DIY: MDX, Pilot, Odyssey spacer install
wham bam thank you ma'am
no one has this besides me. a few 3rd gen guy have done it. but their hood isnt popped as high, they have more clearance.
cheapest place i know. or find someone at a dealer that u know and acura will give the guy that works at the dealer better prices. so u get list pretty much and no shipping
also. u cant mill the intake manifold where the cover sits. u wouldnt have room for the bolts to screw in bc u can only go so deep. and that 1/8" of clearance that u might get wont help much.
I ordered the parts I need this morning from Bernardi in Boston for like 87 shipped. I needed 2 factory gaskets right ?
Also did you say the spacer was only 1 3/4".
If it is, I don't think they're will be much clearance issues on clp's.Maybe the one center beam in the hood but,maybe not much at all
I just came in from putting something on the motor 1 3/4" in between the highest on the motor and the lowest part on the hood and it shut fine.
I really won't know when the parts come but ,this might look great for us clp guys.
measure from the front plenum to the hood. thats where i had a bit of a problem and the hood needed to be raised a tad bit more to clear.
whoa dude,So I might be in the same ball game with you.
I could fit 1 3/4" where I did but 2" would touch the center bar but,I could still close it.
So thats why I opt out for the P2R spacer.
I hope I dont have the issues,I'll have to go remeasure tomorrow when it light out.
Any luck getting you hood down anymore yet?
Has anyone tried http://www.cervinis.net They might could hook us up with some custom hoods...Some look nice, but some look rice.
I never payed much attention but,it looks as if the tabs on the spacer have to be cut like you did to fit.
Do they ?
Did you use a cut off wheel or grind them?
I want to heat up the piece less as possible.
Do they ?
It would be nice to get some exact measurements on how much the clearance issue is. I know it would be much likely less power, but since no one makes cowl hoods for our cars machining the spacer down for proper hood fitment could be an option. I assume the piece is aluminum so it would be very easy to do.
its aluminum.
i had about 1 3/4" or from from the top intake manifold cover to the bottom of the hood. spacer is 1 3/4". but than u have to calculate for engine movement.
but, where i had a problem was the bottom left hand side of the intake manifold cover hitting the hood. wanst something i was expecting. but to be on the safe side, id cut the spacer down to about half of its size. ppl on the 3rd gen side cut 7mm off of the spacer but they also dont need to raise their hood as much as i did.
got a spacer with all bolts (and studs) necessary and gasket for sale in BM
https://acurazine.com/forums/car-parts-sale-361/mdx-intake-spacer-mod-ct-quiet-tip-inserts-753235/
what are the gains like?...did u dyno it?i was thinking of doing this for a while now , i have had te parts for some time now but some things got in the way..still consedering on doing it
u would need diff bolts, i thing u can get away with using 95mm bolts.
been informed that they spacer will not work with the comptech strut bar. sensors and hoses get in the way
havnt dynoed it yet. i got some bent valves. and when i put the spacer on my tires let loose in 1st gear at any mph, never did that before with bent valves. so power was added
, you might be able to get away with a half height spacer, but that is about it
and don't plan on boosting with that there ethier
jb weld the crack for now. or take it to a body shop and see if anyone can weld aluminum.
u got a pic of ur intake manifold? with the top cover off. i want to see the difference.
at a hardware store by my house they had 90 or 95mm bolts. i needed 105mm. so the 90mm bolts just might work for the "P" ppl.
Its not a crack where air could escape. The bolt was going to pop a hole threw but it did not go all the way threw.
Thats why I said a crack.
But, when I first started the car I did get surging with a high idle.
So I checked for leaks . When I restarted the car it idled fine but check engine came on.So then I checked plugs and restarted the car and evrything was all good.
I've been out 3 times with the car and the performance has got beter everytime. ????/ our ecu's must have to learn wtf just happened or something.
Now idles fine,no lights and it go's.
and not too many other people have it either
