Acura Service News and TSB's for the RDX
Old 04-11-2010, 08:58 PM
mau108's Avatar
Looks like Sasair has been out for a while.
I will update this post with any new tsb's related to the RDX. I have combined Sasair's work and will be updating this page often.
Service News:
2006
July - New RDX uses Mobile 1
August - right power mirror problem on early VINs, software update to improve shift quality, engine won't start/immobilizer blinks
September - nothing RDX specific
October - AC fan noise cycling frequently, satin finish chrome and water spots, AcuraLink communication setup
November - roof rack weight limits, front door courtesy light lens falling off, nav map matching, software update to fix brake system problem, TPMS info
December - Nothing RDX specific
2007
January - Dead Audio Unit, Side Moulding Install Tips
February - AT solenoid, Homelink
March - Roof rack covers, DST, outside temp logic
April - Parasitic current draw, cutting roof moldings
May - HFL Locked, No sound or data from XM
June - Engine block coolant separator
July - MAF Sensor, Window Tint, TPMS
August - VSA troubleshooting, Running Fuel Tank Dry
September - Window regulator reset
October - Nothing RDX Specific
November - TPMS Info, Metallic Window Tint, SRS DTC, Nav Info, Interior Lights stay on, Security System, HFL 1 of 5
December - HFL 2 of 5
2008
January - HFL 3 of 5
February Poor Audio Quality, HFL 4 of 5
March - VSA Indicator On after repair, MIL with aftermarket intake, HFL 5 of 5
April - Can't Turn VSA Off?
May - Nothing RDX Specific
June - AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied, DTC P2422
July - Excessive Parasitic Draw? Check If the B-CAN System Is Awake
August - No Communication Between HDS and VSA Modulator-Control Unit
September - Tailgate Outer Handle Not Working
November - Nothing RDX Specific
December - Nothing RDX Specific
2009
January - SRS DTCs 32-xx and 31-xx Are Strictly About the Side Airbags
February - Homelink, Power Mirrors
March - DTC P0325 Knock Sensor
April - Nothing
May - Nothing
June - Nothing
July - Broken Valve stems, Tire Sealant, XM cuts out
August - TPMS, Power Window Reset
September - DTC P0341
October - Nothing
November - Nothing
December - DTC(s) P0171, P0174
2010
January - Lower Front Door Sill Seal Is Loose or Hanging Down
February - Nothing
March - Nothing
April - Nothing
May - Nothing
June - Nothing
July - Nothing
TSBs:
mau108 is offline
Old 04-24-2010, 07:29 PM
mau108's Avatar
new TSB
mau108 is offline
Old 08-17-2010, 03:52 PM
LuvMyTSX's Avatar
Links fixed.
LuvMyTSX is offline
Old 10-27-2010, 03:41 PM
LuvMyTSX's Avatar
Sorry everyone, but it looks like our access to the TSBs has been removed. Not sure if we will be able to get these back up again.
LuvMyTSX is offline
rseb4agze
05-03-2016 07:41 AM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
DRR98
1G RDX Problems & Fixes
09-02-2015 10:52 AM
Quick Reply: Acura Service News and TSB's for the RDX
