Mothers Mag and Aluminum polish...thoughts ?
Old 04-12-2011, 06:19 PM
SilverJ's Avatar
I purchased this product to hopefully have less brake dust on my TL-S wheels. The instructions say when you begin to apply it that there should be like a black soot look to the wheel as your rubbing it in and if you dont see that stop rubbing it as that surface cant be polished. I did not see any soot as I was rubbing it in Am I missing something here? I generally have never polished any rims before but these get SO loaded with brake dust from the brembos I figured if something could help I will try it.
http://www.mothers.com/02_products/05100-05101.html
Old 04-12-2011, 06:25 PM
dinks07's Avatar
Yes mothers works awesome just keep polishing it till its gone
Old 04-12-2011, 06:38 PM
NTMD8
jimsta's Avatar
You are using the wrong product. THat is for non-clear coated products, bare metal polish.
Stock rims are painted and clear coated. You can just use car wax or polish on your rims.
Old 04-12-2011, 10:28 PM
Comptechtl2367's Avatar
Agreed, that is the wrong stuff for clear coated wheels!!!
It works great on exhaust tips and non coated wheels. Get some all wheel cleaner or some simple green to clean your wheels!
Old 04-12-2011, 11:04 PM
Former Whiner
Souljah's Avatar
word
Old 04-13-2011, 07:42 AM
vinnier6's Avatar
stop using that on painted surfaces....its for bare metal...
Old 04-13-2011, 08:50 AM
Jesstzn's Avatar
Actually using that is going to haze the clear on the wheels.
Old 04-14-2011, 11:14 AM
SilverJ's Avatar
k
thanks guys. Hopefully I can return this stuff to walmart. I have wheel cleaner. I was hoping to put some type of polish on the rims to make it a little easier to clean off the vaunted brembo brake dust.
Old 04-14-2011, 11:22 AM
vinnier6's Avatar
keep it and use it on your exhaust tips....
as for your wheels, i would take a cleaner wax clean the wheels up, then put a synthetic sealant on them....
if your just looking for something you can get at walmart, try the meguiars nxt...its a sealant with cleaner in it....
Old 04-14-2011, 12:43 PM
SilverJ's Avatar
Thanks. NXT Wax and sealant ? Whats the exact name of the product ?
Old 04-14-2011, 12:51 PM
Jesstzn's Avatar
A cleaner wax before a sealant isn't a good idea .. the sealants need a good clean surface to bond to.
Use your wheel cleaner to get them clean then do a wipe down using a 50/50 mix of rubbing alcohol & water to prep the surface and a great sealant/protectant for the wheels is NuFinish liquid. Available at Walmart .. its durable & cheap.
Nothing on the market is going to stop the brake dust. But a good sealant on the wheels every few months will make them easier to clean.
Just a hint tho... brake dust can become acidic once it is exposed to moisture so wash the wheels often.
I have a sealant on mine and never use anything but the til end of my car wash water and a dedicated mitt to clean them.
Old 04-14-2011, 02:06 PM
CU2MIKE's Avatar
^ Dale, I'm glad I have matte black wheels, can't tell if they are dirty of not, haha.
Old 04-14-2011, 02:52 PM
Jesstzn's Avatar
Cheater lol
Old 04-14-2011, 04:59 PM
CU2MIKE's Avatar
Originally Posted by Jesstzn
Cheater lol
Less work the better brotha, lol.
These days I'm so busy with school work I started doing "protect and neglected", lol.
Old 04-14-2011, 05:23 PM
v|nsan|ty's Avatar
I scored some KSG half off at eshine recently. That will be my dedicated wheel sealant
Old 04-15-2011, 03:01 PM
SilverJ's Avatar
OK thanks. Nu-Finish eh ? I will look at walmart. Is there anything else to the name ? Like is it called Nufinish protectant ?
Also wouldnt rubbing alcohol/water mix be harmful to the clear coat ?
Old 04-15-2011, 03:16 PM
Jesstzn's Avatar
NuFinish once a year car polish
If rubbing alcohol was harmful I wouldn't have recommended it
HOWELLiNC
Wash & Wax
35
07-16-2017 04:13 PM
kixo
09-25-2015 03:07 PM
09-17-2015 09:01 PM
Quick Reply: Mothers Mag and Aluminum polish...thoughts ?
