Notices
Parts Search
Keyword:
Category:
Price:
Location (State/Prov/Terr):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Location (State/Prov):
FS: 2004 Acura TL remaining parts
Old 12-15-2016, 08:19 PM
NAiL05's Avatar
Category: Accessories
Price: $100
Location (State/Prov/Terr): TX
Item Condition: Used
I have some parts leftover from my 2004 Acura TL. Everything is located in Dallas, TX and I prefer to keep it local. I can ship certain items but I prefer local pickup if possible. I also can work on some of the prices if necessary. If you would like better pictures feel free to PM me or just post in this thread. ALL THESE PRICES DO NOT INCLUDE SHIPPING. I included an FB link to the album just in case pictures don't upload here - https://www.facebook.com/media/set/?...1&l=f00b3fe555
Items I have for sale are:
Available parts off of vehicle for now (Parts that have been removed):
- 2004 Acura TL clock module non nav - 10.00
- Rear engine motor mount - 20.00 for manual tl
- Power steering pump - 50.00 Rebuilt by my coworker (honda tech) using factory honda seals. Does not come with pulley due to it being damaged during wreck but other than that everything else works.
- Both front axles - Manual - 100.00 (Oreilly reman and only used for two days before the accident. Will possibly need new center nuts. Price is for both)
- Stock brake lines for brembo - 20.00
- Injen CAI filter only - 20.00
- Door panels - 100.00 for all of them (All show wear and some have damage. Please see pictures posted. If anymore questions please ask)
- Factory rear bumper w/ A spec (base) rear lip - 250.00 - It will need to be repainted but everything is there
-Sunroof Glass - OEM Honda - 100.00 (has sunroof seal but it is worn. It will need to be replaced)
-Vehicle Glass - 50.00 per glass (All four plus both quarter glasses on the rear door. All glass is OEM honda)
-Rear Taillights w/rear corner markers - 100.00 (I noticed the left LED board starting to act up...it still illuminates but it has a few spots where it will not light up. The right side i fine. LED board will come with both of these tail lights.
-Door lock actuators - 20.00 Each. (I have all four for the vehicle and they will come with the cables)
-Window Regulators w/motor - Fronts - 60.00 each (Both fronts have been replaced with OEM regulators. Driver side been in there for about a year and Passenger side about 5 months. Rears - 30.00 each
-Acura Sidesills for the door - 60.00 (for all four)
-Factory Head unit w/Climate control assembly - 250.00 Yes I do have the codes to activate head unit also. I did notice the climate control led in the temp up and down might be burnt out but switches operate when cycled.
-Full spare tire assembly w/tools (For Brembo) - 80.00
-A/C Vents - 20.00 Each. Passenger and Driver - shows normal wear from a high mileage vehicle
- RV6 V3 J pipe (comes with Gaskets) - 200.00 - Has small dent on front of J pipe and one of the flex pipes has a bit of wear.
- Comptech Cat back w/Mid muffler - 500.00
- A/C Compressor - 200.00 (Factory Denso unit. Replaced January (only used for month before accident) so pretty much new)
- Accelerator Pedal sensor - 75.00. ( Works fine replaced around the 145k stage of the vehicle)
- Racing brake front two piece rotors Has slight dishing due to using an aggressive pad. Did not notice any warping under hard braking scenarios - 150.00 for both
- Racing brake Rear rotors has slight dishing - 140.00 for both
- Factory front brembo rotors - 40.00 for both (resurfaced)
- Windshield washer tank w/motor (everything works fine)- 25.00
- Engine trim pieces - 40.00
- Map light assembly with homelink has comes with two LED's - 40.00 (the reflectors were machined a bit so the bigger LED bulbs would fit.
- Black mirrors - 60.00 for both (There is slight damage on the Passenger side due to fender being pushed into it...shown in the pictures) They will also need the actuators due to them not operating...which I have for sale also.
- Black gas cap cover - 10.00
- ABS Actuator - 60.00
- Gauge Cluster/Bezel - 50.00
- Upper Control Arms (factory)- 100.00 for both - The upper balljoints are still tight. Bushings look like they are in good condition.
- Brembo Acura front brake calipers/ss lines plus rear calipers/ss lines included with EBC yellow stuff pads (Pads have about 60-70% of life both front and rear) - 400.00
- Front knuckle (both) - 150.00 (Noticed one of the lower balljoints torn.) Will not come with rotor. Included will be bearings, lbj, dust shield. Good for if you need or want to do the type S brembo brakes. I would recommend balljoint replacement.
- OEM HID Ballast - 40.00 - only have one side.
-AEM V1 - 450.00 - Bought new. Only removed sticker to see if Honda OBD1 plugs would fit. It was made for a 3000gt if I remember correctly.
Attached Thumbnails 2004 Acura TL remaining parts-1.jpg   2004 Acura TL remaining parts-2.jpg   2004 Acura TL remaining parts-3.jpg   2004 Acura TL remaining parts-4.jpg   2004 Acura TL remaining parts-5.jpg
2004 Acura TL remaining parts-6.jpg   2004 Acura TL remaining parts-7.jpg   2004 Acura TL remaining parts-8.jpg   2004 Acura TL remaining parts-9.jpg   2004 Acura TL remaining parts-11.jpg
2004 Acura TL remaining parts-12.jpg   2004 Acura TL remaining parts-13.jpg   2004 Acura TL remaining parts-14.jpg   2004 Acura TL remaining parts-15.jpg   2004 Acura TL remaining parts-16.jpg
2004 Acura TL remaining parts-17.jpg   2004 Acura TL remaining parts-18.jpg   2004 Acura TL remaining parts-19.jpg   2004 Acura TL remaining parts-20.jpg   2004 Acura TL remaining parts-21.jpg
2004 Acura TL remaining parts-22.jpg   2004 Acura TL remaining parts-23.jpg   2004 Acura TL remaining parts-24.jpg   2004 Acura TL remaining parts-25.jpg   2004 Acura TL remaining parts-26.jpg
2004 Acura TL remaining parts-27.jpg   2004 Acura TL remaining parts-28.jpg   2004 Acura TL remaining parts-29.jpg   2004 Acura TL remaining parts-30.jpg   2004 Acura TL remaining parts-31.jpg
2004 Acura TL remaining parts-33.jpg   2004 Acura TL remaining parts-34.jpg   2004 Acura TL remaining parts-35.jpg   2004 Acura TL remaining parts-36.jpg   2004 Acura TL remaining parts-37.jpg
2004 Acura TL remaining parts-38.jpg   2004 Acura TL remaining parts-39.jpg   2004 Acura TL remaining parts-40.jpg   2004 Acura TL remaining parts-41.jpg   2004 Acura TL remaining parts-42.jpg
2004 Acura TL remaining parts-43.jpg   2004 Acura TL remaining parts-44.jpg   2004 Acura TL remaining parts-45.jpg   2004 Acura TL remaining parts-46.jpg   2004 Acura TL remaining parts-47.jpg
2004 Acura TL remaining parts-48.jpg   2004 Acura TL remaining parts-49.jpg   2004 Acura TL remaining parts-50.jpg   2004 Acura TL remaining parts-51.jpg   2004 Acura TL remaining parts-52.jpg
2004 Acura TL remaining parts-53.jpg   2004 Acura TL remaining parts-54.jpg   2004 Acura TL remaining parts-55.jpg   2004 Acura TL remaining parts-56.jpg   2004 Acura TL remaining parts-57.jpg
2004 Acura TL remaining parts-58.jpg   2004 Acura TL remaining parts-59.jpg   2004 Acura TL remaining parts-60.jpg   2004 Acura TL remaining parts-61.jpg   2004 Acura TL remaining parts-62.jpg
2004 Acura TL remaining parts-63.jpg   2004 Acura TL remaining parts-64.jpg   2004 Acura TL remaining parts-65.jpg   2004 Acura TL remaining parts-66.jpg   2004 Acura TL remaining parts-67.jpg
2004 Acura TL remaining parts-68.jpg   2004 Acura TL remaining parts-69.jpg   2004 Acura TL remaining parts-70.jpg   2004 Acura TL remaining parts-71.jpg   2004 Acura TL remaining parts-72.jpg
2004 Acura TL remaining parts-73.jpg   2004 Acura TL remaining parts-74.jpg   2004 Acura TL remaining parts-75.jpg   2004 Acura TL remaining parts-76.jpg   2004 Acura TL remaining parts-77.jpg
2004 Acura TL remaining parts-78.jpg   2004 Acura TL remaining parts-79.jpg   2004 Acura TL remaining parts-80.jpg   2004 Acura TL remaining parts-81.jpg   2004 Acura TL remaining parts-82.jpg
2004 Acura TL remaining parts-83.jpg   2004 Acura TL remaining parts-84.jpg   2004 Acura TL remaining parts-85.jpg   2004 Acura TL remaining parts-86.jpg   2004 Acura TL remaining parts-87.jpg
NAiL05 is offline
Old 01-08-2017, 12:02 AM
wusty23jd's Avatar
I just PM'd you about the map light assembly
wusty23jd is offline
Old 01-08-2017, 10:37 PM
Duronn's Avatar
I'll take the rear engine mount from you. Is it OEM?
Duronn is offline
Old 01-09-2017, 03:11 PM
NAiL05's Avatar
Yessir it is. Just let me know when you want to swing by!
NAiL05 is offline
Old 01-10-2017, 01:16 AM
Duronn's Avatar
Sweet! I'll hit you up this weekend.
Duronn is offline
Old 01-11-2017, 07:23 PM
NAiL05's Avatar
Sounds good to me. Did you still need that washer tank also?
NAiL05 is offline
Old 01-11-2017, 09:10 PM
Duronn's Avatar
Nah, I went ahead & used to methanol tank that came w/ the kit
Duronn is offline
Old 01-15-2017, 08:29 AM
bluetl04's Avatar
Do you still have the comptech exhaust?
bluetl04 is offline
Old 01-26-2017, 06:49 PM
NAiL05's Avatar
Just an update on items sold since I cannot update the first post.
- Comptech Exhaust
- Brake calipers/pads/lines
- Rear motor mount
NAiL05 is offline
Old 02-09-2017, 09:22 PM
Ltfa182's Avatar
Pm ed about the Jpipe
Ltfa182 is offline
Old 02-11-2017, 05:25 PM
Living it up TL style
coltlauer's Avatar
I noticed that you had posted pics of the A-Spec rear bumper but i didnt see it in your price listings. Are you intending on selling this as well and if so what price are you asking and are you willing to ship?
coltlauer is offline
Old 02-11-2017, 06:07 PM
Administrator
Ron A's Avatar
It is in the list of parts in the first post, 12 lines down.
Or, you can search for "bumper".
Ron A is offline
Old 02-22-2017, 08:51 PM
NAiL05's Avatar
Thanks Ron. But bump for post!
NAiL05 is offline
Old 03-07-2017, 08:15 PM
NAiL05's Avatar
Bump!
NAiL05 is offline
Old 03-07-2017, 10:39 PM
A.Sensation's Avatar
A-Spec Rear Spoiler
How much for the rear spoiler? Is everything in good condition and ready to be mounted?
A.Sensation is offline
Old 03-08-2017, 07:40 PM
NAiL05's Avatar
I do not have the Aspec rear spoiler anymore. I sold it with the trunk. I do however still have the rear aspec lip for base models that I am trying to get rid of with the rear bumper if that is what you are asking. I prefer not to sell separately at this time.
NAiL05 is offline
Old 03-08-2017, 07:41 PM
How much? Can I get some possible pics?
Old 03-12-2017, 08:24 PM
NAiL05's Avatar
Pictures are about halfway down on the first post with all the pictures attached under it. If there is something specific that isnt on there just let me know and I will snap a few more. The mounting hardware and everything is still attached to the rear bumper.
NAiL05 is offline
Old 03-16-2017, 03:33 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
what's the final mileage of the car?
TacoBello is offline
Old 03-16-2017, 07:40 PM
NAiL05's Avatar
It was close to 203.000 miles...Definitely had another 100,000 in it after I did all the maintenance on it.
NAiL05 is offline
Old 03-19-2017, 09:44 PM
k3v11n's Avatar
Interested in the PowerSteering pump. PM Sent
k3v11n is offline
Old 03-27-2017, 07:47 PM
NAiL05's Avatar
All PM's replied. Some couldn't due to inbox being full. Anyway to update list Engine covers were sold today.
NAiL05 is offline
Old 03-31-2017, 06:20 PM
NAiL05's Avatar
Driver side window motor/regulator assembly sold today. I have replied to all pms. If you have not got a response from me most likely your inbox is full.
NAiL05 is offline
Old 04-18-2017, 10:41 PM
NAiL05's Avatar
AEM V1 is sold!
NAiL05 is offline
Old 04-19-2017, 10:39 PM
randomassguy123's Avatar
Do you still have the ASPEC rear lip? Shipped to 95121?
randomassguy123 is offline
Old 04-20-2017, 12:27 PM
NAiL05's Avatar
I have the Aspec rear lip but I prefer to sell it with the bumper. It is pending sale at this time.
NAiL05 is offline
Old 04-21-2017, 09:33 PM
skd2k1's Avatar
Do you have the part that the battery cover connects to? I think it's called the battery sleeve.
https://www.acuraoemparts.com/oem-pa...9tYXRpYw%3D%3D
skd2k1 is offline
Old 04-21-2017, 10:16 PM
KaiserK's Avatar
Condition of the doorsills?
KaiserK is offline
Old 04-24-2017, 11:42 AM
NAiL05's Avatar
I believe I only have the bottom section to that not the top as indicated in the picture.
NAiL05 is offline
Old 04-24-2017, 11:43 AM
NAiL05's Avatar
The doorsills are in good condition have some scratches here and there but not chipped or dented from what I could see. I can double check or if you want better pictures I can get some.
NAiL05 is offline
Old 04-26-2017, 03:02 PM
juvndelgvdo's Avatar
Still selling the j pipe?
juvndelgvdo is offline
Old 04-27-2017, 11:19 AM
NAiL05's Avatar
The jpipe is temporarily pending at this time. I will let you know if it falls through.
NAiL05 is offline
Old 05-02-2017, 07:41 PM
NAiL05's Avatar
Jpipe buyer has backed out it is not pending anymore.
NAiL05 is offline
Old 05-08-2017, 01:50 AM
AD-TL04's Avatar
Is the center A/C vent still available?
AD-TL04 is offline
Old 05-08-2017, 09:13 PM
NAiL05's Avatar
No sir. All I have left are the left and right vent. Center vent was picked up by a local.
NAiL05 is offline
Old 05-09-2017, 01:19 PM
Moved to the LOU
twigglius's Avatar
Willing to separate the radio from the 2 screens? I need the screens but don't need the radio itself.
twigglius is offline
Old 05-10-2017, 08:51 PM
NAiL05's Avatar
Yessir I can do that. Just need a zip for shipping purposes. The only thing if I remember was the temperature adjustment arrows were burnt out but they work. Prob just need new bulbs. Everything else lit up for the most part. I can do 60 + whatever shipping costs are for it.
NAiL05 is offline
Old 05-11-2017, 03:11 PM
lownslow07's Avatar
Interested in the Brembo setup.
Pm'd
lownslow07 is offline
Old 05-13-2017, 05:15 PM
Moved to the LOU
twigglius's Avatar
63303 and what's your PayPal?
Old 05-13-2017, 05:32 PM
ABP UA6's Avatar
Is the j pipe still available? Does it delete the 3rd cat?
ABP UA6 is offline
