dept.TITLE
REGISTRATION EVENT/RENEWAL05/03/2012CA90,781Motor Vehicle Dept.ODOMETER READING FROM DMV05/04/2012SAN JOSE, CAMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL05/17/2012SAN JOSE, CAMotor Vehicle Dept.TITLE08/06/2012CHARLESTON, WV94,010Motor Vehicle Dept.TITLE (Title #J31032)
REGISTRATION EVENT/RENEWAL09/26/2012ManufacturerMANUFACTURER RECALL
RECALL S60
P/S FEED HOSE LEAK
LOCATE YOUR NEAREST AUTHORIZED
HONDA DEALER TO SCHEDULE REPAIR.08/12/2013CHARLESTON, WVMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL06/16/2015CHARLESTON, WVMotor Vehicle Dept.REGISTRATION EVENT/RENEWAL
Accident Check
RECALL S60
P/S FEED HOSE LEAK
car is no longer for sale. Had an issue with the water/methanol system failing. Dumped a gallon and a half into either the engine or parts unknown... So will be swapping in a motor and returning back to stock to trade in.
