What do you guys think? Cold Air Intake?
Honda Ridgeline Owners Reviews Honda Ridgeline Owners Reviews
honda, hidgeline, reviews, forums, accessories, truck, test, drive
Blinglights Introduces Performance Intakes for the Ridgeline
Click here to go to the original topic
Honda Ridgeline Owners Reviews Forum Index -> Engine/Performance
Author Message
mark@blinglights
Posted: Wed May 09, 2007 11:21 pm Post subject: Blinglights Introduces Performance Intakes for the Ridgeline
Hello everyone, as Blinglights sponsors the forum our goal is to provide you with information on all our newest hottest selling products.
BlingLights manufactures its intakes from mandrel-bent, lightweight aircraft aluminum with a powdercoated carbon-black finish, Carbon Fiber Reusable Open Top Fabric Filter and comprehensive photo installation instructions. BlingLights Short Arm intake systems deliver the best performance, value and ease of installation than any other short inlet intake. Our Short Arm intakes install easily under the hood.
Ø BlingLights filters dirt invisible to the human eye, and never needs filter oil!
Ø New Open Top Design provides increased air flow and rigidity over previous closed top design!
Ø BlingLights unique non-woven synthetic filter media never needs oil! This means less down time between cleanings and no more chance of over-oiling. It takes the guesswork out of servicing your air filter.
Ø Carbon-Black powdercoated pipe.
Ø Element is cleanable and is Made for Life!
Ø Will not void your vehicle warranty!
BlingLights Carbon Fiber Intake Kit:
Ø Carbon Fiber Open Top Filter
Ø Open Top Design for Increased Flow
Ø Reuseable Filter, No More Replacing
Ø Black Ionized Stainless Metal Piping
Ø Mandrel Pipe Bends for Less Restriction
Ø Many Sizes In Stock
Ø Rubber Collar for Secure Fit
Ø (2) Adjustable O-rings for Secure Fit
Ø Installation Directions Included
Blinglights Competitive Comparison
BLINGLIGHTS
Carbon-Black Ionized Rust-Proof Piping
Mandrel Pipe Bend (no restrictions)
Slight Growl During Hard Acceleration
On Average 5 - 10 HP Gain.
Retail $124.99
Other Name Brand
Amber Reusable Closed Top Farbric Filter
Black Vinyl Piping
N/A
Inflated Claims but on Average 5 - 10 HP Gain
Retails $300+
No Name Discount Intake
Foam, Non-reusable Filter
Silver of Chrome Paper Thin Aluminum Piping
Kinks at Bend, Restrictive to Air Flow
Vacuum Cleaner Sound Due to Restricted Flow
Possible Decrease in HP Due to Restricted Flow
Sells for $9 (May Not Include Inflated Shipping)
Customer 2003 Civic Si
BLINGLIGHTS Frequently Asked Questions
How Does It Work? When you bolt-on a BlingLights Racing intake, you will notice the difference the next time you drive your vehicle. Our BlingLights Racing Intake Kits are a great way and in many cases the only way to maximize airflow and engine performance. They will replace the factory air box providing both High-Flow air filter technology and a larger air filter size. This winning combination will increase horsepower and sound great too.
BlingLights Racing Intake Kits are the correct diameter for each engine type and will free your car from the size restriction that comes with the factory air box. These economical kits can take a variety of different forms based on vehicle characteristics and available space under the hood. Each kit is designed to provide power throughout the RPM range. BlingLights intakes take advantage of the added airflow provided by an oversized air filter released from the restrictive factory air box.
These kits bring engine airflow out of the factory box by providing a large size open-air conical High-Flow Air Filter. The extra surface area of these open-air air filters provide even more airflow at lower restriction than a name brand replacement filter which is always limited to the size of the factory air box. The larger air filter also captures and holds more dirt increasing its service life before a cleaning is required. The filter is then either directly attached to the engine carburetor or throttle body or indirectly through a tube assembly running from the filter to the engine. All adaptors are made from high quality materials.
Why Does The Factory Intake Need to be Improved? Most people are aware that our High-Flow Air Filter can increase horsepower over a traditional disposable air filter. An air filter change alone however, cannot eliminate other types of air restriction built into the vehicle at the factory. These can be found in the size of the air box and the air path running from the air box to the engine. That’s where air intakes rule the road. They completely replace the factory airflow assembly including the filter, air box and air path. More and more people are discovering the monster power available from a well-engineered air intake, so go ahead and wake the sleeping giant in your car.
How Do You Know It Works? We will not sell an air intake that does not provide a measured increase in horsepower and torque (acceleration). Our air intakes are proven to increase horsepower and torque on a rear-wheel dynamometer (think treadmill for cars). These thoroughly engineered air intakes provide huge increases in power that a customer will definitely feel when they accelerate. BlingLights Racing is known to prove performance!
How Much of an Increase in Miles Per Gallon Should I see from using a BlingLights Racing Intake? Results will vary depending on your vehicle, driving habits, load on the engine (towing for example), existing air system restriction, and other factors. Many BlingLights users report an increase in miles per gallon. Our internal testing is performed using employee and customer vehicles. We usually have the cars for a short period of time that will only allow for fit checks and dyno (power curve) testing. If you take advantage of added power by driving harder, you will not see much of a gain, if any, in MPG.
OK, Enough of the Standard Company Line, What is the Increase in Horse Power I will get, other companys claim pretty incredible numbers? For one thing, it's air, and the density of air varies with both the weather and altitude. That means there is literally more air in the same amount of space when the weather is cool than when it's hot. So one way to get a performance boost is to only drive in cold weather. Since air is variable, air flow claims in absolute terms are not meaningful. This means we must move into the realm of comparison and/or averages. When we do performance testing, we are testing relative horsepower and torque on a particular vehicle on a particular day so we can hold as many variables constant while comparing performance with and without the BlingLights Racing intake on the vehicle.
Can I Install and Maintain the Intake Myself? The kit isn't complicated too install for most application, and the work can be done in your driveway with simple hand tools in about an hour. We recommend to have the kit installed at stereo shop if you are uncomfortable installing on your own. If you do it yourself, you will need a wrench, a ratchet, and a screwdriver. Every 50,000 miles clean the filter with filter cleaner found at your local auto shop. No need to ever replace the filter.
Is the BlingLights Intake Street Legal? In most states our intakes are legal. Our intake kits may not be legal in states where under the hood modifications are not allowed. Check your local laws if you are unsure.
Will the BlingLights Intake Cause My Vehicle Mass Air Sensor to Fail? No, it is both impossible and ridiculous. An engine can only take in a fixed volume of air depending on the engine’s size. The more restriction that an air intake system (filter, air box, and tubing) causes, the greater the potential is for power and mileage degradation.
Will the BlingLights Intake Void the Factory Warranty? NO. The only time this can happen is from improper installation that causes damage to a vehicle system. If a service technician denies your warranty claim ONLY because the car is modified with an Blinglights Racing intake system and the vehicle system failure was not a direct result of the installation and use of an Blinglights Racing intake, please refer him to the Magnusson Moss Warranty act. You can download the Magnusson Moss Warranty act from SEMA’s website at: http://www.enjoythedrive.com/san.
How do I pay by credit card? Once the auction is over click on one of the credit card pictures on the bottom of this page. Just enter your credit card number and auction information. That is it! In the case that paypal is having trouble or your address is unconfirmed you can still pay by credit card instantly to our online account at www.bidpay.com or www.moneybookers.com as well.
What is your return policy? As a high-volume power seller a money back guarantee is optional upon payment for all paypal users Optional Money Back Guarantee Details Here. For all non-paypal customers only you are entitled to a full refund less shipping costs if item is mailed back within 1 week of receiving item. Item must be in the EXACT brand new condition it was received along with the auction item number and reason for return. No pre-approval necessary. By leaving or threatening to leave negative feedback will void this policy.
What our customers have to say
2006 Scion XB
BlingLights Racing,
My recent intake system purchase, was a great one. Installation was quite simple & straight-forward, I had it on my xB within twenty-five minutes. The pipe itself is very well made, hand polished & the filter looked amazing with the carbon fiber accents. After installing the intake I noticed an immediate increase of power throughout each gear. The sound was deep and clean also throughout the RPM's. My car just runs all around better, again I am happy with my purchase and me and my wife would like to Thank you!
-Devin & Julie R
Las Vegas, Nevada
So now your asking how much is it? For $74.99 you will get instant power & instant looks.
Please PM me for questions, and orders.
Thank You!
Back to top
Page 1 of 1
Powered by phpBB 2.0.17 © 2001, 2002 phpBB Group :: FI Theme :: All times are GMT
[ IntegraMOD © 2004 Ronald John David ]
Author Message
mark@blinglights
BLINGLIGHTS
Retail $124.99
Other Name Brand
Black Vinyl Piping
N/A
Retails $300+
2006 Scion XB
BlingLights Racing,
-Devin & Julie R
Las Vegas, Nevada
Thank You!
Back to top
Page 1 of 1
Or This? Same thing though just different site
Here is the link!
http://www.bonanzle.com/booths/bling..._unique_514742
buy sell my bonanzle people help See cart
Log In | Register
Home » Buy » Blinglights Booth » 2004-2008 Acura TL Cold Air Intake System 05 06 07 08
About the Seller
blinglights
contact | profile
feedback: 4901 | 99.5% | more
joined on: 10/01/08
Items 2068 items in Booth
Top Categories Parts & Accessories
Close
Click a thumbnail to enlarge 2004-2008 Acura TL Cold Air Intake System 05 06 07 08 $95.00 OBO CHECKOUTNo pre-registration required. Zoom!SHIPPING PRICE$15.00PAY WITHCash, Paypal, MOCATEGORYParts & AccessoriesREVIEWSSearch Amazon for product reviews
FEATURED: 2004-2008 Acura TL Carbon Fiber Cold Air Intake System
��� BlingLights manufactures its intakes from genuine ultra-light weight carbon fiber and a Carbon Fiber Reusable Open Top Fabric Filter. BlingLights Cold Air intake systems deliver the best looks, performance, value and ease of installation than any other cold air intake. BlingLights Cold Air intakes install easily under the hood.
��� BlingLights filters are completely shielded from drawing in warm air with the 360 degree attractive genuine carbon fiber heat shield. Built-in filter uses the newest open top design for increased air flow over conventional cone filters.
��� BlingLights unique non-woven synthetic filter media encased within the carbon fiber enclosure never needs oil! This means less down time between cleanings and no more chance of over-oiling. It takes the guesswork out of servicing your air filter
��� BlingLights filters dirt invisible to the human eye, and never needs filter oil!
��� Hi-flow flex pipe is rigid yet weighs less then that of any of the materials used by competitors.
��� Element is cleanable and is Made for Life!
��� Will not void your vehicle warranty!
��� Carbon Fiber Open Top Heat Shield
��� Open Top Filter for Increased Flow
��� Reusable Filter, No More Replacing
��� Flexible Extendable Piping more chance of over-oiling.
��� Mandrel Pipe Bends for Less Restriction
��� Rubber Collar for Secure Fit
��� Adjustable Metal Brackets
��� $15.00 Intake Accessory kit Included
��� Installation Directions Included
BlingLights Competitive Comparison
Leading Brand Name
No-Name Intake
Carbon Fiber Reusable Open Top Fabric Filter Amber Reusable Closed Top Fabric Filter Foam, Non-reusable Filter
3.1 Pounds Total Weight! 9.5 Pounds Total Weight. 10.7 Pounds Total Weight.
Genuine Light Weight Carbon Fiber Black Vinyl Piping Silver of Chrome Paper Thin Aluminum Piping
Slight Growl During Hard Acceleration Slight Growl During Hard Acceleration Vacuum Cleaner Sound Due to Restricted Flow
On Average 15 - 20 HP Gain. Inflated Claims but on Average 15 - 20 HP Gain Possible Decrease in HP Due to Restricted Flow
Retail $244.99 Retail $300.00+ Sells for $9 (Usually Includes Inflated Shipping)
Receive a FREE Authentic BLINGLIGHTS Cap Valued at $24.95 With Your Order While Supplies Last
Brushed cotton twill, six panel, sandwich bill, relaxed crown, self-fabric strap with metal closure and tuck-in design. Sport the name and show your pride.
How Does It Work? When you hookup a BlingLights intake, you will notice the difference the next time you drive your vehicle. Our BlingLights Intake Kits are a great way and in many cases the only way to maximize airflow and engine performance. They will replace the factory air box providing both High-Flow air filter technology and a larger air filter size. This winning combination will increase horsepower and sound great too.
BlingLights Intake Kits are the correct diameter for each engine type and will free your car from the size restriction that comes with the factory air box. These economical kits can take a variety of different forms based on vehicle characteristics and available space under the hood. Each kit is designed to provide power throughout the RPM range. BlingLights intakes take advantage of the added airflow provided by an oversized air filter released from the restrictive factory air box.
Why Does BlingLights Make Such a Big Deal about Carbon Fiber? In addition to vehicle power, the overall weight of the vehicle is very important to overall acceleration. In general terms, a weight reduction of 100 pounds will lower the ET by .1 seconds. Carbon fiber, a black fabric weave held together by a transparent resin, weighs one-third to one-fifth as much as similar-strength steel but is seven to 10 times as expensive. Slicing weight dramatically improves fuel economy and performance, and is why carbon fiber is used in race cars and jet planes. The $65,800 Corvette Z06, uses carbon fiber in the front fenders, front wheelhouses and floor. Carbon fiber helps keep the weight of the 505-horsepower speedster down. BMW's M6 coupe, on sale in Europe, has an unpainted carbon-fiber roof. Not only does it save weight, it's beautiful to look at and has a high-tech feel.
How Much of an Increase in Miles Per Gallon Should I see from using a BlingLights Intake? Results will vary depending on your vehicle, driving habits, load on the engine (towing for example), existing air system restriction, and other factors. Many BlingLights users report an increase in miles per gallon. Our internal testing is performed using employee and customer vehicles. We usually have the cars for a short period of time that will only allow for fit checks. If you take advantage of added power by driving harder, you will not see much of a gain, if any, in MPG.
Will the BlingLights Intake Void the Factory Warranty? No. The only time this can happen is from improper installation that causes damage to a vehicle system. If a service technician denies your warranty claim ONLY because the car is modified with an AEM intake system and the vehicle system failure was not a direct result of the installation and use of an BlingLights intake, please refer him to the Magnusson Moss Warranty act. You can download the Magnusson Moss Warranty act from SEMA’s website at: http://www.semasan.com/main/main.aspx?id=60128.
What If My Vehicle has Air or Vacuum Tubes on the Original Intake? Our Intake Includes an Accessory kit with a tool and grommets to hook up your existing vacuum and air lines. Again if you feel uncomfortable installing, we recommend bringing the vehicle into your local stereo shop for a hassle free install.
Where does my MAF sensor hook up? If your vehicle has an MAF sensor, we highly recommend purchasing an MAF sensor adapter (sold separately). If you need help locating the correct adapter for your vehicle, please contact us and we would be glad to help. If you do not want to purchase this adapter and are bringing the vehicle into a shop for installation they can customize a slot for the MAF and install it without a problem. Most Dodge and Jeep vehicles do not use this sensor.
All Mount Accessories Included, Quick Replacement & Easy To Install.
(MAF Sensor Adapter not included. This is required for some vehicles)
Will Fit Most Domestic & Import Vehicles From Race Cars,
Street Cars, SUVs, Trucks and Vans
What Our Customers Have to Say
I2003 Mustang GT
BlingLights,
This is the first performance product that I have purchased. I was very pleased with the increased power and torque, but I was most excited by the increased throttle response.
Through research done prior to my purchase, I knew that I could expect about 15 hp in gains, and for $225, I felt it was a very resonable purchase. I knew that this wasn't a supercharger, and I wasn't a two hour bolt on away from being a Corvette beater, but 15 hp is a great place to start.
I am very satisfied.
Jeremy S.
Tamarac, FL
Fast Shipping, Handling, and Insurance
Discounts available for combined auctions
100% Customer Satisfaction Return Policy
��� Customer satisfaction is guaranteed.
��� For customers, if for any reason you are not satisfied with your merchandise, please e-mail us as soon as possible for us to make arrangements for an exchange or refund.
��� Returned merchandise must be 100% unused by any trials, testing or other signs of wear.
��� Buyer is also responsible for the shipping cost for sending it back.
��� Shipping fees are non-refundable.
��� The refund will be issued as soon as the product is received back and verified to be in proper condition.
Best offers do not include shipping. Happy Bidding and good luck.
Powered by eBay Turbo Lister
The free listing tool. List your items fast and easy and manage your active items.
ADVANCED DETAILS
Condition
UsedQty
1Created on
November 01Shipping Discount
No combined shipping offeredPrice Discount
None setItem Number
514742My Cart 0 Items Checkout
Sneak peek at a few of blinglights's other itemsView all 2068 of blinglights’s Items $100.00
$100.00
2004-2008 Toyota Prius Cold Air Intake System 05 06 07
$100.00
2004-2008 Nissan Maxima Cold Air Intake System 05 06 07
$95.00
$100.00
2004-2008 Chevy Aveo Cold Air Intake System 05 06 07
$95.00
$95.00
$95.00
2003-2008 Toyota Matrix Cold Air Intake System 05 06 07
$100.00
2003-2008 Honda Element Cold Air Intake System 05 06 07
$100.00
Top Blog About Bonanzle Press What's New? Contact Us Terms of Use Privacy Statement What do you think about this page? Tell us what you think of this page. If you've found a bug, there's a more detailed form for that here.
Could you find what you were looking for on the page? --- Very much Yes I suppose... Not really Not at all
Does it load fast enough? --- Very much Yes I suppose... Not really Not at all
What web browser are you using? --- Internet Explorer 6 for PC Internet Explorer 7 for PC Internet Explorer 8 for PC Internet Explorer 6+ for Mac Firefox 1 or 2 for Mac Firefox 1 or 2 for PC Firefox 1 or 2 for Linux Firefox 3 (for any system) Safari Opera
What comments or questions do you have about this page?
Cancel © 2009 Bonanzle. All Rights Reserved.
Enter a message to send to blinglights
Subject
Message
Cancel
Asking about 2004-2008 Acura TL Cold Air Intake System 05 06 07 08
Message to seller:
Close If you'd like to remove an item, click on its picture and drag it outside of the cart
When you're ready to buy, click the 'Checkout' button at the bottom of the cart.
Log In | Register
About the Seller
blinglights
contact | profile
joined on: 10/01/08
Close
Leading Brand Name
No-Name Intake
I2003 Mustang GT
BlingLights,
Jeremy S.
Tamarac, FL
ADVANCED DETAILS
Condition
UsedQty
1Created on
None setItem Number
$100.00
$100.00
$95.00
$100.00
$95.00
$95.00
$95.00
$100.00
$100.00
Subject
Message
Cancel
Message to seller:
2008 335i e92 6MT
"OK, Enough of the Standard Company Line, What is the Increase in Horse Power I will get, other companys claim pretty incredible numbers? For one thing, it's air, and the density of air varies with both the weather and altitude. That means there is literally more air in the same amount of space when the weather is cool than when it's hot. So one way to get a performance boost is to only drive in cold weather. Since air is variable, air flow claims in absolute terms are not meaningful. This means we must move into the realm of comparison and/or averages. When we do performance testing, we are testing relative horsepower and torque on a particular vehicle on a particular day so we can hold as many variables constant while comparing performance with and without the BlingLights Racing intake on the vehicle. "
lol not a straight answer x_X
they're cheap though? who wants to buy one and test it out xP
AZ Community Team
Received 7,770 Likes
WTF??
Cliffs?
Cliffs?
