Looking for FlashPro RDX beta testers
Old 05-12-2014, 09:13 AM
  #161
pzpos360's Avatar
Just to be clear because I apparently missed it, the Flashpro comes with the base map that a reflash would have?
Old 05-12-2014, 10:06 AM
  #162
WTF?
bluecarbonfiber's Avatar
YES that is correct
Old 05-12-2014, 10:07 AM
  #163
Tomtwtwtw's Avatar
Yes, and depending on your model year, it may come with a base map for an intake and / or fuel injectors as well. Hondata also told me that while the files themselves are not directly compatible between all years, you can manually cut / paste the fuel tables from from one tune to another to gain the same benefits.
Old 05-12-2014, 11:04 AM
  #164
pzpos360's Avatar
Thanks for the replies. I have an unmodded 07, do you request a base map for intake or injectors or does it just come with it depending on the year? I would rather it came with just the base reflash map and I can make changes as the modifications progress.
Old 05-12-2014, 12:05 PM
  #165
WTF?
comes with a a base map regardless the rest is up in the air based on the model year, my 2010 had the base and the intake reflash in the map area, you wont know till you get it and upload the map
Old 05-12-2014, 01:17 PM
  #166
Tomtwtwtw's Avatar
I believe the maps are included in the Flashpro software that you download from Hondata. You should be given the opportunity to choose which vehicle(s) you want to get flashes for, but regardless of what you choose the cable will only work with what it has been set up for.
Old 05-12-2014, 09:14 PM
  #167
FLETCH
TheWrench116's Avatar
the tunes avalible are
stock
tuned stock
k&n
600cc k&n downpipe
800cc stock
might have missed one or mislabeled but this is the general idea
I'm running the 800cc stock with all my mods I'm attempting to get tuned this Thursday.
Old 05-23-2014, 05:06 AM
  #168
PM me if you need a reply
InfamousJamous's Avatar
Been meaning to post these up a while ago...
Power mods: Hondata flashpro, C-PE intake, 3" catless exhaust, ETS TMIC, 600cc Deatschwerks injectors, P2R intake gasket
They told me over the phone that they could get 320tq to the wheels with my mods. Seemed like the tuner on shift that day didn't care.
Old 05-23-2014, 09:40 AM
  #169
WTF?
those are pretty solid numbers since you dont have a DP installed, what kind of wheels are those? you have any pics of them posted up?
Old 05-23-2014, 11:47 AM
  #170
Tomtwtwtw's Avatar
He has a DP...at least I assume by the '3" catless exhaust'. Should be able to get more power out of that, but it really depends on the turbo's capabilities at this point. Looks like you boost is hitting 14 lb and dropping to 12 by redline, which I think is about the same as the basic Hondata flash. Now that you have injectors, put that turbo to work and see if you can get better numbers. I'd love to see one hit 300 at the wheel. Or at least 275 for AWD.
Old 05-23-2014, 04:31 PM
  #171
FLETCH
I made 264 today without touching the boost pressure just messed with the fuel a little and added 1 degree to base timing that was it went from 224 to 264.
Old 05-23-2014, 10:53 PM
  #172
But I do have a DP on a 3" turboback so the numbers seem kinda weak. The tuner played it safe.
The wheels are 20x10 +40 Gianelle Yerevans.
I just uploaded more pics of the car at https://acurazine.com/forums/members/infamousjamous-297615-albums-2011-15927/.
bluecarbonfiber (05-30-2014)
Old 05-30-2014, 10:39 AM
  #173
WTF?
forgot to ask you have any sound clips of the exhaust? i am debating on if i want to do a catless or have a cat for the DP.. I am hoping it wont have highway drone.. or sound raspy trying to stay away from that on the rdx
Old 06-04-2014, 07:45 AM
  #174
FLETCH
all you notice is SPOOL!!! at least with the cp-e intake. the exhaust is very mild.
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
SeaJay
09-30-2015 09:15 AM
San Yasin
09-29-2015 10:52 AM
dirleton
09-29-2015 08:26 AM
Quick Reply: Looking for FlashPro RDX beta testers
