Damn DC Sports header...
Old Aug 10, 2010 | 10:00 PM
curls's Avatar
Someone stole "My Garage"
So I got a DC Sports 4-2-1 header, V2, just over 3 years ago (May 2007). In that time, I have had the original weld at the flange reinforced, and I have had the flex pipe changed 2 friggin' times (May 2008, Aug 17, 2009). Surprise surprise, the flex pipe is on its way out AGAIN -- just before the 1 year warranty on the part (none on labour) runs out next week.
I'm sick and tired of this bullcrap with DC Sports. I've had the header lengthened by about 3/8" to 'prevent' this -- apparently it hasn't helped.
Are there any chronic problems with the COMPTECH header? I am going to swap this out for a Comptech soon if the Comptech should be a better part.
Any opinions?
Does anyone else with the DC header have this kind of bad luck with the flex pipe? Hell I even installed an ingalls ETD on near-max stiffness to curb engine movement, and it still hasn't helped at all.
ARGH. DC SPORTS -- YOU SUCK!!
Old Aug 11, 2010 | 05:48 PM
cor6bro's Avatar
Sorry to hear.
The CT header is ok, but it tends to rattle at idle with the A/C on. It’s a real pain sometimes; but you choose you poison, I guess. I’ve had mine for about a year and it seems to be holding up well. In addition I had mine coated by jet-hot, so I can’t attest to how an uncoated CT header would affect under-hood temperatures.
If I had to do it again I’d investigate the 06-08 stock header, however; I’m unsure how much a 04-05 TSX would benefit from a 06-08 header. Perhaps someone here can provide feedback.
Old Aug 11, 2010 | 08:47 PM
curls's Avatar
Weird, I thought the CT header only rattled on the A/T cars (lower idle rpm). Although there is apparently a fix somewhere out there which I'd do if it rattled.
Then again though the Japspeed is 6x cheaper in price, so if each one lasted me a year, I'd still be ahead even after 5.5 years!
Old Aug 11, 2010 | 09:47 PM
feuss2's Avatar
10001110101
Do you also have the comptech catback?
I got the catback first and the header after. I was planning to add a resonator to the catback to quiet it down, and it actually toned down the once header was installed.
perhaps the two work together and there is some mismatch between the comptech parts and stock parts that cause rattle?
i saw the fix for the CT header, but I will not be doing this because there is no need. i have an MT, and a/c or not, there is no problem. the exhaust just gets a little louder when the compressor cycles on at idle.
I noticed that the OEM header is supported around the area that the comptech merges from 4>2, but most aftermarket headers don't hook up to this bracket. maybe this could help?
the flex pipe on the comptech part is also not nearly as flexible as the flex on the oem a-pipe...
Old Aug 11, 2010 | 10:00 PM
curls's Avatar
I am stock from the cat back. No plans to go with anything back there at all.
Old Aug 12, 2010 | 09:12 PM
JTso's Avatar
My dc sport v1 has finally died as well, so I just swap the stock header back on.
Old Aug 12, 2010 | 09:20 PM
curls's Avatar
I still have the stock header but none of the spring-bolts or oem gaskets. If anything I'll go with another aftermarket header I think. I don't want the loss of power associated with the stock 2004 header.
Old Aug 13, 2010 | 10:39 PM
msmching's Avatar
Ex-King of Pasadena
how do you know if it died out?? leaks? cracked?
Old Aug 14, 2010 | 11:04 AM
JTso's Avatar
The flex pipe was leaking. Some may experience complete separation from the exhaust flange.
Old Aug 17, 2010 | 03:27 PM
msmching's Avatar
Ex-King of Pasadena
^^^^^^ thanks!
Old Aug 25, 2010 | 01:13 PM
drunkenbuda's Avatar
Got Phó?
My DC headers are the same way. It's at home collecting dust now lol
Old Aug 25, 2010 | 06:19 PM
curls's Avatar
Back to stock, or another header, or are you running no header?
Old Aug 25, 2010 | 06:31 PM
feuss2's Avatar
10001110101
so glad I got the comptech!
Old Aug 26, 2010 | 03:11 PM
Got Phó?
I'm back to stock headers. I don't know if I want another set of headers or not.
Old Sep 9, 2010 | 01:27 AM
xenonhid's Avatar
CGP Ebony
Cool
So glad I never purchased a DC Header.
neuronbob
3G RLX Tires, Wheels & Suspension
23
Jul 16, 2019 10:48 AM
rp_guy
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
saturno_v
Sep 27, 2015 08:13 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
