19" petrol vengeance
Old 04-09-2012, 03:04 PM
rlawson's Avatar
I have a 2006 acura tl base automatic but Im considering purchasing a set of 19" petrol vengeance 235/40/19 or 235/45/19 Im worried they will cause any sort of mechanical issues. Does anyone have any suggestions whether I should stay away from that size or will it be a bolt on wheel and not have to worry about any thing with the transmission?? please helppp!!
Old 04-09-2012, 03:08 PM
JD TL-S's Avatar
I went with 245/35/19" the best size tire for a 19" rim. Or 235/35/19"
A 235/40/19" tire is about 1/2" higher. I think the only problem with be the speedo will be off a few MPH.
When your going 30mph, your speedo will say aprox 28mph
I suggest 245/35/19" tires !!!
Old 04-09-2012, 03:27 PM
Happy Holidays!
Silver_Surfer's Avatar
245 should be fine for the rear but 245 for the front may rub though depending on the offset of the wheels. Just a little caution.
Old 04-09-2012, 05:58 PM
1qwik6's Avatar
run a 235/35/19 and you wont have any problems at all
Old 04-10-2012, 08:10 AM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
What's the offset?
Old 04-10-2012, 02:15 PM
rlawson's Avatar
thanks Ill look into it. He had them on TL 6 speed so I'm assuming they will fit with no problem. I just figured I would get some advise first. I think the offset is 35...but Im not sure yet
Old 04-10-2012, 03:42 PM
JD TL-S's Avatar
^^^ Thats the offset I had on a set of 19"x8.5" wheels on my long gone 06 TL 6-speed
+35 all around with 245/35/19" Tires and lowered 1.7" front and back. No rubbing at all.
rlawson (04-10-2012)
Old 04-11-2012, 10:07 PM
rlawson's Avatar
There they are 235/35/19 fit perfect!
09-21-2015 08:44 AM
09-17-2015 10:16 AM
stangg172004
06-30-2006 09:14 PM
Zoot
12-05-2003 06:30 AM
Quick Reply: 19" petrol vengeance
