'04 TL A-Spec MT Suspension Question
I've been searching for a couple weeks now but I'm not really making any head way for the part numbers for the rear suspension (Spring/Coil assembly). When I'm searching on a parts websites, most don't give you an option to select the A-Spec trim package so I've been leery about placing any orders. However, the rear end of my car is squatting really low and I'm scrapping more and more going over bumps and humps in the road; especially if I put anything in the backseat and even more so in the trunk.
So I have two questions for you guys; first, from what I'm describing can someone confirm that I need to replace the rear spring/coils? Second, can someone give me part numbers and different places to get these parts?
Some additional information: The car has 114,000 miles on it and I replaced the Rear Sway Bar End Links roughly 2 months ago.
Thanks ahead of time for any help.
Do you have the A Spec suspension on the car?
If so, don't believe any A Spec suspension parts available.
Unusual for the rear to drop, but if it has, the suspension is kaput, or at least something has gone by the wayside.
Did you check for a broken spring? Leaking shock?
End links that were replaced, factory style or adjustable?
^Agree. If the rear is squatting you likely have a blown shock or broken spring. There is no A-Spec trim, that's why your not seeing it listed anywhere. It was a dealer accessory. You can only get it from Acura. Contact one of our vendors. The 201-B kit is for the MT cars, You may not be able to get it anymore? not sure.
MrHeeltoe
79
10-14-2015 08:47 AM
nuldabz
09-03-2015 05:49 PM
