Starter motor heat shielding?
Old 07-18-2014, 06:58 PM
dcmodels's Avatar
Question Starter motor heat shielding?
Many factors affect the life of a starter motor, but certainly HEAT is one - excessive heat can shorten the life of the starter. There are only a few threads, of higher mileage RDX starter failures.
On inline engines the exhaust often runs past the starter motor, but not so on the RDX. Would a heat shield or heat "blanket" provide protection to an RDX starter? or would that only cause more heat-soak?
After all, the radiator fan is blowing directly onto the starter. Engine coolant radiator "exhaust" heat is not nearly as high as exhaust pipe heat radiation onto a starter.
Any comments, thoughts, or ideas for increasing the life of an RDX starter?
Old 07-19-2014, 10:18 PM
sinnersahuayo's Avatar
you could wrap the starter and also the exhaust?
08KBP_VA
10-22-2019 01:55 PM
xsilverhawkx
09-28-2015 06:51 PM
agupta3224
09-22-2015 08:08 PM
Quick Reply: Starter motor heat shielding?
