Serpentine belt diagram
Old 06-16-2014, 06:15 PM
8th Gear
pjsblowngt's Avatar
Does anyone have a serpentine belt diagram? There's not one under my hood, or in the manual, and I did not take note to its position upon removal. Thanks!
Old 06-17-2014, 01:13 PM
8th Gear
pjsblowngt's Avatar
I found a generic picture of one through Google images & managed to figure it out. Take note to its routing before you remove one. It'll save ya the hassle down the road!
Old 06-22-2014, 02:37 PM
littleblazer's Avatar
Check Dayco.com and log year,model,engine should be belt routing any cars...even timing belt...
Old 06-24-2014, 03:50 AM
dcmodels's Avatar
Check the pics in the following link. I will note that I was unable, even with the *special-belt-tool* I purchased, to route the belt without access below, around the lower pulleys. I remove the belt OK, just could not get it back on, until ...
I removed the splash shield, located between the front bumper cover, and the front frame cross member (large round tube). That will allow access behind the passenger side wheel, because the splash shield also covers part of the area of the belt and pulleys.
https://acurazine.com/forums/showthread.php?p=14629541#post14629541
08KBP_VA
10-22-2019 01:55 PM
brboy
10-05-2015 11:34 AM
Jboat
09-30-2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Serpentine belt diagram
