DIY - Rear Differential oil change
Old 06-30-2012, 07:25 PM
wifesRDXtech's Avatar
Originally Posted by Bruce Banner
I can't imagine fitting under the car to get those bolts off without jacking it up.
Is there some trick to doing this?
What fluid does everyone recommend? I'm eyeballing the Mobil stuff.
On models with SH-AWD...Rear Differential Fluid" it indicates, "Use Acura All-Wheel Drive Fluid (DPSF) only.
My original fill was the ATF Acura stuf and now is superseded with DPSF. I wouldn't use anything other that in rear dif.
Old 08-01-2012, 08:55 AM
larryt1026's Avatar
I'm a bit confused after reading through all that twice..I drive a RDX non-AWD.
So does all rear differential oil changes uses DPSF? Or is the DPSF ONLY for the SH_AWD RDX's?
Since I do not have AWD, do I use DW-1 (now that the ATF-Z1 is discountinued) for both the rear differential and the transmission fluid?
Thank you!
Old 08-01-2012, 09:05 AM
Thank you!
very good question, i assume your set up would be fwd only and you do not have a rear differential? On my car its a front differential i guess built into the tranny then behind it a transfer case with a drive shaft to the rear differntial to make it awd. your's probably doesnt have transfer case rear drive shaft and rear differential?
Old 08-01-2012, 09:08 AM
Thank you!
In regards to your tranny use the new stuff, I found a dealer online in MA that ships a case to your home cheaper then buying at dealer local.
Old 10-05-2012, 10:42 AM
Ilovedoughnuts's Avatar
Does anyone know if there is a small electric gear oil pump available? It might save alot of time under the RDX in small tight spaces while on the ground?
Old 10-05-2012, 01:02 PM
DRR98's Avatar
^yes. I saw one on motorweek for trans that have no drain plug. It snaked in through the dipstick hole into the trans pan. Seems like that might work for you. Google it.
Old 10-06-2012, 05:52 PM
  #47
Gear Oil Dispenser
I am curious if anyone has tried the Mityvac MITMV6400 Fluid Dispensing System for the differential? I wondered how it might work because temperature might limit how well well the fluid would flow. But if it did work even say during warm summer months it would save alot of manual work.
Here is a link where you can get it with a picture:
http://shopping.yahoo.com/851755898-...ensing-system/
Here is the video link:
Old 10-22-2012, 11:39 PM
user65's Avatar
OP thanks for saving me $$$. Much appreciated! Dealer wanted $99. Took me less than an hour and I learned something new.
Old 10-26-2012, 04:47 PM
  #49
vaprea's Avatar
Easy as 3.14
Did this today, very easy DIY and well worth the the piece of mind.
The magnetic end of the drain plug was clean. not-one visible metal shaving.
Picked up the washers last month, Typically Acura has them in stock.
One note* I had the use my impact gun on the fill/drain plugs, they would not budge by hand!
Old 12-12-2012, 06:38 PM
  #50
IndecisiveDude's Avatar
Excellent write up, did this basic maintence this weekend and it took me about an hour, including a 15 minute drive to warm up the fluid.
One comment, I bought a Valvoline Qt bottle pump and NAPA and it took over 200 stroke to empty a quart bottle. Damn. Over 500 strokes later, I was done.
That is all....
sometimesIride (12-31-2013)
Old 12-12-2012, 07:47 PM
  #51
dcmodels's Avatar
That is all....
And I thought that I was the only one to do that (count). Same Valvoline pump and same number of strokes - counted the second time I did this job to keep from going crazy laying on the cold cement garage floor.
Old 12-13-2012, 06:04 AM
  #52
I did the job with this : http://www.harborfreight.com/multi-u...ump-66418.html
It was a lot less than 500 pumps, but not sure if this pump will last too long its cheaply made.
Old 12-13-2012, 10:23 PM
  #53
haole kama'a-ina
737 Jock's Avatar
That is all....
500 strokes on the cold garage floor? Ya'll boys got some stamina.
I used the outboard motor oil pump on the previous page. I didn't really count 'em, but I think I finished in about 80-90 strokes.
Old 03-23-2013, 11:27 AM
  #54
kingkong222's Avatar
Called the dealership today and they asked me 'which differential, front or rear'? I didn't know that RDX has front differential. Can someone confirm? Or are they yanking my tail?
Old 03-23-2013, 11:58 AM
  #55
That dealer is incorrect, there is a front transaxle that is part of tranny, transfer case and a rear differential only. Unless you have front wheel drive then no transfer case or rear diff.
Old 03-23-2013, 03:55 PM
  #56
I came in the dealer to pick up the diff fluid. The guy almost gave me the transmission fluid which is 1 gallon VTF I believe, Anyhow, I told him it comes in a smaller bottle. He looked at me all confused. I showed him the pic and he was like, 'oh my bad'.
Old 03-23-2013, 04:17 PM
  #57
I think he almost gave you fluid for mdx.
Old 05-15-2013, 10:43 AM
  #58
haole kama'a-ina
737 Jock's Avatar
Just did my 4th diff change. This time I let it go about 30k miles and the ATF-Z1 came out looking cherry and smelling clean. The was almost nothing on the magnet. Overnight drain yielded a few onces shy of 3 quarts.
Put in DPSF for the first time. No noticable difference. Drives and feels identical to ATF-Z1.
Old 05-15-2013, 11:07 AM
  #59
Thanks for the update! Have DPSF fluid in for 10 k miles now , probably will wait till another 20 k miles to change it.
Old 05-26-2014, 01:34 AM
  #60
ska325xi's Avatar
did this today and the bolts were getting rusty and would not bulge. I had to use some pb blaster and had to jack one side of the rear up to give myself more room for the wrench. Im not a big guy and the space is very limited.
once I have the bolts out i used a mityvac fluid pump to fill....piece of cake
Old 05-26-2014, 01:35 AM
  #61
ska325xi's Avatar
im going to invest on a impact gun...no more breakin knuckles
Old 05-27-2014, 02:01 AM
  #62
dcmodels's Avatar
Originally Posted by ska325xi
did this today and the bolts were getting rusty and would not bulge. ...
The bolts are not *stuck* because they are rusty. The bolt itself does not touch the aluminum differential case. The bolt touches only the washer, except for the threads, which are lubed with the oil in the drain/ fill holes.
And only the washer touches the case. The bolt is harder to remove than install, because the aluminum washer galls (cold welds) to the aluminum case, esp if installed dry - I apply ATF/ DPSF to the washer before installation, and reduce the torque by 10%.
You can use a Q-tip and dielectric grease on the steel bolt, and around the OUTSIDE of the aluminum washer, to prevent the bolt from rusting, and the aluminum washer from corroding to the aluminum case. Do NOT apply the grease, until AFTER the bolt is installed. Otherwise, it will cause you to over-torque the bolt.
Improper use of an impact gun can damage the aluminum diff case/ drain hole threads. I find that holding the end of the wrench with one hand, and a very firm bump against that hand with the palm of my other hand, is usually sufficient to break loose the bolt.
Old 11-29-2014, 06:43 PM
  #63
SinCity's Avatar
Third time around for "6" service (84k miles). PITA in removing the fill bolt. I gave up trying to muscle my way on the drain bolt and used a floor jack to push against the wrench to loosen it.
Old 12-09-2014, 09:14 PM
  #64
GASKICKER's Avatar
Is there anything other than dpsf that can be used? Also, will the mid tell me when this needs to be done, or should i just do it every 30k? Mostly higheay miles, just got the rl and trying to learn all i can.
Old 02-03-2015, 05:53 PM
  #65
sharwag's Avatar
Thank you for this write up!
Old 04-04-2015, 06:14 PM
  #66
hunter2054's Avatar
I need help - I cannot locate the rear differential filler and drain plugs on my wife's 2014 rdx - Can someone point me in the right direction? - thiw should be easy - thanks
Old 04-05-2015, 09:03 AM
  #67
SinCity's Avatar
Originally Posted by hunter2054
i need help - i cannot locate the rear differential filler and drain plugs on my wife's 2014 rdx - can someone point me in the right direction? - thiw should be easy - thanks
awd?
Old 04-05-2015, 07:21 PM
  #68
hunter2054's Avatar
Thanks -i will look in the daylight - happy easter
Old 05-04-2015, 04:30 PM
  #69
ndangkhoa's Avatar
OP thanks for saving me $$. Much appreciated!. Took me less than an hour and I learned something new and even did this for other AWD cars we owed
Old 12-06-2015, 11:01 PM
  #70
RobbDizzle's Avatar
Bumping and old thread with a question: is the ATF-DW1 an acceptable substitute for the Z1? Ive read that the DW is the successor to the Z1
Old 12-08-2015, 12:17 PM
  #71
Jdrum1's Avatar
08200-9007A | Acura All-Wheel Drive Fluid (DPSF) - Bernardi Parts
Old 03-07-2016, 08:54 AM
  #72
af145's Avatar
Acura Customer Service advice
Just talked to Acura Customer Service. They said the correct rear differential fluid is ATF-DW1. Acura RDX 2008.
As a side issue, they mentioned an air bag recall coming out in June.
Old 03-07-2016, 10:01 AM
  #73
your dealer is incorrect I would call them back . I just changed mine rear diff fluid and have been using this fluid which is the recommended fluid by Acura:
Old 03-07-2016, 10:44 AM
  #74
af145's Avatar
This wasn't no dealer. I called the central Acura Customer Service, gave them my VIN and stuff.
Old 03-07-2016, 11:04 AM
  #75
Originally Posted by lndiferrent
This week I went to an Acura dealer and asked for a rear differential fluid for 2008 RDX. The salesman gave me three ATF-DW1 quarts. Since I've already seen this topic, I asked him isn't DPSF supposed to be used in rear differentials? He told me that ATF-DW1 is a replacement fluid for ATF-Z1 and that is what they use in rear differentials now. Then I looked on the back of the container and it clearly says "Not to be used in rear differential and clutch cases" and I asked him about that. He repeated again that they use DW1 in rear differentials but if I want, he can order DPSF for me since they don'y have it in stock right now. He also mentioned that DPSF costs twice as much.
Since this was a reputable Acura dealer I decided to buy DW1 and trust their judgement. However, something just didn't sound right about that and a couple of days later I decided to ask another Acura dealer in the area for a second opinion. I told them the story and their mechanic immediately told me that I don't want to put DW1 in the rear differential and I should use DPSF instead. They were even kind enough to swap DW1 I got from the first dealer for DPSF - without extra charge.
see this Above, do not put DW1 in rear only DPSF
Old 03-07-2016, 11:19 AM
  #76
af145's Avatar
Saw this. OTOH, Amazon says DPSF does not fit my car. That's why I called them. If you can't believe central Customer Service, who can you believe?
Old 03-07-2016, 12:39 PM
  #77
I would call another dealer or go to a local dealer and look at the bottle DW1 it will say do not use in differential. Would not trust Acura customer service person or Amazon .
Old 09-18-2016, 11:17 AM
  #78
2005 Acura RL
cyberquest's Avatar
i have a 2005 RL and its rear diff is setup a little different then what is shown in this thread. i found a great tutorial video on youtube for the 05-08 RL models and he shows the drain plugs for both the diff case and the clutch case. very informative video so i thought i would share it.
Old 03-06-2017, 10:51 PM
  #79
heykosal's Avatar
I'm sorry to seemingly beat a dead horse, I just want a clear answer. Should I use DW-1, or DPSF?
Old 03-07-2017, 09:00 AM
  #80
af145's Avatar
Dpsf
For what it's worth, I ended up using DPSF. That was 1 year and 10K miles ago. No problems so far.
heykosal (03-07-2017)
Quick Reply: DIY - Rear Differential oil change
