Started on some in home porting
The following 2 users liked this post by AnthraciteTypeS:
97BlackAckCL (01-06-2014),
richardparker (01-02-2014)
#1642
That video was just cruising around on motor. Only wot was when I was spinning and even then I was slightly letting off not to hit the limiter.
I think my car will do mid to high 12's now.
crappy cell phone video but ,here is a 55 to just under 100 passing speed video.
http://s899.photobucket.com/user/acu...194fb.mp4.html
#1645
Nothing new or fancy.
But I got a bunch for the swap.
I ordered a LuK flywheel. I only got it for 189 shipped so I couldn't pass that up when comparing it to the 500$ flywheels.
Any opinions on what's the best clutch and pressure plate options to use with it ?
I want something that will be able to hold atleast 400whp/tq.
A little higher whp/tq would be fine too.
I would like to be able to make more hp down the road and not have to switch again.
#1647
6mt swapped..smart
Spec is also making clutches now, and they actually have custom pressure plates unlike previously when they were just using stock pp's.
I remember when I did my swap and i'm exciting for you just looking at all those goodies!
#1649
The problem with spec is that they do not offer a flywheel, and that is the part I want the most out of upgrading clutch. They make a flywheel for the tsx and 3rd gen tl tho. I am not sure if you can use the aasco flywheel with the spec clutch. Might as well go with CM or xlr8. I just wish there were more ppl running those to see long term results.
1foxbody (02-03-2014)
#1651
6mt swapped..smart
RP, another heads up, you're likely going to need spacers/washers behind the clutch pedal bracket for full engagement. When I swapped my car the clutch wouldn't fully engage without them. On the true 6 speeds there are basically boss's/spacers casted into the firewall behind the pedal
#1652
#1653
are the spec clutches sprung or unsprung. If unsprung for sure. Im running the oem sprung clutch on the Aasco lightweight without issues and im sure the spec would work as well.
#1654
So basically I might need to shim the between the firewall and bracket to get the slack out of the masters push rod.
Is that what your saying ?
#1655
6mt swapped..smart
Yes exactly, you're gonna need about 1/4"-1/2" spacer on each stud. So a few washers. HOWEVER, this will put stress on the bracket itself causing it to potentially crack around the mounting holes (ask me how I know..).
A better solution I found is to use a s2000 clutch master spacer adapter they make for older civics/integras wanting to upgrade to an s2k master. It is really the perfect piece for the purpose. This way, the slack is taken up on the OTHER side of the firewall taking added stress off the pedal bracket. I highly recommend it or you run the possibility of problems down the road
http://www.velocityshop.com/product/...k-dc_1416.html
#1657
#1658
#1659
What one are you thinking of using? Other than the flywheel being lighter and it taking a little different approach to letting the clutch out i have no issues using the sprung clutch on the Aasco
#1660
Glad to see there's still a few OG's left like me, that are actually doing real performance mods. Keep up the good work! I can't wait to see it go 12's n/a!
#1661
To be OG IMO you needed to join atleast before 2005.
#1664
I was meaning more along the lines of there's not many true performance second gen cl guys left, only a handful including you and I. People that are actually spending money on quality performance mods and have real builds. It seems like the past few years the crowd has gotten shittier and the mods are all typical bullshit stuff lol.
#1665
Been away for awhile because I just spent the last few months with my son going threw a medical issue that had us living at a hospitol a hour away for almost 2.5 months.
Made it threw my worst times ever and just starting to get everything situated again at the house.
So I'm going to start back on the car again soon.
#1667
All motor
Hope everything went well with your son. MUCH more important than your car.
#1669
Glad to see you back posting again. It looks like you just drilled out the spot welds to remove extra panels. I was at road america last weekend for the Tudor series races and it has motivated me to do some more weight loss. I started in the trunk. I tried drilling at first, but didn't want to drill thru both panels so switched up to a cutting wheel. Not sure yet if I want to remove the rear strut tower skins, but there is good weight to be lost there.
Did you say before that there is tar deadener under the wiper cowl? Do you know if there is sound deadening under the fender liners also? I am even debating removing the a/c. I'd probably leave heater to defrost windows tho. It might be a necessity to fit my headers so will see.
Hope to see you break into the 7 ' s soon.
#1670
#1671
Ah I wish I knew you were going, I would have said hi. I did not see the cl but there were so many nice cars. I was there Friday thru sunday. It was my first time there. The track and racing was amazing. I walked around the whole trackk multiple times. I had a few crashes happen right in front of me. One was the continentsl tire series on the straight before turn 5. There was a big crash right in front of me at around 150 mph. Some pieces of debree flew thru the fence and landed right by my feet. The sound and smells in person were amazing. I had so much fun, felt like a kid at Disney land.
#1672
Thanks guys my son seams better.
About 3months home and he ocasionally has a little bit of stomach pain once in awhile but i think everything is ok.
docs say it could always happen again too him so any sign of pain really freaks me out.
he starting school monday and its like never happenned to him by how active he is so i hope he conntinues to have a great life.
weve been spoiling like their is no tommorow but he deserves it for what he went threw.
Anyway might be buying nother cl tommorow. A 6Speed this time.
not sure what im going to do. maybe sell my swap pieces,the car im buying,the old car,parting something ,but i got alot of options if i get that car.
we'll see.
posting from my phone so ill get more into stuff later.
we'll see.
#1673
Such a waste of 3days of texting and about 3.5hrs of travling today to look at a white on black 6speed.
the car was only listed with a bad engine and thought i had a good buy at 2400.
Got their and the whole passenger side was dented from the rear fender to the front.
i explained to the guy all i cared about it had a nnice body and the trans was good.
what a dink.
what a dink.
#1675
Yeah I think I'm ready.
The car is just sitting and that needs to change.
The trans in it now is totally done. I think it may have welded itself together.
Every gear position is a forward gear now.
Park,rev,neutral all of them. I got under the car and checked the linkage but all is good and you can just barely push the car backwards by hand.
Ordering all the rest of the little stuff I need tonight.
But for the clutch line stuff, I want to do it once and want to know what I should get from this/delete/and get better lines and what have you.
I'm sure someone could help here.
I'm talking about the stuff in between the master and the slave.
I'm also thinking of the CM fx400 setup if it will hold or some solid disc and a nice pressure plate that will hold my power and use a heavy stock flywheel to drag with.
I think twin setups are out of my buget.
I'll take all the advise anyone has to throw at me.
#1677
Since I've started going to the track last weekend I'm going to start updating progress again this time with the 6speed installed.
when the car was auto it ran a best 8.3 on motor.
I was constantly losing weight and couldnt do any beter on the motor
Since ive lost alot of weight an also went 6speed.
last weekend I Went 8.4 on the motor.
So feeling like some aint right I checked compression and im definitely relieved there.
All cylinders above 240psi ,2 were 245psi 4 are 250psi cold. Engine has about 7500 miles and broken in perfectly.
Next step will be checking my valve lash to make sure none are to tight before this weekend.
stay tuned for times,going to hit the track every weekend I can.
