New Exhaust Tips!
Old 04-11-2013, 03:28 PM
Packagingpro's Avatar
New Exhaust Tips!
After much researching, I was finally able to pull the trigger on new exhaust tips. I have a FWD TL and did not want to do a full exhaust or catback. I did want the 4" Quad Tips. I totally credit Matt on Acurazine for doing this first. Tips cost $132.00 shipped from Ebay + $100.00 to install. Very Happy, So Far!
Size:  92.4 KB[URL=http://s384.photobucket.com/user/packagingpro/media/IMG_1357copy.jpg.html]Name:  IMG_1357copy.jpg
Size:  82.7 KB[/URLName:  IMG_1359Copy.jpg
Size:  101.3 KBName:  IMG_1360Copy.jpg
Illmatics (04-28-2015)
Old 04-11-2013, 03:31 PM
if you like it; then thats all that matters.
however; i would take the stock set up over those. they do not fill in or match the bumper cutout
Old 04-11-2013, 06:26 PM
TheOMan's Avatar
I like it - looks good. Did they have to cutoff the stock tips and weld these on?
Old 04-11-2013, 06:42 PM
takin care of Business in
swoosh's Avatar
+1 with Justin....
I wish the tips were a little bit bigger...
Old 04-11-2013, 07:09 PM
potmilkz's Avatar
even though tips are 4 inch.. they look rather small compared to my atlp which is the same size..
there is a lot of gap on the top side of the exhaust. maybe you should move it up a bit.... but given the choice.. i rather have spent 300 dollars on magnaflow muffer and tips.. just my take on it.
Old 04-11-2013, 07:16 PM
VQPower37's Avatar
FWIW ... i think they look good, esp for the price you paid for em
justnspace (04-11-2013)
Old 04-11-2013, 08:22 PM
Danyoung's Avatar
They look fantastic, love the car, love how clean it looks. That chrome trunk deck lid...on point!
Old 04-11-2013, 08:45 PM
types1fan's Avatar
I like it
Old 04-11-2013, 08:53 PM
KB1Spec's Avatar
Nice!
Old 04-11-2013, 09:14 PM
Matts_Acura's Avatar
Look good! I think the dude should have made the tips sit higher though. They are plenty big but since there is a gap between the bumper it makes them appear smaller.
Old 04-11-2013, 09:22 PM
itsryanftw's Avatar
I agree with Matt here. The space would be filled out if they were welded more straight on center and higher up.
On my 2012 bumper (see below), it fits great. I told my installer exactly how I wanted it installed, and when he tack welded the tips on, I gave him the OK to proceed with the full weld.
In the end, these are 4 inch tips... even on a 2009-2011 bumper, just copy how the ATLP's sit, and they should look fine.
Old 04-11-2013, 09:59 PM
I was not able to go any higher or more to the center. This was the best the installer could do without modifying the rest of the exhaust.
Old 04-12-2013, 12:19 AM
vivmike's Avatar
A good welder can do anything YOU want. Even build you a complete exhaust system.
Old 04-12-2013, 01:32 AM
silkk8482's Avatar
Love those tips!! Do you think it would fit on a 3G base TL?
Old 04-12-2013, 07:19 AM
They would fit a Type S bumper but not the base bumper.
justnspace (04-12-2013)
Old 04-13-2013, 08:14 PM
msubee's Avatar
eBay link for the tips?
Old 04-13-2013, 09:21 PM
Try this!
http://rover.ebay.com/rover/0/e11400...OC%3AUS%3A3160
The following 2 users liked this post by Packagingpro:
ej6sliver (06-21-2014), msubee (04-14-2013)
Old 04-14-2013, 12:41 PM
jdm_fanatix's Avatar
looks good. wish it was more centered and higher though how much were these ?
Old 04-14-2013, 01:26 PM
si1point6's Avatar
Looks good - big improvement over the OEM tips
Old 04-14-2013, 02:01 PM
Jamdc5's Avatar
I was gonna say stock tips look better but having those tips closer to the bumper makes it look much better!
Old 04-14-2013, 03:13 PM
Keep in mind this is an inexpensive way to get the 4" quad tip look. There are some flaws when installing them on a 09-11 TL. The tips need to be raised and moved over about a 1/2 inch, which is not possible without additional mods to the stock exhaust. I do feel they look better in person than on the pictures. I have been sick of looking at the stock tips and wanted a change. I saved the old tips and they can be welded back on at any time. Last, I drive my car on over 24,000 miles per year and wanted to retain the stock exhaust and keep the quietness of the car. I have been in TL's and other Honda's with Catbacks and Magnaflow Muffler Only systems and they do get to loud for my taste and have drone.
Old 04-14-2013, 03:42 PM
itsryanftw's Avatar
Matt had his installed on his 09-11 TL, and he had the installer weld the tips straight on to the mufflers. I have a 2012 TL, and I followed the same direction.
In fact, he specified that key point in his build thread, so that's what I told my installer to do. Looking at both of our install pics, we have similar results.
If you chop off about an inch off the back of the new tip and have your installer weld it straight onto the muffler, then the exhaust holes will still line up, and they could be brought more to center and up.
If I ever wanted to switch back stock tips, I'd just have the cut pipe from the original tip welded back in place and then spray paint the new weld flat black.
Old 04-14-2013, 03:52 PM
I had the new tips cut down at the manufactured weld and the installer welded them directly to the muffler. They were welded so they could be at the highest point and farthest to the right. I am not sure why my would come out different that Matts. Maybe the tip changed slightly!
Old 04-14-2013, 05:54 PM
bugfam4's Avatar
I have a 2010 TL SH-AWD and I went with the 3.5" from So Cal AutoSports and they worked out well and fit in the stock opening pretty well.
http://www.socal-autosports.com/35-quad-exhaust-tips
Old 04-14-2013, 08:53 PM
Can you post some pictures?
Old 04-15-2013, 05:02 AM
KarKraze's Avatar
Those tips are available with different inlet sizes,it may be possible that your set has a smaller inlet than Matt's,as a result you cannot move them further to the right or upwards,just a thought.
Old 04-15-2013, 05:36 AM
The inlet on mine were 3", same as Matt.
Old 04-15-2013, 08:19 AM
I actually got the 2.5 inlets. Maybe that's why they were able to move them up a little more.
Another option may be to adjust the rubber that the exhaust hangers are on. Maybe find some shorter ones which would pull it up a bit.
On another note.... I love that damn color!
Old 04-15-2013, 08:36 AM
I bet the shape of the tips are actually different. If I have a bigger inlet, in theory, I would have more room to adjust the position.
Old 04-16-2013, 08:07 PM
vivmike's Avatar
I got mine welded on today. The welder put them on perfect. No gap.
Old 04-28-2013, 01:19 PM
brandontnguyen's Avatar
They look great!
Old 04-28-2013, 05:02 PM
Steven Bell's Avatar
I like them-very sweet!
Old 05-09-2013, 10:17 PM
8th Gear
bwptl13's Avatar
Anyone have pics of how a quad round tip exhaust would look on a tl without the lip kit besides the one posted on top. I'am thinking about pulling the trigger but I think it will look funny without the rear lip kit.
Old 05-09-2013, 10:28 PM
8th Gear
bwptl13's Avatar
nevermind found it here:
https://acurazine.com/forums/showthr...=877798&page=6
sweet cat MAtt
Old 05-10-2013, 02:55 PM
chriscraig2010's Avatar
Do you still have your original tips? I am looking to buy a set to put on a 3g.
Old 05-10-2013, 04:05 PM
I am keeping mine.
Old 05-19-2013, 05:56 PM
PinotGrigio's Avatar
I think they make that rear end look a lot meaner
Old 05-19-2013, 06:54 PM
I was able to get another muffler shop to heat up the exhaust and move the tips up and over. They now look even better!
Old 05-19-2013, 07:40 PM
RICHDAKIDD's Avatar
I think they look good especially for what you pay for them also see you have that radar system, Is that the passport?
Old 05-19-2013, 08:33 PM
I have the K40 RL360 with the laser diffusers, 2 jammer heads on front and one on the back. Wanted the more stealth look over the escort/passport. I have been saved several times and the laser diffusers have been tested by actual police I know!
Quick Reply: New Exhaust Tips!
