2004 Acura MDX Brake Pads and Rotors
Moderator Alumnus
I have to replace my brake pads and rotors on all 4 sides in my 2004 Acura MDX. I was quoted by my local mechanic for $800.
Does this seems reasonable?
pads front and rear 85 bucks at pepboys, and I believe you can find rotors for under 50 a piece. I did the pads on my 06 my self and they are super easy. doing the rotors is not much more work. do one wheel at a time. your rotors are probably fine any way if your pads did not cut into them they should be fine.
Moderator Alumnus
^^ Thanks man! Let me know if you find anything else!
Anyone know of a reputable site to get pads/rotors?
I want to make sure the rotors are decent quality, don't want vibrations in ~10,000 miles lol
You can follow this DIY: Its basically the same thing
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/diy-rotors-pads-%2A%2Ahow-w-pictures%2A%2A-620983/
I used stock acura pads (got them at A&H motors in PA-they mail order acura & honda parts).
Moderator Alumnus
https://acurazine.com/forums/showthread.php?t=620983
Moderator Alumnus
from what I remember, two bolts per caliper and one set screw for the disk. It took me 15 minutes per side with air tools and my brother in law doing the heavy lifting for the wheels.
Moderator Alumnus
Moderator Alumnus
Gonna be taking care of the brakes in a few, any last tips/tricks? lol
Does anyone know the proper bolt torque specs for the caliper, etc?
Moderator Alumnus
Ran into a little hickup, the new brake pads I got don't have the little hole for the wishbone shaped spring to go in to? What should I do? Not use the spring? Drill the hole for it?
The springs are called 'pad spreaders'.
When I changed my brakes in October, the new pads I got didn't have the holes for them, but I knew that before I bought them(they're cheaper). I figured as long as I use the 'disc brake quiet' paste, I didn't need them.
This is the 1st vehicle I've owned with them. Also the 1st one with twin piston calipers. Don't know what their purpose is....maybe to help keep the pads away from the disc, or even the resistance because of the 2 pistons?
I don't notice any difference with or without them.
Moderator Alumnus
Yea, i just went along without them. The whole process took about 6.5 hours. I had a hard time getting the back rotors off.
Other than that everything went kinda smoothly. I hear a little noise now but I think that is supposed to go away after the break-in. Hopefully it does!
Moderator Alumnus
So everything seems to be ok as far as braking, i do hear a clunk when going forward after a moderate brake. What could this be?
Moderator Alumnus
Looks like the fronts caliper bolts had to be tightened to 101lbs/ft, just tightened them up now.
Any idea what the rear caliper brackets are supposed to be torqued to? I can't find the info anywhere.
mada51589
05-03-2022 08:54 PM
