"My seat won't move/recline" thread
Old 07-05-2012, 05:28 PM
  #81
kc1337's Avatar
Its just the gears that are binding. Use a screwdriver to break the gears free then grease them.
I've taken the motor out before, and I see the gears. But what do you guys mean by breaking it free with a screwdriver? Just pry it back and forth?
kc1337 is offline
Old 07-05-2012, 05:44 PM
  #82
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
Try to spin the gear using the screwdriver. I wish I had a picture, Id show you where to push.
civicdrivr is offline
Old 07-05-2012, 07:41 PM
  #83
kc1337's Avatar
Should I soak the entire gear with penetrating oil then pry at it with screwdriver? Do I need to take the motor out?
kc1337 is offline
Old 07-06-2012, 12:30 AM
  #84
civicdrivr's Avatar
I did it with the motor in. I tried to adjust the seat using the motor, and forced the gears to spin in the direction it should have. No need for penetrating oil.
Old 10-07-2012, 03:42 AM
  #85
qwpobird's Avatar
anyone has picture walkthrough on this ? THANKS
qwpobird is offline
Old 10-19-2012, 07:43 PM
  #86
qwpobird's Avatar
Originally Posted by TOPHER33884
Did you try the method that I gave you on the seat fix? If you dont understand what I am talking about......I have walked thru this with 4 members over the phone. If you interested, I will give you my number so that I can assist you thru it.
never mind,,, I fixed it
for anyone who needs pic reference.... I sprayed MD40 here, and use a flat to band it down a few times,, then ...boom,,,, that's it
thanks for TOPHER33884's method ......
qwpobird is offline
Old 01-21-2013, 08:15 PM
  #87
InspireBySD's Avatar
oh i guess its my turn also my driver seat is not reclining but i hear the motor clicking.. i hope its just something stuck in it.
InspireBySD is offline
Old 05-02-2013, 07:04 PM
  #88
Usman Y. Chaudhry's Avatar
Driver seat in my second gen cl stuck :(
Hey guys,
I have an 01 CL type s, the driver side seat is all the way forward and stuck i believe. When i pull the seat back button, only the left side of the seat moves back and not the right., so in a way its twisting then stops., Any suggestions please?
Usman Y. Chaudhry is offline
Old 05-05-2013, 02:49 PM
  #89
deucedeuce2000's Avatar
I had the same issue for a few months. Today I decided that I'd try to get to the bottom of it and final fix my passenger seat. I read the thread, great advice, and decided I'd try the wd40 brute force method before and disassembly. I pulled back the plastic covering the motor near the rear of the seat, pulled up the cloth so that I could see the motor and gears. I liberally sprayed wd40 into and around the gears and motor. I really soaked them. Let it sit for about an hour then got into the back seat with the seat movers all the way forward. I tried to pull back on the seat while pressing back on the recline button but had no luck. I then pressed forward on the recline button and literally pressed my shoulder into the seat back and pressed as hard as possible with my feet planted in the back seat floor. I heard a "click" and tried the recline button again. To my surprise it worked! I now have a reclining passenger seat again! Hope this helps. Good luck.
deucedeuce2000 is offline
Old 06-02-2013, 07:35 PM
  #90
Another DESI Acurziner
cgacutl's Avatar
Exclamation
HELP Pleeeeease!
I have a similar issue with my driver-side seat. A 6 inch metal rod/ flexible wire (like the one we see on bicycle brakes ) fell off and the seat does not move. (obviously!) I tried to take out the seat but the bolts on the rear side are not accessible without moving the seat forward but the does not move with the power buttons.
Is there a way to manually move the seat forward so the bolts can be accessed?
I searched the forum all weekend with no luck. I see how to get the seat out but I need to get to the rear side bolts.
Thanks in advance for your help.
cgacutl is offline
Old 06-04-2013, 05:29 AM
  #91
cgacutl's Avatar
Originally Posted by cgacutl
HELP Pleeeeease!
Anyone? please please please !!!
cgacutl is offline
Old 06-08-2013, 01:08 PM
  #92
Pnyklr's Avatar
what about with a long extension you might be able to get one
Pnyklr is offline
Old 06-08-2013, 05:55 PM
  #93
Pnyklr's Avatar
after a lot of soaking (3 hours) and me messing with it I got the passenger seat to work just took out the drivers seat and sprayed that with pb blaster I might mess with it tomorrow
Pnyklr is offline
Old 06-09-2013, 10:30 AM
  #94
cgacutl's Avatar
The problem is the seat rail that moves with seat is on top of the plastic part that covers the bolt. To get to the bolt the plastic part needs to be removed. To remove the plastic part the seat needs to move forward..
cgacutl is offline
Old 06-09-2013, 06:30 PM
  #95
Pnyklr's Avatar
well I only got the passenger set to work... and to add to it now my SRS light is on
Pnyklr is offline
Old 06-16-2013, 01:42 AM
  #96
Jill5141's Avatar
Hi TOPHER, could you help me fix my seats? My email is katherineli0109@hotmail.com
Thank you.
Jill5141 is offline
Old 06-16-2013, 02:14 AM
  #97
aameghoo's Avatar
when my seats get stuck I just sit in the seat backwards, grab the 2 metal bars for the headrest and shake the hell out of it by pushing and pulling it towards and away from me with moderate force, I aim to shake it really fast though
never seems to fail me
aameghoo is offline
Old 06-16-2013, 03:02 PM
  #98
sabohead's Avatar
I have a question for you all. My seat works fine. Except for when you pull forward on seat back to let someone in back. when you push back on seat back it "should automatically" return to last position. Mine does not. Anyone else with this problem?? Thanks in advance.
Joe
sabohead is offline
Old 08-05-2014, 07:37 PM
  #99
DavidSweet77's Avatar
Where did you put the screw driver to un jam it?
DavidSweet77 is offline
Old 08-05-2014, 09:37 PM
  #100
3.5 psi
gnuts's Avatar
On the gear and hammer it while someone pushes the recline.
gnuts is offline
Old 08-06-2014, 11:44 AM
  #101
I tried that. Are there gears on both sides of the seat?
Old 08-06-2014, 12:26 PM
  #102
3.5 psi
gnuts's Avatar
Can you see the gear move a tiny bit when you try and recline?
gnuts is offline
Old 08-06-2014, 02:26 PM
  #103
No but it moves a tiny bit when I'm sitting in my seat.
Old 08-06-2014, 02:28 PM
  #104
The back part of the seat moves, but the gear doesn't.
Old 08-06-2014, 02:45 PM
  #105
3.5 psi
gnuts's Avatar
In the pic above there is a piece of metal with rust on it near the top. The gear to the right of it is where you hammer.
Can you hear the motor clicking or making sounds when you push the button? If not the motor might be shot.
gnuts is offline
Old 08-06-2014, 03:25 PM
  #106
Yes it makes noise and the seat actualy trys to move. Do I stick the screwdriver on the gear teeth or just hit the gear with the hammer.
Old 08-06-2014, 03:58 PM
  #107
3.5 psi
gnuts's Avatar
Get a flat head and put it in the teeth and hammer the gear towards the rear of the car as someone presses the recline. I had to hammer mine pretty hard and many many times before it moved.
gnuts is offline
The following 2 users liked this post by gnuts:
Ayu688 (02-21-2015), Lance10 (02-20-2016)
Old 08-06-2014, 04:31 PM
  #108
I will try that this weekend. Thanks for all your help.
Old 08-14-2014, 11:36 AM
  #109
davy411's Avatar
honda
^ Who said I called them? LOL
Would this work on an 06 honda accord
davy411 is offline
Old 09-04-2014, 01:31 PM
  #110
orange1's Avatar
I have a long plastic covering with knobs on the side of my seat, do I just remove the knobs to access the gears? I'm having a hard time locating the 'cover' with the description.
orange1 is offline
Old 02-02-2015, 02:33 PM
  #111
r10l300c's Avatar
I need ur help to topher! r10l300@gmail.com
Originally Posted by arp408
Hey topher bro, i'm also going to need your help!!! My email is apadrinao@sbcglobal.net
Good looking out bro!!! Thanks in advanced.
Email me!! R10l300c@gmail.com
r10l300c is offline
Old 02-15-2015, 03:12 PM
  #112
Wehe_831's Avatar
Acura tsx
Hey topher can you please help me out .. My seat wont recline but you can hear the motor click.. My email is trujillo_385@yahoo.com please help me out
Wehe_831 is offline
Old 02-16-2015, 09:15 PM
  #113
TOPHER33884's Avatar
I dont think Topher is around here anymore since he sold his CL.
Meh, I do still lurk weekly, and now my head count is upwards of 43 members seat backs fixed. lol
TOPHER33884 is offline
Old 02-16-2015, 09:48 PM
  #114
Ayu688's Avatar
Hey Topher,
Can you help me out as well with same issue.
My email is ayu68828@yahoo.com
your help would be greatly appreciated.
Ayu688 is offline
Old 02-17-2015, 12:28 PM
  #115
3.5 psi
gnuts's Avatar
Ayu688. Why does he need to email you. Just post here and we'll help.
gnuts is offline
Old 02-21-2015, 02:53 PM
  #116
Ayu688's Avatar
Thanks gnuts. Literally did as you advised to place the flat head onto the gear but I placed it counterclockwise as there was more room to work with. After couple hard hits, the gear instantly freed up. Appreciate your help. This site never fails me.
Ayu688 is offline
Old 03-10-2015, 08:45 PM
  #117
johndo18's Avatar
How about fixing the seat that does not move forward or backward anymore, It reclines fine but he seat wont move forward backward or up or down..whats the fix for that...I do hear clicking when the button is pressed and thats it
johndo18 is offline
Old 08-04-2015, 03:55 PM
  #118
kbrooks0375's Avatar
manual car seat same problem
Can u guide me through how to fix a manual seat on 05 Chrysler Sebring.. My email is kbrooks.0375@gmail.com
LOL......If I was greedy, you could PayPal me some money since I just saved you $650!
kbrooks0375 is offline
Old 10-31-2015, 08:46 PM
  #119
Ahmed Nomaw's Avatar
Originally Posted by CL-S progression 01
^^^^ now that's a story. Finally using excessive force has gotten the job done
Yes same thing happen to me and I had slam the seat back and it finially worked. although my memory seat buttons are not working for some reason.
Ahmed Nomaw is offline
Old 02-19-2016, 12:35 PM
  #120
Scott Tuley's Avatar
Drivers seat issue
Just got my 05 TL about a month ago and only one of the motors to move the seat forward and back works. I want to try and replace the other.... Anyone know how to replace the motors that move the drivers seat foward and back, and where to get motors for a good price?
Scott Tuley is offline
Quick Reply: "My seat won't move/recline" thread
