DIY - Transfer Fluid change
haole kama'a-ina
Perform Do-It-Yourself auto maintenance at your own risk. You can kill or injure someone or damage the car. Raise an auto only on a level, concrete floor. Do not go under any auto unless you are completely certain that it is secure. You and only you, are responsible for your work and safety.
There are many ways to raise an auto for service. Jacks, ramps, scissor lifts and stands, etc. All auto lifts share a few traits, though: they are cunning -- they hate you -- and they want you dead! The RDX weighs 3950 pounds. If it falls on you, that's 3850 more than it needs to crush your skull and emboss the phrase "engine oil" in mirror image on your forehead . DO NOT go under an auto unless you are completely certain it is secure!
Front and rear, left and right is ALWAYS related to the car itself, NOT how you are facing it:
LEFT is always the DRIVER side.
RIGHT is always the PASSENGER side.
Text relates to the picture below the text.
Parts and tools needed:
1. Hypoid gear oil, API classified GL4 or GL5: 430 ml (0.45 qt). SAE 90 above -18 C (0 F) and SAE 80W-90 below -18 C -- or --
2. If the above is not available, one quart of Mobil 1 or Castrol Syntec synthetic 75W-90 will do fine.
3. A hand pump for installing the oil.
4. 3/8" drive ratchet and short extension.
5. Small torque wrench (preferred).
6. Spirit level.
7. Eye protection, face protection, gloves and protective clothes.
8. Drain pans, newspapers, rags, etc.
To change the Transfer Fluid, insure that the engine is cool or only slightly warm. Then make sure the RDX is raised and level. This is so the fill port will hold the correct amount. Place a spirit level along the rocker panels, under the doors:
The transfer unit is attached to the rear, right-side of the transmission. It has a fill plug facing forward and a drain plug on the bottom. It may be dirty, but it should be dry with no evidence of leaks:
Always loosen the fill plug first. This is to insure you can refill the transfer before you begin to drain it.
The transfer fill and drain plugs are identical and only require a 3/8" drive to turn (no sockets). Using the 3/8" drive ratchet and a short extension, break the torque on the fill plug. Remove the fill plug to check the oil level. It should be just at the bottom of the fill port and some may drip out. Reinstall the fill plug loosely.
Prepare a container to catch the fluid and remove the drain plug. I use a container with a sight gauge so I can measure the old fluid quantity:
Here is the sight gauge showing exactly the 430 ml (.045 qt) of drained oil that the RDX manual specifies:
When it stops dripping, clean the transfer and any traces of oil. This is to facilitate the leak check later. Replace the drain plug seal washer with a new one (part 94109-20000). The fill plug uses the same washer, but it may last through 2 uses if it's not over-torqued. Here is the seal washer package:
As an option, apply a bit of thread sealant to the plugs. Install and torque the drain plug enough to crush the seal washer slightly (44 N-m, or 33 ft-lb).
I use an outboard motor oil pump to fill the transfer. This screws right on to the gear oil bottle and the metal fitting on the hose end fits snugly into the fill port. For minor top-offs, I use a MixMizer syringe. Both are pictured below and are available at auto parts stores. (For the SH-AWD differential service, I have a second outboard motor oil pump and MixMizer syringe. This prevents contamination between the gear oil and ATF-Z1.)
The RDX Service Manual calls for SAE 90 gear oil above -18 C ( 0 F) and SAE 80W-90 below -18 C. That's pretty hard stuff to find. I have used Castrol Syntec and Mobil 1, 75W-90 synthetic for several years with excellent results:
Position a container under the transfer to catch overflow. Pump the gear oil into the transfer fill port, using the sight gauge on the bottle to monitor the progress. The RDX Service Manual specifies 430 ml (0.45 qt) to the bottom of the fill port.
When it begins to spill out, let it slow to a trickle and install the fill plug (44 N-m, 33 ft-lb). Wipe everything clean. Clean up all tools and items. Lower the car and take it for a drive around the neighborhood -- get it up to temperature. Now look under and check the transfer again for leaks. This is why cleanup was important earlier -- the bottom of the engine must be clean and dry to identify any leaks.
6. Spirit level.
The following 5 users liked this post by 737 Jock:
Fireboy (12-03-2016),
jojo32m (07-20-2023),
sleepless247 (08-25-2011),
wifesRDXtech (08-25-2017),
x2lacrosse (07-02-2013)
cobra10363 (09-21-2015)
haole kama'a-ina
Thanks wspy.
I should mention that the standard torque settings apply to new seal washers only. If re-using a seal washer, run it down to contact, then only about 30 -45 degrees farther turn (up to 1/8 turn) to seal it. Don't over-torque it. It can always be tightened a bit, if it seeps on the leak check.
Cool was planning on doing this this weekend along with DW1 in the transmission and rear diff as well as engine oil.
Helm's says to fill it until it starts to come out the fill hole.
thanks for the great diy guides, very detailed. do you happen to know what the oem fluid is? also will the royal purple max gear oil as well?
http://royalpurple.com/gear-oil.html
haole kama'a-ina
As far as I've been able to determine, the transfer oil is one that there is no "genuine" Honda OEM fluid for. The Pilot, CR-V, Ridgeline, MDX and RDX manuals show only the specification listed above.
It is nearly impossible to find this spec. The dealers probably use bulk stock of whatever 90-ish oil they get a good price on. Most DIYers use a good synthetic 75W-90.
^i only found 1 80w-90 gear oil by mobil one. will this work?
http://www.mobiloil.com/USA-English/...us_80W-90.aspx
haole kama'a-ina
Well, the weight of 80W-90 is per Honda spec but I'm a little put-off by the statement on the Mobilube HD site:
This stuff is clearly heavy-duty for commercial trucks, hence GL-5 only.
Honda specs GL-4 or GL-5. I would stay with a gear oil that is also spec'ed GL-4 or GL-5.
The commercial grade GL-5 is designed for high temps and pressures -- which it will not reach in the RDX -- it will not be in its designed service range.
Not recommended for applications requiring API GL-4 Level performance.
I personally use Mobil 1 75W90, which is readily available from any of the local auto parts stores. The Mobil 1 web site tech data page for this product, does state that it can be used for GL-4, but is primarily intended for GL-5 (my understanding of the data page). I personally would not use it when ONLY a GL-4 product is required. I think it is great for both my RDX transfer case, and my Chevy truck axles.
The GL-4 spec is intended to protect 'yellow' metal, such as bushings etc. GL-5 products often will 'attack'/ corrode these metals. I am guessing that the additives in Mobil 1 75W90 are such that brass/ bronze (yellow) is not at risk, assuming that these metals are in the RDX transfer case. So I like the Mobil 1 because of the RDX Acura GL-4/ GL-5 spec.
For those who are interested in such things (I am an engineer), there is a 'white paper' comparing gear lubes, published by AmsOil. Note that I have no relationship to that company, have never used their products, and found this information while searching for something to use instead of the $38/ quart GM OEM gear lube, for my Chevy truck.
I have seen various links to the document, but here is one on the AmsOil site.
http://www.amsoil.com/lit/g2457.pdf
Use this stuff. There is no higher quality gear oil available on the market.
http://www.amsoil.com/storefront/svg.aspx
This is Amsoil's severe gear lubricant and it can be used in API GL-4 and GL-5 applications.
haole kama'a-ina
I live in the snow belt, and both my local dealers state that they use Valvoline non-synthetic 80W90 bulk.
It's the active sulfur in the Extreme Pressure additives in the GL-5 which has corroded yellow metals. They now claim that modern formulations of GL-5 are inhibited from attacking yellow metals.
The term active sulfur refers to the relative ability of a sulfur-containing compound to chemically react with a metal surface to form a metal sulfide. Inactive sulfur compounds do not form metal sulfides under test or operating conditions. The tendency of a sulfur-containing additive to react with a metal surface depends on the composition of the additive, the reaction temperature and the oxidation state of the sulfur in the compound.
Modern EP gear oils contain thermally stable additives that promote system cleanliness and do not corrode yellow metals under moderate operating conditions. The goal in formulating top-tier EP gear oils is to develop additive chemistries that will carry high loads under boundary conditions and protect mating surfaces from wear while minimizing corrosiveness to yellow metals and keeping steel gear components clean.
We don't know if the RDX transfer contains any yellow metal bushings or parts. Honda says we can use GL-4 or GL-5. Translation: GL-4 is good enough, but GL-5 won't hurt. This could be because the transfer contains no yellow metals or because the newer formulations are safe. But I've been using Mobil 1 and Castrol Syntec with no apparent problems for 4 years.
Keeping in mind that EP additives can decompose under high temperature and form metal sulfides, I change the transfer every 30k with the tranny.
Thanks for that info dc.
It's the active sulfur in the Extreme Pressure additives in the GL-5 which has corroded yellow metals. They now claim that modern formulations of GL-5 are inhibited from attacking yellow metals. ...
[your quote above]Modern EP gear oils contain thermally stable additives that promote system cleanliness and do not corrode yellow metals under moderate operating conditions.
That seems like good advice.
haole kama'a-ina
And I always use only a GL5 (or GL4/5) rated oil when there is a hypoid gear involved, as in the RDX transfer case.....Now, what I find amazing, is that the front differential (which has 'sort-of-but-not-really' hypoid gears), runs in ATF, which is why I change the transmission fluid more often than the MID specifies.
Great DIY , I was able to do it without raising rdx. I used mobile 1 75w 90 syn gear oil. I think I found one that matches exact requirements in manual. See link: http://matrixsyntheticoils.com/datas...0_gear_oil.pdf
Maybe try that stuff next time not sure if it's synthetic though.
737, your DIY's are just great, among the best ever and many thanks for your time and efforts on them.
So if you re-fill 'til it drips anyway, is keeping track of the amount that came out important?
haole kama'a-ina
Not really.
It's just helpful to verify that it wasn't leaking. But if the transfer case is not dirty and greasy, that's pretty good evidence that it wasn't leaking also.
Not really.
RangeRider49er (11-28-2013)
Using Amsoil
I am using the Amsoil 75W-90 synthetic as suggested by DigitalSniper on this thread. http://www.amsoil.com/shop/by-produc...ont%2fsvg.aspx It is rated gl4/gl5 and has excellent low temp. flow characteristics. Since I live in a low temp environment in Colorado where temps can get as low as -25F it should be a good choice. Excellent thread 737jock.
Need new pump for bigger bottle mouth
I actually used a different Amsoil but I think it should work. I used this stuff: http://www.amsoil.com/shop/by-produc...?code=FGRQT-EA They say it is okay for GL4 & GL5 and it shold last forever!
Using Amsoil
I actually used a different Amsoil but I think it should work. I used this stuff: http://www.amsoil.com/shop/by-produc...?code=FGRQT-EA They say it is okay for GL4 & GL5 and it should last forever!
"The Long Life 75W90 is one of the recommended gear oils to use in this transfer case. It will be equal in performance to the Severe Gear lube in this application."
considering how little the front transfer case takes, I found I have over .5 quarts of each.... lets get some opinion on what I should put in...
redline 75w90 mt-90 gl4
http://www.redlineoil.com/product.aspx?pid=46
redline 75w90 gear oil gl5
amsoil 75w90 gl4 gear oil
http://www.amsoil.com/shop/by-produc...r-lube-75w-90/
Red Line 57904 (75W90) Synthetic Gear Oil - 1 Quart : Amazon.com : Automotive
You're referring to the maintenance code displayed? Cycle the display to the oil life%, hold the reset button for 10 seconds or so and the option to reset will come up. Select reset and hold for another 10 seconds or so and you're done.
FYI i have been using Mobile 1 75W-90 , but on next transfer fluid change coming up i have purchase the 80w-90 synthetic from Amsoil on their site :
https://www.amsoil.com/shop/by-produ...?code=AGLQT-EA
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
