Serpentine belt diagram
8th Gear
Does anyone have a serpentine belt diagram? There's not one under my hood, or in the manual, and I did not take note to its position upon removal. Thanks!
8th Gear
I found a generic picture of one through Google images & managed to figure it out. Take note to its routing before you remove one. It'll save ya the hassle down the road!
Check the pics in the following link. I will note that I was unable, even with the *special-belt-tool* I purchased, to route the belt without access below, around the lower pulleys. I remove the belt OK, just could not get it back on, until ...
I removed the splash shield, located between the front bumper cover, and the front frame cross member (large round tube). That will allow access behind the passenger side wheel, because the splash shield also covers part of the area of the belt and pulleys.
https://acurazine.com/forums/showthread.php?p=14629541#post14629541
rp_guy
07-16-2017 07:33 AM
