TSX Dynos
Old 06-09-2008, 01:34 PM
  #441
CarbonGray Earl's Avatar
Originally Posted by godfather2
^ the hell if i know! i was toooo damn hot to even think to ask that. seriously, it was torture out there. i'll dyno again once my new header, cat, p2r img, and hondata have been installed. e.t.a. about 2 months
@ the heat. good showing considering the factors, can't wait to see what you get once you have the new stuff.
Old 06-09-2008, 01:58 PM
  #442
JTso's Avatar
$40 for 3 runs, i guess you get what you pay for: they only gave me a print out of my best run (#2) and it only shows hp, no tq numbers. here you go:
Huh? no correction method or engine rpm either. You need to go find another dyno shop the next time.
Old 06-09-2008, 02:32 PM
  #443
Time to Climb
godfather2's Avatar
tell me about it. blue ridge motorsports brought their rolling dyno to crown honda here in charlotte. i knew $40 sounded too good to be true
Old 06-09-2008, 06:23 PM
  #444
Rep'n Taxbrain.com
Tsx536's Avatar
Originally Posted by DAYTA
Btw, I noticed the numbers look a bit low compared to what I hit (15-20whp/10-15wtq).
Beyond the Mugen vs Comptech part difference, did you check how much boost you're getting? It could be that you're not at the 5-6psi you're supposed to be getting.
Yeah, you're numbers do seem a little low, especially for an 06. But then again, it looks like it was pretty hot when you ran the dyno. I would look into getting boost gauge or maybe see if the dyno can read boost levels too. Make sure that you're getting proper boost levels.
Also, make sure that the belt has enough tension. Sometimes a loose belt can cause lower boost levels too. Do you happen to know your belt size? You're running the Autotensioner setup, correct? Do you have a manual tranny?
Old 06-22-2008, 10:17 AM
  #445
Time to Climb
godfather2's Avatar
<embed src="http://www.veoh.com/veohplayer.swf?permalinkId=&id=12880478&player=vid eodetailsembedded&videoAutoPlay=0" allowFullScreen="true" width="410" height="341" bgcolor="#FFFFFF" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed><br/><a href="http://www.veoh.com/">Online Videos by Veoh.com</a>
Old 06-22-2008, 10:19 AM
  #446
Time to Climb
godfather2's Avatar
here's a crappy vid of my dyno runs:
http://www.veoh.com/videos/v142538596wre6FfG
Old 07-01-2008, 02:59 PM
  #447
808havok_tsx's Avatar
Originally Posted by tsxdriver
just got back from the dyno. power= 234.50, torque= 175.88
done on the same dynojet i went to last time. SAE Smoothing 5. 91.78 degrees. good enough for me
shit reading the above comments i noticed you guys said to turn off the vsa. frick what if i didn't?
dude, where did you dyno and how much was it?
Old 08-22-2008, 04:15 PM
  #448
06PWPssshh's Avatar
Some descent numbers on here.. I like the variety of set ups everyone is running. A lot of info on this thread. I'm hoping to re-dyno my car soon. So I'll try and post mine up along with a video clip as soon as I get it done.... Trying for 215whp with my bolt ons..I/H/E for now..
Old 08-26-2008, 06:14 PM
  #449
WTF?
bluecarbonfiber's Avatar
so i been reading everyones dyno pulls.. but havent seen many AT tsx'x what is the average for those i feel mine was pretty low for what it should of been.. I have the 04 reflash dc exhaust and header,tb bypass,hondata intake manifold gasket and injen intake.. when i dyno ran it was only 178.99 hp and 141.22 tq.. i did have 93 octane in the car not sure if that makes a difference and im pretty sure the vsa was on (read it should be off) any other reason why i might not be hitting atleast 200?
Old 08-28-2008, 08:15 PM
  #450
06PWPssshh's Avatar
Your dyno sounds pretty accurate with your mods if your dynoing on a DYNOJET...Which is pretty on point in comparisson to a DYNAPAC..And thats to the wheels.. To the crank your easily over 200hp..If you go to Church's I'm sure you'll be over 200..
Old 08-28-2008, 11:35 PM
  #451
WTF?
cool i wasnt sure.. seemed like i should be more like 180+ and 150 tq.. of course i still need to make a fw adjustments and re-dyno.. and it was a dynojet winpep CF is uncorrected and smoothing is 5.. have to admit though the tq is solid all the way from 3Kto 7K and it was in 4th gear pull
Old 08-29-2008, 02:05 PM
  #452
06PWPssshh's Avatar
Your relatively close to that....3k to 7k feels great in our cars.. I could only imagine if it was boosted... I got 166Tq...Out of my bolt ons...Could of got more if I had a cat....
Old 11-24-2008, 10:47 PM
  #453
Unregistered User
valeratj's Avatar
I do not see the sheets anymore. where did they go ?
Old 02-07-2009, 03:20 PM
  #454
gamblez's Avatar
07 tsx mt
Mods are
Greddy Sp2
Comptech headers
Comptech ice box
NST pulleys
RT High flow cat
ingalls ETD
Second run was 203 WHP but i guess the first one is more accurate
Old 02-07-2009, 03:32 PM
  #455
gamblez's Avatar
video link to run,
hear the vtec kick in
Old 03-25-2009, 02:59 PM
  #456
2006 ASM tsx
vthree's Avatar
did a dyno run today:
2006 MT
k&n intake, ct headers,exhaust, rt cat, tb coolant bypass mod, ingalls etd, and hondata reflash
i'll have vids up soon waiting for youtube to finish processing..
i guess 205.5 wasn't too bad right??
Old 03-25-2009, 03:02 PM
  #457
2006 ASM tsx
vthree's Avatar
Originally Posted by gamblez
Mods are
Greddy Sp2
Comptech headers
Comptech ice box
NST pulleys
RT High flow cat
ingalls ETD
dang, i wonder if your pulleys made that much of a difference? compared to mine?? ... and you dont even have a hondata reflash
Old 03-25-2009, 03:16 PM
  #458
2006 ASM tsx
vthree's Avatar
videos:
http://www.youtube.com/watch?v=AgeRVVXqoAc
http://www.youtube.com/watch?v=DL4uCJWE6L8
Last edited by vthree; 03-25-2009 at 03:17 PM. Reason: trying to get videos to post..
Old 04-02-2009, 07:20 PM
  #459
Member
hondata's Avatar
Preliminary results from testing this morning.
04 MT TSX:
- 06 TSX intake cam
- 06 TSX TB - 64mm
- 45 Degree VTC cam pulley
- Hytech headers & exhaust
- High Flow cat
- Injen intake with (very) dirty air filter
- CT supercharger & injectors
- 3.3 pulley with 1920mm belt
- VTEC point 3000 RPM
Notes:
- Torque is wheel torque not engine torque. Engine torque is 225 ft pounds
- Red line dirty air filter
- Green line velocity stack no air filter
Old 07-14-2009, 12:40 PM
  #460
TodaSi's Avatar
Well I was able to get a base dyno done....finally
The dynojet I am using is elevated and set-up for RWD cars. The fans are in the wall blowing out (away from a FWD car) and they have no fan blowing on the the engine/radiator. By my second run my intake temps were well over 120*F.
So far on the car I only have:
2005 Acura TSX 6 speed Manual
removed resonator
Non Stop pulleys
I did three runs, the first run was 171.09 whp, second was 164.06 (these runs don't have the torque rating as we were trying to figure where to get the tach signal (of the three wires).
Last run we got the correct wire and were able to get the torque rating, by then the engine well rather hot, but it is still a decent base to go by, enjoy.
Old 09-30-2009, 09:53 AM
  #461
9th Gear
quaidvc's Avatar
where is a good place that can dyno my car local in OC
Old 10-09-2009, 01:47 PM
  #462
Rep'n Taxbrain.com
Tsx536's Avatar
04 TSX 5AT Auto Tranny - 108K Miles
Hondata TSX K-Pro - Dual ECU Setup
Comptech / CT-E Supercharger with 8 psi / 3.15" Pulley
Comptech / CT-E Icebox with K&N Filter
Comptech / CT-E 520 CC Fuel Injectors
Comptech / CT-E Auto Tensioner (Prevents belt slip)
DC Sports Header with 2" Vibrant TurboFlex Pipe
2.25" FastLine Performance Hi Flow CAT from HeelToe Auto
Stock OEM Exhaust
Denso IK20 Spark Plugs (Stock)
04 Throttle body with Throttle Body Coolant Bypass
Stock VTC (25 degree max cam angle)
More info: https://acurazine.com/forums/1g-tsx-performance-parts-modifications-126/review-dyno-vid-hondata-k-pro-fully-tuned-ct-e-supercharger-auto-5at-265hp-199tq-734778/
Stock Auto TSX vs. SCed Auto TSX
Old 04-16-2010, 09:20 PM
  #463
PatJo_09's Avatar
mean
Old 04-16-2010, 09:22 PM
  #464
PatJo_09's Avatar
nice!!
Old 07-02-2010, 03:57 PM
  #465
carcrazyboy68's Avatar
wow....kinda getting mixed results on intake and exhaust....all i have on my 06 mt is a k&n intake (short ram) and a simple cat back exhaust...i wish i still had my paper from skoo when i did my run on a dynojet but i got 190hp and 168tq. and what is the stock power to the wheel for the 06? also is there a street legal s/c for the tsx?
Old 08-07-2010, 10:10 PM
  #466
Pete0028's Avatar
Anyone ever use a performance chip and if so did they see any noticeable results.
Old 12-16-2010, 09:01 PM
  #467
stellarsteve90's Avatar
Does anybody know of a dyno shop in the eastern Pa area?
Old 01-16-2011, 05:40 PM
  #468
L.A. > the rest
SLIKRIK's Avatar
Talking
OK here it is:
2005 AT
57K
Performance:
Injen SP1431/short ram
FLP Cat
UR Pulley
Hondata Reflash
S2K AP2 tips
Peak hp/torque:
187.6/149.4
Where:
MD Automotive
Westminster, CA
DYNOJET
Sportshift, 3rd gear
VSA off!!!
Correction: SAE
Smoothing: 4...although i think it should've been at 5?
Temperature: 78
Humidity: 24%
pretty consistent numbers as u can see.
i wish i would've dynoed when i was bone stock to compare.
C/C
Old 01-16-2011, 05:54 PM
  #469
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Old 01-16-2011, 07:21 PM
  #470
L.A. > the rest
SLIKRIK's Avatar
Originally Posted by princelybug
Thx for the recommendation.
Old 05-23-2016, 01:29 PM
  #471
me3
me3's Avatar
Old 05-23-2016, 01:30 PM
  #472
me3
me3's Avatar
tsx_boy
12-13-2019 08:33 PM
mlody
12-04-2019 02:11 PM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
GWEEDOspeedo
01-15-2016 10:39 PM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: TSX Dynos
