crank position sensor
havent worked on the car for over a week. all my grounds are good, im gonna check to make sure my ecu is all plugged in. but i did get a iacv code last weekend. kept fluctuating all over the place but only when i would be stopped at a light. so im guessing its the harness. ill work on it soon.
got a harness and installed it. now, still get the crank position sensor code (p0336) and my spedo and reverse lock out doesnt work. so im gonna go and recheck to make sure everything is plugged in. so unless its the ecu that gone to shit once again. idk what could be the problem
Check to make sure all your grounds are in contact.
one plug wasnt plugged in, plugged it in and spedo and reverse lock out works. still have the crank code. swapped in my other ecu and crank code still comes up. so my last guess is that its the fly wheel. but if others are running the same fly wheel. what is up with mine.
1foxbody (01-24-2013)
What flywheel did you order?
Shouldn't have any problems with the new one hopefully . What pressure plate and clutch disc are you going to use with it?
#50
I still need to get a light weight flywheel.
#51
Whats up with RDX owners?
1foxbody (01-26-2013)
#53
So what was wrong with the lwfw?
#54
no clue what was wrong with the lwfw. i compared them every which way and measured everything and it all matched up. the crank trigger notches on the lwfw were 1/16th narrower then the ones on the oem flywheel but thats the only thing that i could find. different
#56
so i couldnt do what i wanted (oem flywheel, p2r disc and the clutchmasters pp). the disc was loose when the pp was installed so i reused my old stock pp and p2r disc. bc my pp is so worn out that the car isnt drivable. but the good thing is that it revs fine so ill be ordering a oem pp and disc for the time being
#59
Lives in Boost
Me, you, Brian and some other mid-western Azine'ers needs to have a track day around the same time as the one on the East coast. It would be a pretty good time.
Rajca (01-27-2013)
#61
Lives in Boost
#62
Im in for a track day.
#63
well, with the oem fly wheel and oem clutch. the car runs great. put just over 200miles on the clutch so far, and besides needing more fuel in the higher rpm, the car drives great.
so i sent out the clutchmasters stage 4 kit last week and no im waiting for what they are going to say about the flywheel
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
