Inner cv joint
Bad. How many miles?
I have the same knock on my right side with slight vibration at freeway speed. Since I'm still under warranty I took it to the dealer and they confirmed that it's a bad axles. Only issue is that they are on national backorder and I'm stuck waiting for the part to be available. In the meantime I have a slight vibration at freeway speed and a knocking sound pulling into my driveway. I guess it can be worse.
TSX Wagon is running very smoothly now.
Oh I know ....i'm gonna install my brand new rims (Oem honda ) and I will inspect the inner cv joint myself , take pictures and document everything ...then go back
car has 50 000miles
car has 50 000miles
Mine look fine at 40k. Seems like the right axle cannot handle the load for some reason. Wagons are heavier by about 150lbs, but that shouldn't matter.
My dealer also tried to tell me it was my tire balance but I escalated the issue to the GM. Funny thing is don't they want to make money!?!? I would still pay the diag fee and Honda would reimburse if under warranty. Funny how they think everyone is an idiot except them. Number one customer service tip is to listen to your client.
xtcnrice (03-08-2017)
Agree ; I know it's the axel i've been driving Acura for over 12 years ...I changed the axel on my Type R 4 times ....Only Oem or raxels will do ...I'm cover under warranty ,I wanna do this before it gets worst ; so I will install my new summers rims ,have them look at the car again with me present ,then I'm gonna insist they do the axel ...with new axels the vibration will be gone ...they won't be able to deny it was the axels ; inevitably covering it under warranty
I'm sure they are. IMO, it's pretty simple to listen to your customer to see if they are knowledgeable before choosing to follow protocol.
I am also noticing vibrations when accelerating and even cruising, especially on the highway. Very noticeable at times in the steering wheel. Also, probably normal/diffrent, over 3K rpms there is a high amount of vibration in the car as well. I usually pawn it off as the road however. Are there any examples/videos I can look into to see if this is normal operation? I have both a powertrain + aftermarket warranty.
I had vibration under brisk acceleration which went away at cruising speed. Yup, first thing dealer wanted to do was replace the tire. I also have non-oem alloy wheels, so they suspected that too. I said no; it would be a waste of time, vibration only happens under acceleration, and that on this forum, people reported similar experiences. Mine happened around 55k miles. Got the axles replaced under the powertrain warranty. One of the bushings also had a small tear, so I had them replace that too but with my own dime.
can I visually inspect the cv to see any issues before power train runs out at 100k?
I am at 85 k now
If you have no vibration there's nothing to be done ; I will personally remouve the inner cv joint and inspect the inside , then repack it with grease and reinstall a new band ! Look a my Video give it the shake test ....lol
no vibration at low or high speeds. I mean it's not smooth like my Lexus LS , but no vibration here
thanks
However, one thing that stays constant is that the vibration frequency increases with speed.
Does it get worse with higher speed? Mine also feels random at times and seem to be exaggerated by different types of surfaces. I can also feel it through the chassis of the car, not just the steering wheel.
Yes, it is worse at higher speeds. I certainly can feel a vibration through the chassis of the car. It is strange because the car is so solid at times, and at times I feel like I am driving my old Pontiac with the vibration, especially noticeable in the steering wheel. Its not enough where if someone drove my car would say "damn you have a problem", but being that I drive it everyday, I look for things like this.
I have found that on my wife's 09 that hard cornering accelerations bring out the symptoms more so that just normal driving. I'm pissed though, cause I complained about this while I was under the extended warranty and the dealer wasn't able to 100% reproduce my complaints (shocking right?). I mentioned it to the service writer last week during the latest maintenance stop and he seemed to be in the know now. I guess 2 years makes a difference.
MCDavis (03-11-2017)
I just had to deal with bad cv joints. Was getting a bit of a shake at around 60-80 mph when accelerating. It would only shake when the pedal was pressed between those speeds. Had to get them replaced.
MCDavis (03-23-2017)
I'm currently at 101,800 miles, and my car is at Acura having the CV Joints replaced. although it seems more to me it's the half shaft bearing on the half shaft, anyhow HEre's how mine sounded:
https://youtu.be/F4S-P5pG0ek
