Question for those that have the ETS IC
Old 06-26-2014, 08:12 PM
Tomtwtwtw's Avatar
Did it come with a separate screw for the MAP sensor that plugs into the corner of the IC? I'm talking about the little 8mm screw, not any of the 10mm.
Thanks~
Old 06-26-2014, 08:33 PM
Tomtwtwtw's Avatar
Or some kind of gasket or o-ring for the recirc valve?
Old 06-27-2014, 01:57 PM
Tomtwtwtw's Avatar
So it turns out the MAP sensor bolt hole on the ETS IC fits the same size as the rest of the bolts that hold it in place, so I just went and got the correct length / size bolt from Ace for 60 cents.
For another 60 cents I bought a large, flat rubber washer and trimmed it to fit between the recirc valve and IC. I just don't trust a metal to metal connection to hold pressure. Maybe it's just me?
Still not sure if the IC comes with these two things normally, but just in case I figured I'd post up my cheap and easy solution.
ttimberlak443
21
10-22-2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
Quick Reply: Question for those that have the ETS IC
