Front Left Driveshaft Replacement
Old 06-30-2014, 08:40 PM
djbarber's Avatar
Took my 2007 RDX to dealer to fix a few things and they commented on a rusted left-front driveshaft (rusted near the boot??). Recommended replacing it saying it will eventually fail. Anyone else had this issue? Also, started looking up how to replace this thing using the ALLDATA website/service manual. It says to drain transmission fluid when replacing the left front drive shaft, but in the replacement section it says to refill transmission fluid if the right drive shaft has been replaced. Anyone have a factory manual that can confirm which driveshaft requires tranny fluid drain/refill? Thanks!
Old 07-01-2014, 04:18 PM
DRR98's Avatar
We have an "11 with 67k mi and just had the same one replaced. it caused some vibration on full throttle and thump/knock a few times on cold mornings. Did not last long.
Old 07-01-2014, 05:11 PM
DevilDogDoc's Avatar
I've gotten away with jacking the car up on the side the half shaft that is bad on and had minimal fluid loss. Buuuut that's been on manual cars, not sure on the autos.
Old 07-01-2014, 09:09 PM
mack1611's Avatar
[IMG]Front Left Driveshaft Replacement-7zmpprd.png[/IMG]
08 NBP TL
09-08-2015 08:49 PM
RK_AcuraTL
09-05-2015 02:26 AM
DRR98
1G RDX Problems & Fixes
09-02-2015 10:52 AM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Front Left Driveshaft Replacement
